Easy Button End Table MAX 26.5" x 24" x 37.5" hwd - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
Old 03-13-2009, 04:02 AM - Thread Starter
NEO Dan's Avatar
Actually you are right, I did change it, and I told you back in post #53
Dan
NEO Dan is offline
Old 03-13-2009, 11:59 AM
smoke90's Avatar
raaahhh I missed it
This is a good point I should have cut it after the assembly.
Especially to be sure they are concentric
Dan I saw the time you were posting. 4.02 am. do you ever sleep?
smoke90 is offline
Old 03-14-2009, 12:56 PM - Thread Starter
NEO Dan's Avatar
Lately I am going NonStop™
Dan
NEO Dan is offline
Old 03-20-2009, 06:04 PM
RockRover's Avatar
Originally Posted by NEO Dan View Post
Smoke,
you win a cookie. Thanks for letting me know. It's sad that I missed it, but at over 2300 views someone else should have caught this by now. I'll update the cut sheet drawing.
Nobody caught it because the original cut sheet was correct. My buddy had the original cut sheet, was willing to choke on the MDF dust, and had his crew do the cuts for me. I finally picked up the pieces today, somewhat bummed that the dimensions would be wrong. Wouldn't you know it, I dry fitted everything together an hour ago and the pieces fit like a glove!
Thanks Dan!
I'll start gluing tomorrow and start a build thread. O'yea, I'm stuffing the box with an IXL 18.4.4, powering with an EP2500, HPF'ering with a Reckhorn B, and dialing in with a BFD and REW/RS SPL combo.
--Doug
Easy Button End Table w/IXL18.2...1700cf room + REW = Base bliss!
RockRover is offline
Old 03-20-2009, 09:11 PM - Thread Starter
NEO Dan's Avatar
Thanks Dan!
--Doug
Interesting, and thanks for the info. I really had begun to have doubts about publishing plans. I feel really bad for wasting anyones time and money . I think I may have introduced errors into the plans at the time I was working on the modified version for Stinn.
That's an interesting processor combo, if you get the chance do a loop-back measurement with REW and post it up, I'm currious about what the low end rolls off like. I would guessing that you will need to make a wide parametric cut between 30-60 hz, as I hear the B1 rolls off early.
Dan
NEO Dan is offline
Old 03-20-2009, 09:36 PM
RockRover's Avatar
Dan - Yea, maybe when you moved the width 1" and height 1" for Stinn. I printed the cut-sheet before that.
What ever you do PLEASE don't quit your plan designs! About 2 month's ago I thought Best-Buy was the cheapest place to buy a 'quality' sub! It's because of your cut-sheets that I continued to research and learned enough to give DIY a go. It gave me a starting point on a box design, and I could spend time on other topics like WinISD, drivers, amps, etc. Had I had to learn box design on top of it all I might have just skipped DIY altogether.
I plan on posting before and after REW analysis. Never heard about the early roll-off of the B1. The HPF of the B1 starts at 10hz, and on up from there. I'll use the BFD if my PEQ needs go past what the boost/cut levels' can muster from the B1.
Funny how most on this site prefer the EQ.2 and on the Shack most are modded Art Clean Box's or the B1. I would have done the MIC2200 for my signal boosting and HPF duties, but I read your analysis on it about a day too late! Nice deals on the Bay for used MIC's btw.
Thanks again Dan, and keep designing!
--Doug
Old 03-27-2009, 05:57 PM
smoke90's Avatar
the sub is finish will all the equipment recommended by Dan. This subs rocks and it has deep bass for home theater but also sharp bass for a rock concert.
Good Job Dan
smoke90 is offline
Old 03-27-2009, 06:29 PM - Thread Starter
NEO Dan's Avatar
Smoke,
thanks for the kind words. Congrats on pulling it and the drawings together.
Dan
NEO Dan is offline
Old 04-16-2009, 08:58 PM
?mwf15?'s Avatar
Hi Dan,
thanks so much for your post and designs. Would this enclosure be the one for all around use(70% HT 30%music) this would also be my one and only sub. between the EP2500, the MAL-X, mdf, and the little misc hardware, ill be out of money. do i need the other electronics being described? i read of the subsonic filter for this build. which do i need? I apologize for my noob q's but i did a search for subsonic filter and only found an explanation of what it is.
Brandon
?mwf15? is offline
Old 04-17-2009, 01:31 AM
Fackamato's Avatar
My Maelstrom-X should be here within one month.
Has anyone verified the tuning of this enclosure? NeoDan states 10.5-14Hz in the first post.
Fackamato is offline
Old 04-17-2009, 11:09 PM - Thread Starter
NEO Dan's Avatar
Originally Posted by ?mwf15? View Post
Hi Dan,
Brandon
The filter is a requirement, without it you risk having to buy another woofer.
Without the filter the woofer can operate as if it were just sitting out in free air, this can occur when ever the source material contains energy below the boxes tuning.
Actually the situation is somewhat worse than free air as the mass of the air in the port is basically added on to the moving mass of the of the driver .
Dan
NEO Dan is offline
Old 04-17-2009, 11:16 PM
?mwf15?'s Avatar
im wondering that too. im about to build a sub and im wondering if this one will be fine to 80hz. another post showed a big spike at 80.
Dan, would the smaller easy button be better for this?
?mwf15? is offline
Old 04-18-2009, 10:30 AM - Thread Starter
NEO Dan's Avatar
add to this post:
The port does provide some loading to about one third octave below tuning. So there is some cushion there.
They are very similar in design, I had no issues running them up to 160hz.
What 80 spike are you referring to? link please
Dan
NEO Dan is offline
Old 04-18-2009, 06:58 PM
mayhem13's Avatar
Quoted: 43 Post(s)
Hey Dan, given your dimensions, box volume, port length and surface area, there seems to be a significant 1st port resonance at 80hz. Here's the link to the Unibox sim
http://www.avsforum.com/avs-vb/attac...0&d=1240029545
Do your Sims show this as well?
mayhem13 is offline
Old 04-18-2009, 11:46 PM - Thread Starter
NEO Dan's Avatar
Yea I am aware, fortunately the sim is way overblown as compared to actual measurements. The measurements show just a little wiggle in the phase. Have a look in the threads for the smaller versions, the measurements have always been posted. In this respect it preforms way better than a straight port, heck the prior version would have had to have >160" long straight ports to hit the same tuning. Sim that up
Dan
NEO Dan is offline
Old 05-12-2009, 11:39 AM
Fackamato's Avatar
Argh! Still no Maelstrom-X in my possession! It seems the factory is having a hard time sourcing the voice coils for the M-X...
At least I can dream...
"disclaimer": (I didn't order from Exodus Audio, but through StreamingAudio which buys directly from the factory afaik)
Anyone built this thing yet? Verified the tuning?
Old 05-12-2009, 05:41 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1771
NeoDan is pretty accurate with these things, I'd say it's what he posted, or close enough that no one would know the difference anyway.
_______________________
The SEOS Waveguide Project
Erich H is offline
Old 05-12-2009, 08:15 PM - Thread Starter
NEO Dan's Avatar
Hehe,
funny you should bump the thread. I came by to see if there was an update from the fella I lent my WT2 out to to verify the tuning. I'll go bump up his thread and see if we can get some info
Dan
NEO Dan is offline
Old 05-13-2009, 12:20 AM
Fackamato's Avatar
Hehe,
Goodie!
Old 05-25-2009, 04:49 AM
Fackamato's Avatar
Any updates?
My M-X Neodan super super edition should be finished by the end of August.
As I don't have Wal-Mart here, I'm wondering how much stuffing I should use. Is there any recommendation?
Question: any words on the tuning yet?
Old 09-17-2009, 12:39 AM
robertcharles's Avatar
OK so this is it for this series, I got lucky and found an alternate layout that allows for ~1/3 increase in volume over the original.
Specs:
Volume 8'³/13827.5625"² before driver displacement
Port 3-2.5" x 7" total area >8" ID port
Tuning is as yet unverified, likely in the range of 10.5-14Hz
Use a 1.25" round over for the port, MLCS item #8659
The cheap pillows from WalMart will still be a good idea.
Dan,
I have been looking at this design for quite some time. I am in the process of working out my 6 and 7 chennle sin my 7.1. I have a bunch of things going on-actually too many, but I am at least planning things and trying to get things moving. This box can be used for a Mal X, but is there a way to flip it upright and put the driver on what used to be the base and have the box tall with a smaller footprint and the same overall dimensions?
Is there any deterent to facing the driver and port to the wall other than clearance? This would eliminate need for a grill and the finish would be very simple because it will be totally covered as the other cabs in the room except for the LMS's.
Robert
robertcharles is offline
Old 09-17-2009, 04:45 PM - Thread Starter
NEO Dan's Avatar
Robert,
this would be the side mount option
Dan
NEO Dan is offline
Old 09-17-2009, 05:33 PM
I like both option, but I need it tall like my other cabs. Driver would be on the side and so would the port and then stand it up on end?
Old 09-17-2009, 05:40 PM
dbldare's Avatar
Would it be possible to put feet on the port side and have it lifted a bit on that side, and let it "breath" out of the bottom? That may make it to top heavy with the driver on the top of the cabinet though?.?.? hummmm....
dbldare
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
Old 09-17-2009, 10:11 PM - Thread Starter
NEO Dan's Avatar
Or you could down fire, but that's it there's nowhere else to put anything
Dan
NEO Dan is offline
Old 09-17-2009, 11:03 PM
That is a good idea, but how far from the floor does it have to be to be fully effective. I have a little height problem where they are going. I can go as high as about 45 inches. would that be enough. Also, when these cabs are going full tilt, do they vibrate and bounce around much? I wanted to do something like a stand with it. I guess I could make a shelf right above it and put the cab just below and effectively use the shelf as the stand top and eliminate the cab as a possible direct vibration source.
Old 09-18-2009, 05:06 PM - Thread Starter
NEO Dan's Avatar
Robert,
I don't think they would move when downfiring. 4-6" legs are enough so it would be under 45" tall
Dan
NEO Dan is offline
Old 09-18-2009, 05:54 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
do those cornered ports offer the same performance as straight ports?
seems like they would be turbulence city.
Listen. It's All Good.
LTD02 is offline
Old 09-18-2009, 08:49 PM
Robert,
Dan,
I think I am going to go for the box in the original setup. I might have to give it a few twists to make it fit into the setting where it is going. I have decided on the finishing touches for the other channels, and I am going to use a set of Klipsch forte's for the side surrounds. They will be enclosed in a set of columns that will possibly be utilized for DVD storage also. I am really excited about the prospects of this.
Have you done any testing on the cabinet with the Mal 18?
Robert
Old 09-18-2009, 09:25 PM - Thread Starter
NEO Dan's Avatar
I've pushed the prior version really hard, it has a smaller port. If pushed really hard without a SSF & below tuning you can get port noise, but this is to be expected @ 6Hz & 2"+p-p excursion. A couple hertz higher and you have enough pressure to really rattle the doors and windows in there frames.
Long ago I built a low tuned single 12" Driver was an OEM copy of the JL 12w1. The box was ~2.8'³ and I had to take the 4" port tube from the front through the back and up a foot and back into the box IIRC the tuning was <16Hz. This thing went nice and low but sounded crappy. I think it was a port velocity and port resonance problem. I don't hear any of that with the End Table design, and I am significantly tougher when listening for these things now than as I was then. I haven't built this one yet, but I wish I had already built & tested this version so I could say with certainty it's "perfect" I'm building on what I've learned from building the previous versions. I don't see any reason that this one should any problems though.
Dan
NEO Dan is offline
