Noob needs some help - sub building - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-26-2008, 03:51 PM - Thread Starter
redpen's Avatar
I'm very sad that my PB12 died... Instead of buying another sub, I was told I should consider building my own..
Can someone link me to a FAQ or something along those lines? I'm hoping to learn the basics so I can decide if I want to build one myself.
Also, if you can link to some vendors for amps/subs or recommend some brands I should be considering.
redpen is offline
post #2 of 3 Old 12-27-2008, 01:46 AM
vasyachkin's Avatar
i suppose you could search the forum. i believe this question gets asked routinely.
also outline how much you already know about subwoofers so we can establish a starting point for you.
vasyachkin is offline
post #3 of 3 Old 12-27-2008, 10:06 AM
XanderMoser's Avatar
Also, how much you know about basic construction and power tools. Also which tools you have access to
And your budget.
XanderMoser is offline
