Master Index of DIY Subwoofer Projects - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #91 of 189 Old 07-26-2009, 08:27 PM
usil's Avatar
Here is mine: 6.3 cubic ft - 6" ported; 12 Shiva-X
http://www.avsforum.com/avs-vb/showthread.php?t=1148326
Usil
usil is offline
post #92 of 189 Old 07-27-2009, 12:07 AM - Thread Starter
LTD02's Avatar
Quoted: 2462 Post(s)
Liked: 2783
nice work usil. added!
Listen. It's All Good.
LTD02 is offline
post #93 of 189 Old 12-07-2009, 05:30 PM
mynym's Avatar
Quoted: 31 Post(s)
Please append my Tuba HT (THT) build thread that can be found on BFM's forums here: http://billfitzmaurice.info/forum/vi...php?f=5&t=8589
mynym is offline
post #94 of 189 Old 12-07-2009, 06:12 PM - Thread Starter
LTD02's Avatar
Liked: 2783
cool. i linked that as 1 and your avs as 2 in the master index. if it should be presented some other way, just let me know and i'll change it up. the master index belongs to us all. i'm just the keeper for now.
LTD02 is offline
post #95 of 189 Old 12-11-2009, 04:14 AM
jaco pasta's Avatar
what is preferred sealed or ported design?
jaco pasta is offline
post #96 of 189 Old 12-11-2009, 09:05 AM - Thread Starter
LTD02's Avatar
Liked: 2783
welcome to avs jaco. the answer is it depends. lots of discussions around here for identifying the variables. ;-)
LTD02 is offline
post #97 of 189 Old 12-12-2009, 11:05 PM
Vinculum's Avatar
Quoted: 13 Post(s)
I think it would be benefical to group all the Tuba Home Theater subwoofer build threads together when you get a chance? Thanx!
Vinculum is offline
post #98 of 189 Old 12-13-2009, 01:11 PM - Thread Starter
LTD02's Avatar
Liked: 2783
i suppose the list is getting large enough that segmenting it might make some sense. given that everybody will want to carve it up in different ways, i'm still noodling what makes the most sense. maybe i will just breakout all horns as a first, very rough, sort that most everyone could agree with. it seems stupid that such a trivial database sorting app hasn't found its way into discussion fora yet, oh well, i'll see what i can do.
LTD02 is offline
post #99 of 189 Old 12-13-2009, 01:15 PM
radman12's Avatar
Liked: 27
sealed, ported, horns?
radman12 is offline
post #100 of 189 Old 12-13-2009, 07:00 PM - Thread Starter
LTD02's Avatar
Liked: 2783
the problem is that everybody will want a different cut.
some will want size.
some will want cost.
some will want efficiency.
some will want extension.
some will want max spl at single hz.
some will want max spl at teens hz.
some will want max spl at 20hz.
some will want a specific design (sealed/ported/horn).
and so on.
given that there are a boatload of ways of "slicing and dicing" the builds, i'm not really sure that it makes sense to try to sort them. i suppose some sort of cluster analysis might work, but that seems like overkill for what i had in mind here.
i'll noodle your comments.
LTD02 is offline
post #101 of 189 Old 12-13-2009, 07:21 PM
Vinculum's Avatar
Quoted: 13 Post(s)
Wouldn't some form of organization be better than none?
Yeah I know its alphabetical, but that does no good when the sort starts with user names, first names, "THE", thread topics, driver model #s, subwoofer pet names, ect.
Makes most sense to me to organize by alignment, as this is most DIYer's fork in the road to make comparisons on.
Just my 2 cents, hope it helps!
Dr V
Vinculum is offline
post #102 of 189 Old 12-13-2009, 09:39 PM - Thread Starter
LTD02's Avatar
Liked: 2783
after noodling it hard, i don't think any ordering makes sense.
the reason is that any person can make an equally valid rationale for another sort.
for example, should horn subs be grouped with their efficiency counterparts, their cost counterparts, or their response counterparts?
this kind of argument grouping / comparisons is without end.
everybody will have a different (and valid) opinion.
maybe it would be best to tag each build so that it can be easily sorted by users.
if someone wants to pull out all the tht builds that should be easy, even though at the moment it is impossible.
let me noodle that for a while. i see where you are coming from.
ten years from now, we will look back on this problem and laugh...
LTD02 is offline
post #103 of 189 Old 12-13-2009, 10:28 PM
Cy-Gor's Avatar
price and difficulty come to mind.
and/or maybe driver/enclosure size since thats a good comparison.
the size one would help with "approval factor"
But for now a decent description helps.
maybe change the links to just the names then add a sentence or two after for a summary.
just a few ideas
Cy-Gor is offline
post #104 of 189 Old 12-15-2009, 12:25 PM
radman12's Avatar
Liked: 27
hometheatershack has a nice way of slicin and dicin
http://www.hometheatershack.com/foru...-database.html
radman12 is offline
post #105 of 189 Old 12-29-2009, 05:48 PM
supermoore1025's Avatar
Which of these come with the kit and has all the pre cuts for the box and is under $500, I have never diy a sub before so I want something easy to start off with and I guess I am never going to learn if I don't try right lol?
supermoore1025 is offline
post #106 of 189 Old 03-10-2010, 07:41 PM - Thread Starter
LTD02's Avatar
Liked: 2783
more research required supermoore1025...
LTD02 is offline
post #107 of 189 Old 04-15-2010, 05:40 AM
stgdz's Avatar
stgdz is offline
post #108 of 189 Old 04-15-2010, 10:20 AM - Thread Starter
LTD02's Avatar
Liked: 2783
thanks stgdz, added!
LTD02 is offline
post #109 of 189 Old 04-15-2010, 04:06 PM
Oklahoma Wolf's Avatar
Quoted: 20 Post(s)
Oklahoma Wolf is offline
post #110 of 189 Old 04-16-2010, 07:26 PM - Thread Starter
LTD02's Avatar
Liked: 2783
added! i try to keep up with all the builds, but alas i can't. i was thinking of asking for new builds every six months or so. you beat me to it.
LTD02 is offline
post #111 of 189 Old 06-09-2010, 04:56 AM
mjg100's Avatar
I like this idea for sub arrangement. You select a driver and have all of the different possibilities using that driver listed together. This would not be the greatest for a person that wanted to look at only THTs for example, but it is great for those that already have drivers and want to look at other possibilities. Also great for those that come across a good deal on a driver and want to know what they can do with it. Might need both though. Theater Shack is set up this way, Driver based and configuration based. Makes for extra work on your end, but it is nice for searching through.
mjg100 is offline
post #112 of 189 Old 06-09-2010, 01:46 PM
Gmichael2's Avatar
Great thread. When do I get added?
Gmichael2 is offline
post #113 of 189 Old 06-10-2010, 11:41 AM - Thread Starter
LTD02's Avatar
Liked: 2783
gmichael2, i've been lurking during your amazing build thread...i should have added it earlier...awesome stuff...added!
LTD02 is offline
post #114 of 189 Old 06-11-2010, 07:37 PM
corock's Avatar
You need a Maelstrom 21" in here (see signature)
corock is offline
post #115 of 189 Old 06-11-2010, 09:55 PM - Thread Starter
LTD02's Avatar
Liked: 2783
corock, added! now, you have to actually finish it. ;-)
LTD02 is offline
post #116 of 189 Old 06-11-2010, 10:37 PM
corock's Avatar
I'm not sure I remember what life is like without having this build. Besides, do I have the record for the longest time to build a subwoofer yet?
corock is offline
post #117 of 189 Old 06-16-2010, 12:05 PM
Gmichael2's Avatar
Thanks. I'll try to have it finished in the next week or two. It's been a long build, but not as long as corock's. (It was his build that started on another site that inspired my build)
post #118 of 189 Old 06-18-2010, 11:24 PM - Thread Starter
LTD02's Avatar
Liked: 2783
roger that gmichael, i've never been one to nudge folks, but a midrange egg actually holds much more potential than a bass egg. don't we all love mother nature and what she can do off axis? ;-)
LTD02 is offline
post #119 of 189 Old 07-17-2010, 12:59 PM
pbc
pbc's Avatar
Quoted: 403 Post(s)
Liked: 213
I think mine are ready to be added to this list!!
http://www.avsforum.com/avs-vb/showthread.php?t=1233892
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is online now
post #120 of 189 Old 07-18-2010, 01:42 AM - Thread Starter
LTD02's Avatar
Liked: 2783
i'm sorry for not including your build...added!
LTD02 is offline
