Master Index of DIY Subwoofer Projects - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #121 of 189 Old 09-06-2010, 03:18 PM
mwmkravchenko's Avatar
Liked: 27
Mines an ugly front loaded horn. Goes to show you what can be done with some cheap material and a lot of thinnin! But it is proving to be very tough to measure ultimate SPL with. I'm sticcking with the sims as they have held true up to now. 200 watts and almost 120db at 18 hz. Other than size this is a keeper if you have the room.
http://www.avsforum.com/avs-vb/showthread.php?t=1258205
Complete pics here:
http://s407.photobucket.com/albums/p...n%20Subwoofer/
Mark
Mark Kravchenko
Consultant and Designer
www.kravchenko-audio.com
mwmkravchenko is offline
post #122 of 189 Old 09-18-2010, 12:35 AM - Thread Starter
LTD02's Avatar
Quoted: 2462 Post(s)
Liked: 2782
i'm a little surprised that your driver hold up this high of c.r.
Listen. It's All Good.
LTD02 is online now
post #123 of 189 Old 09-18-2010, 05:42 AM
Liked: 27
Here is a comparison between my design and a very good design by Bill Fitzmaurice.
Tell me what you think about appropriate compression ratios. I'll tell you that an appropriate compression ratio begins at 1:4 and yes it is very driver dependant. As it is location dependant. A 4:1 compression ratio is hard on a driver in Pro sound applications. At home the driver will hardly be worked out when you average peaks to steady state volume.
Have you looked at a TRIO12 inorder to comment on the integrity of the cone?
Mark
Mark Kravchenko
post #124 of 189 Old 09-18-2010, 12:54 PM - Thread Starter
LTD02's Avatar
Liked: 2782
is there a rule of thumb that relates the limit of compression ratios, excursion, power, etc.? i.e. do you happen to know what aspect of high compression ratios it is that destroys drivers?
LTD02 is online now
post #125 of 189 Old 09-18-2010, 12:56 PM - Thread Starter
LTD02's Avatar
Liked: 2782
"Have you looked at a TRIO12 inorder to comment on the integrity of the cone?"
i have not.
LTD02 is online now
post #126 of 189 Old 09-18-2010, 02:32 PM
Liked: 27
Back from working on my barn. Little barn but still needs to be built!
It's a black art!
Well short story I try to keep things less then 5:1. If you go with a much greater compression ratio you end up putting enormous stress on the driver.
That said you have to pick a driver with a cone that can take the pressure of a horn in the first place. Musical instrument drivers are usuallu light cones that will not like horn loading. So you are looking for a driver with a decent moving mass and a demonstrably heavy enough cone to take the beats!
The TRIO12 is a great driver in this regard. There are quite a few other drivers that will work. The problem is that the combination of high X-max decent sensitivity and suitability to horn loading are not traits found in a great deal of 12" drivers.
i have not.
I take it you have a killer system as is?
If you don't the TRIO12 is a good driver in it's class of 12" drivers. It competes head to head with most and beats a great many of them. I've been modeling it for almost a year. And messing with it for about 8 months. Hard driver to find the equal of it I'd say.
Mark
Mark Kravchenko
post #127 of 189 Old 09-22-2010, 01:13 AM
s_carter's Avatar
Any chance I can get my build added to the list?
Sam Carter
Custom Sounds NW
Custom enclosures, service and installation of mobile electronics and home theater equipment.
Featured in CAE
My Home Page
DIY Dual 18" Sub Project (MK II)
s_carter is offline
post #128 of 189 Old 09-23-2010, 05:38 PM - Thread Starter
LTD02's Avatar
Liked: 2782
nice build. added!
LTD02 is online now
post #129 of 189 Old 09-27-2010, 01:12 AM
s_carter's Avatar
Thank you!
Sam Carter
Custom Sounds NW
Featured in CAE
My Home Page
s_carter is offline
post #130 of 189 Old 09-28-2010, 10:29 PM - Thread Starter
LTD02's Avatar
Liked: 2782
just needs a little more bracing... ;-)
LTD02 is online now
post #131 of 189 Old 11-06-2010, 03:28 AM
Theresa's Avatar
Liked: 51
My subs are two 90 liter aperiodically vented cabinets with NHT 1259s. I know that the drivers are old, I bought them between ten and fifteen years ago while the cabinets are even older, more than twenty five years old. They are powered by 300 watts to each. They really pump out the air with a boost at 20Hz. The air pressure changes dramatically and things sometimes start rattling. I don't plan on replacing them but do need to repaint the cabinets.
Theresa is offline
post #132 of 189 Old 11-06-2010, 08:35 PM
kgveteran's Avatar
Quoted: 437 Post(s)
Liked: 165
I had a set of 1259's in sealed enclosure, funny enough I use to run bridged Ashly Fet-200, about 300watts each.
Great subs...
kgveteran is offline
post #133 of 189 Old 11-22-2010, 05:16 PM - Thread Starter
LTD02's Avatar
Liked: 2782
"My subs are two 90 liter aperiodically vented cabinets with NHT 1259s."
got a build thread? i can add it to the list...
LTD02 is online now
post #134 of 189 Old 12-04-2010, 04:08 PM
s_carter's Avatar
I will be adding some bracing very soon, and it will be documented in my build log. I have already added sound deadening throughout the entire interior of the enclosure, and since doubled the power going to the subs. They just keep getting better and better.
Sam Carter
Custom Sounds NW
Featured in CAE
My Home Page
s_carter is offline
post #135 of 189 Old 12-04-2010, 04:39 PM - Thread Starter
LTD02's Avatar
Liked: 2782
LTD02 is online now
post #136 of 189 Old 01-25-2011, 05:11 PM
CZ Eddie's Avatar
Quoted: 65 Post(s)
Liked: 33
Should this "master index" be sorted by enclosure type?
sealed
vented
flh
tapped
bandpass
ib
etc
"The boom is dead, long live the bass"
CZ Eddie is offline
post #137 of 189 Old 01-25-2011, 09:00 PM - Thread Starter
LTD02's Avatar
Liked: 2782
i went back and forth on that...and no solution jumped out as the right one...so i tried to include words that will pop up if someone does a search. i'm sure the future web will have a way, but for now we are in the stone age. :-)
LTD02 is online now
post #138 of 189 Old 01-25-2011, 09:13 PM
CZ Eddie's Avatar
Quoted: 65 Post(s)
Liked: 33
I don't understand?
If you have text that indicate what each build is (sealed vs. ported, etc), then why not just list them in that order?
Do people send their build thread links to you or do you just scavenge them up?
It's your thread, you decided to make a fuss over doing it and making it a sticky. At least do it proper.
If you aren't sure what some or most of them are, then just list those as "unsorted" or something.
CZ Eddie is offline
post #139 of 189 Old 01-25-2011, 09:19 PM - Thread Starter
LTD02's Avatar
Liked: 2782
some folks wanted to sort on spl capability.
some folks wanted to sort on size.
some folks wanted to sort on drivers.
some folks wanted to sort on cost.
some folks wanted to sort on design.
there isn't a simple way to slice it, or i would have. :-) the future web will take care of all of this, but we aren't there yet.
LTD02 is online now
post #140 of 189 Old 01-26-2011, 07:57 AM
CZ Eddie's Avatar
Quoted: 65 Post(s)
Liked: 33
That sounds like it's you who's talking and not "some folks".
I searched the thread and nobody has requested anything be sorted in any manner other than alignment?
CZ Eddie is offline
post #141 of 189 Old 01-26-2011, 10:22 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5836 Post(s)
Liked: 4836
If I were to go thru all the trouble, I'd just keep it real simple. Sealed, Vented/PR, and other.
Obviously...It's up to you, LTD. Your thread, your time.
Scott Simonian is offline
post #142 of 189 Old 01-28-2011, 06:14 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
That's a no win, but it would be nice to have some criteria for indexing/sorting.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #143 of 189 Old 02-11-2011, 01:17 PM
Theresa's Avatar
Liked: 51
deleted by poster
Theresa is offline
post #144 of 189 Old 05-26-2011, 11:24 AM
mrpage's Avatar
you saved me alot of time of searching!
how much time it took to collect this list?
mrpage is offline
post #145 of 189 Old 05-26-2011, 03:06 PM - Thread Starter
LTD02's Avatar
Liked: 2782
"you saved me alot of time of searching!
how much time it took to collect this list?"
i have no idea. many people have performed a lot of work here and elsewhere that helped me out. it seemed like it would be useful resource for somebody who was new to kind of get a perspective on what others have done and why.
LTD02 is online now
post #146 of 189 Old 07-13-2011, 07:14 PM
Tankramer's Avatar
Reserved
Tankramer is offline
post #147 of 189 Old 08-19-2011, 06:04 PM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 191
None of the MFW projects made the list?
Wembley's dual opposed design was pretty nice.....
http://www.avsforum.com/avs-vb/showt...319489&page=11
NicksHitachi is offline
post #148 of 189 Old 08-20-2011, 07:43 PM - Thread Starter
LTD02's Avatar
Liked: 2782
i just haven't updated it in a while.
if you see something that should be on the list, just shoot me a pm and i'll try to get to them all.
LTD02 is online now
post #149 of 189 Old 02-08-2012, 02:42 PM
jaco pasta's Avatar
hello,
I saw this project many times and it is missing on you list
jaco pasta is offline
post #150 of 189 Old 02-13-2012, 10:31 AM
caper_1's Avatar
Liked: 26
You can add mine to the list as well: CSS TRIO12 with 2 x 12" Passive Radiators : http://www.hometheatershack.com/foru...-trio12-h.html
HT: Yamaha RX-V565 | 3 X Energy Take FPS, 2 X VS Surround, 2 X Take LCR | DIY Subs: SDX12 APR15 & TRIO12 Dual APR 12's | 47" LCD
Music: Yamaha RX-V863 | 2 X Energy RC-70 | MA RXw12 Sub
Bathroom: 2 X Energy Take LCR
Car: Sony Xplod HU, Xplod 6X9s, Kenwood 4"s, Alpine 12" Type-S, Rockford Amp,...
caper_1 is offline
