Anyone build a planar speaker? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 01-20-2009, 05:00 PM - Thread Starter
moovinfast's Avatar
Has anyone here built a Planar speaker from scratch? I was reading about building one on another site and was interested. They can be built for cheap. But they just gave general guidelines. Anyone know of a good place to look for DIY full range planar speaker plans?
moovinfast is offline
post #2 of 16 Old 01-20-2009, 05:09 PM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 458
Do you really mean planar? Such as an electrostatic speaker (like the Quad), a planar dynamic (like the Magnepans) or a ribbon? Or are you referring to a flatish speaker to mate with a flat panel display?
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #3 of 16 Old 01-20-2009, 05:15 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
It would certainly be an insteresting project if possible. I would be interested in learning the specifics of this.
I have never heard of anyone on this forum building a planar setup.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #4 of 16 Old 01-20-2009, 09:05 PM - Thread Starter
moovinfast's Avatar
I mean a flat piece of perforated metal with magnets and foil. Heres the post I was talking about.
http://www.diyaudio.com/forums/showt...threadid=95541
post #5 of 16 Old 01-21-2009, 03:43 PM
Quoted: 673 Post(s)
Liked: 458
Planar magnetodynamic.
Kal Rubinson
post #6 of 16 Old 01-21-2009, 04:19 PM
jkhome's Avatar
Quoted: 89 Post(s)
Liked: 48
Have you looked into modding the Magnepan products? It's a common practice with web support; one fellow even started a business doing it (Magnestand).
The MMGs are so cheap (especially used), I don't think you could build a diy version for the same cost. And folks are modding them to the point where the only OEM parts left are the drivers.
jkhome is offline
post #7 of 16 Old 01-22-2009, 04:14 AM - Thread Starter
moovinfast's Avatar
Good idea. Ill look and see if I can find a deal on some used ones here in WA
post #8 of 16 Old 01-22-2009, 02:22 PM - Thread Starter
moovinfast's Avatar
I wonder if my Receiver would be able to handle them. Its a Onkyo HT-R540. It says it 110w RMS at 8 ohms, but doesn't say anything about 4 ohm loads. Think Id fry it?
post #9 of 16 Old 01-22-2009, 04:12 PM
Quoted: 673 Post(s)
Liked: 458
From the manual:
You can connect speakers with an impedance of
8 ohms or higher
. If you use speakers with a lower
impedance, and use the amplifier at high volume levels
for a long period of time, the built-in protection
circuit may be activated.
It also says:
All channels: 110 watts minimum continuous power
per channel, 8 ohm loads, 2 channels
driven at 1 kHz, with a maximum total
harmonic distortion of 0.9%
Note that the rating is with only 2 channels in use and only at 1KHz (not full range) with high THD of nearly 1%.
I would think this likely to be quite inadequate for Maggies or similar.
Kal Rubinson
post #10 of 16 Old 03-30-2011, 07:45 AM
jamesbos's Avatar
I have been building full range planars for 20 years now. Starting with heavy ferrite ones, weighing over 40 kilos. I now use neos and have built several pairs. The smallest being 5 kilos bass is very tight unlike the esl 57 & 83, which sound plummy and resonant in comparison.
jamesbos is offline
post #11 of 16 Old 03-30-2011, 07:58 AM
Starkiller4299's Avatar
Jamesbos--do you jave any pictures posted up anywhere? I'd be very interested to see them!
We love overkill. -- gperkins1973
My fuse box is my HPF. -- kryptonitewhite
2x18 Ficar IB3 Infinite Baffle Manifold Install
Starkiller4299 is offline
post #12 of 16 Old 09-06-2011, 02:16 AM
jamesbos's Avatar
I have been rebuilding all my designs using 23 micron mylar A.and have reduced the width of my aluminim tape by half.This has improved the sensitivity quite a lot.I have pictures on imgur site,and videos on youtube also on diyaudio site under full range planars using neo magnets and under other forum names on the same site. I am also doing rebuilds and re-designs using ferrite magnets,reducing the weight considerably.Cutting down on the magnets by half. Still have a few more rebuilds before I start on a design for planar headphones. Wish me luck.
jamesbos is offline
post #13 of 16 Old 03-05-2012, 04:19 PM
jamesbos's Avatar
I have built a few new designs with a better foil layout similar to the epsilon layout. this increases the sensitivity significantly.
jamesbos is offline
post #14 of 16 Old 03-05-2012, 05:43 PM
MoFinWiley's Avatar
Jamesbos,
Is the trapezoid cutout to help with the break-up modes of the plastic or to help with the dipole nulls?
I must admit, I am very interested trying my hand at ones of these.
-Steve
MoFinWiley is offline
post #15 of 16 Old 09-28-2012, 02:49 AM
jamesbos's Avatar
Am in the process of rebuilding my rebuilds with the new 3 mm tape and 12 um mylar C. Ceased building the epsilon design, am now using 3 mm wide tape as is. Do not have to cut anymore alu tape in half or quarter. A lot easier for a 74 year old.smile.gif Something to do with standing waves , best to ask the experts I only build and listen, don't understand all the gobbledygook.biggrin.gif Have got another 6 to go in my living room 10.1 layout all hanging from the ceiling, they only weigh 5 kilos each. 60 x 40 cm in size. Making sure they are all in phase this time using 9 volt battery.
jamesbos is offline
post #16 of 16 Old 06-27-2016, 05:50 AM
jamesbos's Avatar
Originally Posted by jamesbos View Post
Am in the process of rebuilding my rebuilds with the new 3 mm tape and 12 um mylar C. Ceased building the epsilon design, am now using 3 mm wide tape as is. Do not have to cut anymore alu tape in half or quarter. A lot easier for a 74 year old.<img alt="smile.gif" class="bbcode_smiley" src="http://files.avsforum.com/images/smilies/smile.gif"> Something to do with standing waves , best to ask the experts I only build and listen, don't understand all the gobbledygook.<img alt="biggrin.gif" class="bbcode_smiley" src="http://files.avsforum.com/images/smilies/biggrin.gif"> Have got another 6 to go in my living room 10.1 layout all hanging from the ceiling, they only weigh 5 kilos each. 60 x 40 cm in size. Making sure they are all in phase this time using 9 volt battery.
Have reached my final design after 17 years of endeavour. Don't use mylar or polyethylene any more, too noisy. Have got rid of resonance which occurred on some songs. Very happy with final design.
jamesbos is offline
