Build something comparable to SVS PB13-Ultra? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 99 Old 02-07-2010, 03:31 PM
notslow's Avatar
I might have stumbled across something that is close to the PB13 in size and performance here:
http://www.hometheatershack.com/foru...slot-port.html
Pros, cons? Also, if I wanted to go slightly larger box (6-6.5cf) and use an AV15 is there any reason I couldn't use a slot port design instead of the PR? This would reduce cost substantially, but would there be a trade off?
notslow is offline
post #92 of 99 Old 02-07-2010, 03:55 PM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1141
Bigger cone and more Xmax from the look of the surrounds, I reckon the Tempest would easily best it.
Sure you can use an AV15, but I'd increase to port area (and the length to match) to get the port air speed lower. With 190L box, same 19" width you'd need 2.5" port height and 70cm/28" length. Assuming 1kW amp.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #93 of 99 Old 02-07-2010, 09:25 PM - Thread Starter
collin's Avatar
what frequency is this slot port tuned for?
collin is offline
post #94 of 99 Old 02-08-2010, 04:11 AM
A9X-308's Avatar
Liked: 1141
Fs 24Hz, port length ~70cm.
19Hz is 120cm.
I just ran a quick sim in Unibox.
A9X-308 is offline
post #95 of 99 Old 02-11-2010, 07:14 PM
notslow's Avatar
Does the AV15 need a bigger box than the Tempest? Which one is the better sub?
notslow is offline
post #96 of 99 Old 02-11-2010, 07:54 PM
A9X-308's Avatar
Liked: 1141
That will depend upon the tuning.
Better? In what regard?
A9X-308 is offline
post #97 of 99 Old 02-12-2010, 12:04 AM
notslow's Avatar
If I want to tune to 15hz. which one would need a bigger box? Which one would have better output, more linear frequency response?
notslow is offline
post #98 of 99 Old 02-12-2010, 03:46 AM
A9X-308's Avatar
Liked: 1141
You should get a modelling program and work that out for yourself.
A9X-308 is offline
post #99 of 99 Old 08-30-2012, 06:31 AM
alpenpoint's Avatar
Hi,
Here are so good Subwoofers in this Forum and i am also interest to build a Subwoofer who is so good or better than a SVS PB13 Ultra. Have you Tips for me?
Who has build a comparabel Subwoofer?
Alpi
alpenpoint is offline
