DIY speaker build using Waveguides...looking for advice - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 1040 Old 04-23-2009, 12:38 PM - Thread Starter
penngray's Avatar
Liked: 47
Originally Posted by zero the hero View Post
No - a tool called SPL Trace. All you do is copy the frequency curve, paste it into SPL Trace and plot the curve by clicking the mouse along the line. Then you save the file as .frd.
Same thing with the impedence curve - only you save as .zma
Sounds tough, but after 3-4 times its a piece of cake. Roman has a bunch of driver files already. Some PDFs dont allow you to copy the graph, but you can download Snag-it and copy it that way.
Seriously, it sounds more difficult than it is.
I will check it out, I use screenhunter for all my screen captures.
I will check out what Roman has, thanks!
penngray is offline
post #92 of 1040 Old 04-23-2009, 01:54 PM
catapult's Avatar
Lets just assume that Im not really into machining parts atleast not yet, I have ZERO tools or patiences for that and Im not anal enough to get it right
Im really hoping that the parts I buy will fit together.
In that case, the 18sound XT1086 is another good choice. John J. is using it in some of his smaller pro systems -- TD12M, BMS 4552, XT1086. I'd say it's either that or the DDS if you want plug 'n play (assuming DDS QC is back up to snuff).
http://www.loudspeakersplus.com/html/18sound_horns.html
Dennis H
catapult is offline
post #93 of 1040 Old 04-23-2009, 03:19 PM - Thread Starter
penngray's Avatar
Liked: 47
Yeah, that was talked about already several posts suggested the PE horns are a fraction of the price and perform just as well so I might as well save some $$$ if it really doesn't matter
The 18sound compression drivers that crossover at 1200 or lower are too expensive for this project so how do I know if other compression drivers fit on the XT1086 outside of checking online for matches?
penngray is offline
post #94 of 1040 Old 04-23-2009, 03:31 PM
noah katz's Avatar
Quoted: 1094 Post(s)
Liked: 379
Dennis,
"the 18sound XT1086 is another good choice. John J. is using it in some of his smaller pro systems -- TD12M, BMS 4552, XT1086. "
Is there any more info on that somewhere?
noah katz is offline
post #95 of 1040 Old 04-23-2009, 03:59 PM
catapult's Avatar
Penn, any bolt-on 1" compression driver should fit okay. The BMS is one of the best you can buy and costs something like $140 (I forget, call Assistance Audio.)
Noah, http://www.aespeakers.com/phpbb2/vie...php?f=3&t=1690 . He doesn't specify which 1" BMS driver but, for the few bucks difference, I'd go with the best one. Don't you have those drivers and waveguides? Time to get 'em playing, dude!
Edit: Assistance Audio also sells DDS and they'll give you a little off if you buy a 'kit' of waveguide + driver. But ask them about the current DDS QC first.
http://www.assistanceaudio.com/
Dennis H
catapult is offline
post #96 of 1040 Old 04-23-2009, 05:52 PM - Thread Starter
penngray's Avatar
Liked: 47
I emailed them, the email from the website did not work.
penngray is offline
post #97 of 1040 Old 04-23-2009, 06:18 PM - Thread Starter
penngray's Avatar
Liked: 47
I need to summarize all the different options so I do not forget.....
Waveguides/horns
DDS eng 1-90 ($69)
18sound XT1086 ($88)
Dayton H12RW ($14) (screw-on not bolt)
Selenium HM25 ($23) (screw-on not bolt)
B&C ME45 ($53)
JBL PT-95 (or 338800) ($10)
Compression drivers
BMS 4552($145)
Radian 475PB ($169)
Selenium D220 ($44) (screw on)
Selemium D2500Ti ($78) (screw on)
B&C DE250 ($151)
Tweeters that can be used if we mod the horns
Crossovers
Selenium 2V1K2/600 2-Way Passive Crossover (1200Hz) with Dish ($68)
BMS 4552 1KHz crossover from Assistance Audio ($??? part of kit)
penngray is offline
post #98 of 1040 Old 04-23-2009, 06:35 PM
2100's Avatar
Assistance Audio did not get back to me about 2 years ago too despite several emails, could only guess they deal with bigger deals for the pro users or they are out touring. So Penn, don't hold your breathe there. usspeakers is just a wee bit more expensive, but Al Katz is really responsive.
2100 is offline
post #99 of 1040 Old 04-23-2009, 06:39 PM - Thread Starter
penngray's Avatar
Liked: 47
I have purchased several drivers from US Speakers, no problem with me if they have the products. I really wanted to get the kits and discount minus the Ciare 12" woofers.
penngray is offline
post #100 of 1040 Old 04-23-2009, 06:53 PM
catapult's Avatar
Assistance is a very small company and their 'day job' is setting up the sound for concerts, etc. But they are the official US importer of BMS and also seem to have a better relationship with DDS than usspeakers (usspeakers sent those really crappy waveguides to John J.). You may have better luck contacting them by phone.
Dennis H
catapult is offline
post #101 of 1040 Old 04-23-2009, 09:07 PM - Thread Starter
penngray's Avatar
Liked: 47
Kind of a bump in the road to this projects, my TD12S choice might come back to bite me now and I always knew I should have went for the TD12Ms.
From John's website
For going up to 1KHz or so, the TDM's are going to be the best option. They use the cloth accordion surround which really has no resonance issues until above 4KHz. The foam surround on the X, H, and S models does have a resonance at 500hz and 1khz. This resonance causes a narrow dip at both frequencies. As it is a dip and not a peak it is not extremely significant, but the TDM's avoid this totally. Either way can work. If you need extra output on the low end, the TD15X will give you about 3db more overall. If not, the TD15M will be a little flatter.
I wondered about the measured dips I see in my tests when I use the TD12S above the 400Hz crossover I have always set for it.
Time to find new drivers Anyone want 3 TD12S drivers for a decent discount?
penngray is offline
post #102 of 1040 Old 04-23-2009, 09:17 PM
LTD02's Avatar
Quoted: 2524 Post(s)
Liked: 2867
4552 on xt1086
source: http://db.audioasylum.com/cgi/m.mpl?...nsound&session
Listen. It's All Good.
LTD02 is offline
post #103 of 1040 Old 04-23-2009, 09:32 PM
LTD02's Avatar
Liked: 2867
what about the $10 jbl horn from the econowave project?
http://www.audiokarma.org/forums/sho...d.php?t=150939
dr. geddes kindly measured the combo:
note: eq'd for more or less flat on-axis response.
LTD02 is offline
post #104 of 1040 Old 04-23-2009, 09:39 PM
LTD02's Avatar
Liked: 2867
they are probably just fine. like linkwitz says, sins of omission are...not so bad. also, you could always use them for the .5 woofer in some 2.5 way speakers. that would reduce cone motion significantly, which reduces distortion (of course). if you sell them, you'll kick yourself later. ;-)
LTD02 is offline
post #105 of 1040 Old 04-23-2009, 11:24 PM
noah katz's Avatar
Liked: 379
penngray,
"Time to find new drivers"
Might you be interested in a set of 3 ea 18Sound 12ND710 http://www.eighteensound.it/index.as...roduct&pid=238 , BMS4552ND, and XT1086's? All brand new.
I've got some of the 30 ppi reticulated foam to fill the waveguides, too (but it's 1/2" sheet that would need to be cut up into layers).
I got them before the Geddes kits were available, but the Nathan 10 would fit my available space a whole lot better.
post #106 of 1040 Old 04-24-2009, 12:06 AM
LTD02's Avatar
Liked: 2867
so you are scrapping your ava's/18sound/bms in favor of maelstroms/nathan's?
LTD02 is offline
post #107 of 1040 Old 04-24-2009, 12:09 AM
noah katz's Avatar
Liked: 379
That's the idea, but not if I have to take too much of a hit.
post #108 of 1040 Old 04-24-2009, 12:17 AM
LTD02's Avatar
Liked: 2867
that was 'lucky 13'. hope you aren't supersticious.
LTD02 is offline
post #109 of 1040 Old 04-24-2009, 12:49 AM
noah katz's Avatar
Liked: 379
oh *****
post #110 of 1040 Old 04-24-2009, 05:12 AM - Thread Starter
penngray's Avatar
Liked: 47
We shall see....its an intial knee jerk reaction because things seem to be coming together and then I missed something so obvious I already new the 93dB sensitivity was a little low so I was going to use two of them below the horn (maybe).
I never bought them for anything more then 40Hz to 400Hz this was just something rattling around in my head. I agree that they are still very useful just not for this specific project.
penngray is offline
post #111 of 1040 Old 04-24-2009, 05:26 AM - Thread Starter
penngray's Avatar
Liked: 47
Already mentioned in the thread but I forgot to add it to the list...where can I buy it though, only the JBL pro website? Its it the PT-F95 stuff or the 338800, the econ waveguide thread says PT-F95.
penngray is offline
post #112 of 1040 Old 04-24-2009, 05:31 AM - Thread Starter
penngray's Avatar
Liked: 47
penngray,
Maybe
Where did you get the foam too?
penngray is offline
post #113 of 1040 Old 04-24-2009, 10:57 AM
noah katz's Avatar
Liked: 379
IIRC someone in one of the diyaudio thread posted a link to an online vendor.
My plan was to
- make a plug of the inside of the horn with 2-part expanding foam
- slice that up along the axis into 1/2" thick layers
- trace the outlines on the reticulated foam
- cut out with scissors
- stack layers and sew together
post #114 of 1040 Old 04-24-2009, 11:02 AM - Thread Starter
penngray's Avatar
Liked: 47
My plan was to
What about "Felt" on the horns?
penngray is offline
post #115 of 1040 Old 04-24-2009, 02:06 PM
noah katz's Avatar
Liked: 379
Felt where/why?
But it's certainly too dense/absorptive for the waveguide cavity.
post #116 of 1040 Old 04-24-2009, 03:25 PM - Thread Starter
penngray's Avatar
Liked: 47
Felt where/why?
I didnt save the link but someone added thin felt to the horn walls in one of the DIY threads somewhere.
penngray is offline
post #117 of 1040 Old 04-24-2009, 03:36 PM - Thread Starter
penngray's Avatar
Liked: 47
Update After reading some info fromt the "Hi-End and Hi-Eff loudspeakers system" link
http://www.audiodesignguide.com/HiEff/HiEff.html
and
http://www.diyaudio.com/forums/showt...1&pagenumber=3
Goal is a 1KHz crossover 2-way design.
Waveguides/horns
DDS eng 1-90 ($69)
B&C ME45 ($53)
Compression drivers
Beyma CP380M ($190)
BMS 4552($145)
Radian 475PB ($169)
B&C DE250 ($151)
Crossovers
Here are his comments about the D220, the link shows the Harmonic Distortion is audible in the higher frequencies when played really loud...no sure I would ever get that loud though!
"Someone have suggest me a cheaper compression driver near the 50$ like the Selenium D220T used in the Econowave collaborative project but I have discarded this because the distortion level of this driver is very high (see differences).
penngray is offline
post #118 of 1040 Old 04-24-2009, 04:49 PM
noah katz's Avatar
Liked: 379
I don't think there are any 1" compression drivers that work well down to 1kHz, and you'd need a 15" woofer to match directivity at XO.
I believe the XO points that give matching directivity are 900 Hz for a 15" woofer and 1200 Hz for a 12".
post #119 of 1040 Old 04-24-2009, 05:07 PM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
DDS eng 1-90 ($69)
Where can you get them for that price? $US129 at US Speaker.
http://www.usspeaker.com/dds%20cfd-eng-1-90pro-1.htm
I'd like to grab a couple of these for a project later to test them out. Being in Oz, John J's pics showing the ones he was delivered a while back worried me. I hope the build Q has improved.
The Selenium looks more like it's breaking up to me, but I'd need to see a CSD to get a better idea. I'm not at fan at all of Ti diapragms, much preferring the mylars or sometimes, aluminium. The DE250 and CP380M are both excellent in my experience.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #120 of 1040 Old 04-24-2009, 07:22 PM - Thread Starter
penngray's Avatar
Liked: 47
Its probably a bad batch or you would read about the problems more online.
The price for the DDS was from here http://www.assistanceaudio.com/10_DDS.html
for double the price, we are getting better performance but I have to be willing to pay the price but it depends on individual goals. I suspect the D220 in my case would actually be fine.
Tonight I spent some time testing my new NAD T-175 (no hum in my system finally and I can get rid of stop gap cheater plugs but that is a different topic). AT the same time I once again moved my crossover from my TD12 up to 1200Hz then 1800Hz, eliminating my PHL1120 all together. Measurements are great and all but sometimes you have to go with what you hear and I spent 3 hours listening to the foo fighters live and then vintage AC/DC....I like it, I spent time listening from different angles too so I wasnt just in front. Maybe Im not a good critical listener but I enjoy the TD12S even above 1000Hz tonight.
With the DCX I can tweak the dips so who knows! If John @ AE would swap the TD12S for TD12Ms that would be cool, The ones for this project are still in boxes unused, untouched.
penngray is offline
