Q about routing the holes for speaker drivers... - AVS Forum
post #1 of 11 Old 04-22-2009, 08:13 AM - Thread Starter
ChaoticBliss's Avatar
When you cuts the holes for your drivers, do you make them the exact size of the inner diameter of the driver? Or do you make them a little bigger. Reason is ask is because if I make them the exact size of the inner diameter, I don't have the proper rabbeting bit size to flush mount them. So I figure I could adjust the hole size so that it works about my rabbeting bit will be the perfect size. Hope that made sense.
ChaoticBliss is offline
post #2 of 11 Old 04-22-2009, 08:22 AM
LHD21's Avatar
If you use a straight/up cut and a plunge router on some sort of jig you can dial in your flushing depth and your overall cutout diameter. Make a couple of passes at the diameter of your driver rim, until you get to the desired flush mount depth. Then reset for your cut out hole size. If your driver has a large basket you may have to do several concentric circles to get the flusmount the right width.
Originally Posted by vasyachkin
Even i, the genius, only vaguely understand what i am saying here.
LHD21 is offline
post #3 of 11 Old 04-22-2009, 09:42 AM - Thread Starter
Right now I don't have a plunge router and the only bits I have are a rabbiting bit set I borrowed from someone. So I need to cut the holes with my rotory tool (which I have a circle jig for) and then use my router for the flush mount. Problem is, I need to cut the holes a little larger than the driver basket so when I add the rabbit the driver will be flush with no gaps. So I guess my question is, can I make the hole a little larger than the driver basket or does it have to be the exact size? (The biggest rabbiting bit I have is 1/2 inch and by my calculation I need .66 inch for the driver I have).
post #4 of 11 Old 04-22-2009, 10:57 AM
djarchow's Avatar
Liked: 25
One thing to be careful of is to leave enough material for your screws or t-nuts. The more the better, especially if this is a heavy sub driver.
Dennis
djarchow is offline
post #5 of 11 Old 04-22-2009, 08:26 PM
gimpy's Avatar
I'm a little confused, but, if possible, do the flush mount rout first, then cut the hole out after you have done the flush mount.
Frank, "Still the one"
gimpy is offline
post #6 of 11 Old 04-23-2009, 07:26 AM
NJTEX's Avatar
Just test what you want to do on scrap board first so you can check if your driver can be mounted properly. I cut baffles the "normal" way and still test my set-ups on scrap wood first.
NJTEX is offline
post #7 of 11 Old 04-23-2009, 10:45 AM
stgdz's Avatar
Is it better to use this bit to make the initial flush mount depth to insert the up spiral bit into?
http://www.rockler.com/product.cfm?page=19461
Or do you just use the upspiral bit to make your flush mount depth?
http://www.rockler.com/product.cfm?p...forester%20bit
I would want the carbide 1/4" bit correct?
stgdz is offline
post #8 of 11 Old 04-23-2009, 10:54 AM
penngray's Avatar
Liked: 29
Can your driver mount on 1/2 inch?? You can cut your hole a little wider so that you could use the 1/2inch rabbit.
I measure the outside of the driver then create my hole based on the rabbits I own to create the flush mount.
penngray is offline
post #9 of 11 Old 04-23-2009, 02:52 PM - Thread Starter
Its going to be close. I think a 3/4 inch would work out better but I am having a hard time finding a a bit that will do a 3/4 inch rabbit.
post #10 of 11 Old 04-23-2009, 03:28 PM
penngray's Avatar
Liked: 29
Yep, that has been my problem too but for larger drivers, I use double baffles and then cut holes individually, the driver sits flush with the first baffle.
penngray is offline
post #11 of 11 Old 04-23-2009, 07:58 PM
dawg1161's Avatar
If you don't do it penngray's way (which the double baffle is best for your enclosure imho) make sure if you cut the hole alittle larger that your screws have something to hit and are not to close to the edge(i have made this mistake)
Use a practice piece first as that was a good tip also. Good Luck.
dawg1161 is offline
User Tag List
