curved cabinet construction? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 38 Old 04-24-2009, 08:04 AM - Thread Starter
soundemon's Avatar
Quoted: 49 Post(s)
Liked: 31
I'm in the planning stages for my next set of speakers, floorstanding MTM using usher 8945P midwoofers and Peerless HDS tweets. I'm considering going with a curved cabinet design, but looking for some resources.
Can anyone point me to threads involving curved cabinet construction?
Anyone wish to comment on merits of curved cabinets vs conventional boxes?
TIA!!!
I think we're the demons.
soundemon is offline
post #2 of 38 Old 04-24-2009, 08:13 AM
dhgilmer's Avatar
dhgilmer is offline
post #3 of 38 Old 04-24-2009, 08:36 AM
NJTEX's Avatar
That's my summer project this year too, just got a big box of RS drivers from UPS yesterday! I'm going with curved tower cabinets for looks and WAF factor because they're going in the livingroom.
Translam construction is the ideal for it's stiffness but it's also the hardest to implement. Maybe someday I'll try it if I ever want to play with high end drivers.
For this build I'll be using kerfed 3/4" MDF with maybe a 1/4" bendable ply layer on top to help even out the surface. I still need to talk to my lumberyard guys to find out if bendable ply is as stabile as MDF, if not I may try a thin 1/8" MDF lamination instead.
Good luck with your build!
NJTEX is offline
post #4 of 38 Old 04-24-2009, 08:47 AM
penngray's Avatar
Liked: 47
Originally Posted by dhgilmer View Post
Something like this maybe? http://www.zaphaudio.com/audio-speaker20a.html
Im re-doing my wall surrounds just like those to bad Zaph took the crossovers off the site for those He is getting ready to get into the business from what I heard so no more builds, no more tests
But maybe the OP is talking about the curved boxes I have seen in a couple of recent builds. People are using "Bendy ply" or something in those builds.
penngray is offline
post #5 of 38 Old 04-24-2009, 12:33 PM - Thread Starter
soundemon's Avatar
Quoted: 49 Post(s)
Liked: 31
I'm talking about speakers like this:
Te mirage OMD28:
and the B&W 803s
There seems to be 2 trains of thought for building curved:
a skeleton with X number of ply's "wrapped"
or making a cross section and stacking them up (which seems like it would be more labour intensive but also have greater ridgidity:
I've seen threads about these types of builds but can't seem to find them anymore...
post #6 of 38 Old 04-24-2009, 12:47 PM
dhgilmer's Avatar
The cross section method looks very wasteful but to each their own.
Here is a build with the recession busters that has a curved box: http://www.avsforum.com/avs-vb/showt...ight=recession
dhgilmer is offline
post #7 of 38 Old 04-24-2009, 01:25 PM
penngray's Avatar
Liked: 47
I was looking for Tsloms build! He did a great job!
penngray is offline
post #8 of 38 Old 04-24-2009, 01:30 PM
timreeves's Avatar
I was thinking about this just earlier today
the best way I could think of was a basic MDF skeleton. bendy MDF wrapped round the design then an ass load of a really high density fibreglass based filler. Possibly with the addition of lead shot to really dampen well
timreeves is offline
post #9 of 38 Old 04-24-2009, 01:39 PM
dhgilmer's Avatar
What about an mdf skeleton and put fiberglass/resin over that. Then line the inside with sound deadening material from car audio?
dhgilmer is offline
post #10 of 38 Old 04-24-2009, 02:02 PM
noah katz's Avatar
Quoted: 1107 Post(s)
Liked: 387
Google curved plywood and/or plywood cylinders
Noah
noah katz is offline
post #11 of 38 Old 04-25-2009, 08:21 PM
tsloms's Avatar
Quoted: 55 Post(s)
Liked: 61
Hey, thanks Penn. The only thing that I would change when I do it again would be to prebend the plywood using straps to gradually curve the plywood over a couple of days. Using the bag of salt over stands as I did with my Recession Buster speakers did not work adequately. Luckily the contact cement does a great job of bonding the layers of 1/4" plywood.
I plan on building some Econowave speakers with JBL 2226's using this curved method again. All of the parts should be here later next week. This DIY stuff is rather addictive.
tsloms is online now
post #12 of 38 Old 04-25-2009, 11:03 PM
spl_nut's Avatar
This is impressive work, very nice!
spl_nut is offline
post #13 of 38 Old 04-26-2009, 05:54 AM
penngray's Avatar
Liked: 47
lmao, Im working on my wave project but Im still figuring out the drivers and I have the NHT VR-3 project still to do first. The Econowave should be a great one!!
Im actually going with the MDF bending method for a couple of projects. 3/4" MDF, with cuts 5/8" deep ever Y inches for X inches. Ddegree of bend will determine X and Y inches, that is unknown to me still, I must experiment. All "Slits" made from the table saw will have loads of glue in them and I will bend around a pre-made frame so I form the correct shape. All good in theory!
Similar to what Zaph did in one of his builds and Im follow several bending MDF links I found online.
penngray is offline
post #14 of 38 Old 04-26-2009, 06:28 AM
NJTEX's Avatar
Another MDF construction variation I'm considering is bending the kerfed MDF around the formers with the Kerf side facing outward and then laminating 1/4" bendable wood on top to acheive a smooth surface for finishing. That may provide even stronger construction and the panels could even be premade over temporary formers so they are precurved for easier final assembly.
NJTEX is offline
post #15 of 38 Old 04-26-2009, 06:34 AM
cybe's Avatar
Kerfing picture, borrowed from FisherCustoms.com. The proprietor, BJ, is the reigning king of mobile-audio subwoofer enclosures to my knowledge.
cybe is offline
post #16 of 38 Old 04-26-2009, 06:42 AM
tsloms's Avatar
Quoted: 55 Post(s)
Liked: 61
The only downside I can think of to cutting these kerfs is that the curve is not smooth but instead it is a stepped curve. I like NJTEX's idea of leaving the kerf to the outside and adding the plywood over the top of it to give a smooth corner.
post #17 of 38 Old 04-26-2009, 07:18 AM
penngray's Avatar
Liked: 47
yeah, Im going to add something over my project, something thin would be applied then veneer. I didnt know it was called Kerfing, now I have a name.
I wonder if there is anything formula on line that tells me how many notches and how far apart to cut them to get a specific degree and radius of a bend.
penngray is offline
post #18 of 38 Old 04-26-2009, 07:37 AM
Erich H's Avatar
Quoted: 1495 Post(s)
Liked: 1907
If you used that method, would the outside "curve" be smooth enough to glue the plywood to? I would think each part of the curve would be too square to get a good flat seating.
I have seen a company somewhere that makes very large MDF round corners. They're totally solid pieces too. They have notches cut into the sides to glue in your 3/4" or 1" mdf panels and get a nice flush finish.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #19 of 38 Old 04-26-2009, 08:16 AM
penngray's Avatar
Liked: 47
I pretty sure You would get enough surface area to get a good enough bond, you do not need 100% coverage for wood glue to have a very, very strong bond especially since its also sealing against a flat surface that is probably +6" on the back and +12" on each side sides...thats a lot of flat adhesion. This is my case...Im curving the wood all the way around
Im going to first see how the MDF looks itself and maybe just a little sanding is needed to smooth it out.
penngray is offline
post #20 of 38 Old 04-26-2009, 09:40 AM
tsloms's Avatar
Quoted: 55 Post(s)
Liked: 61
+1
I think it would be plenty strong as well. Maybe just add a little extra glue around the corners to fill in the small gaps.
post #21 of 38 Old 04-26-2009, 09:51 AM
Hot Grits's Avatar
Bendable ply comes in 3/8". 2 layers will give you 3/4". I use it for radius walls and staircases once in awhile. They call it wiggleboard around here. Should be perfect for an enclosure.
Hot Grits is offline
post #22 of 38 Old 04-26-2009, 10:37 AM
John_E_Janowitz's Avatar
Quoted: 26 Post(s)
Liked: 81
Anderson International Trading has all kinds of curved plywood and mdf pieces. They have Neatform flexible MDF and some other flexible plywood as well.
The nice thing about stacking the layers is that you can build the bracing into various pieces. You can also have varying wall thickness throughout the enclosure and also include the bracing into random layers. It allows you to also get close approximations to 3d shapes that you can then work with.
pics are too big so i'll just put the links in:
http://www.aespeakers.com/pics/spy/PICT0321.JPG
http://www.aespeakers.com/pics/spy/PICT0326.JPG
http://www.aespeakers.com/pics/spy/stackproto8.jpg
John
John E. Janowitz
Acoustic Elegance, LLC
"Learn from the mistakes of others... you can't possibly live long enough to make them all yourself"
John_E_Janowitz is offline
post #23 of 38 Old 04-26-2009, 11:08 AM
seagul's Avatar
I tried stacking with my tc-1000 build which is still in progress. Ill post some pics. The advantages I found are that you can determine the thickness of your walls, its more rigid, and you can add bracing that becomes part of the enclosure. On the down side you wast a crazy amount of material and for me it took forever. I don't have a router so I had to do it all with a jig saw and then sand it smooth. It looks great but if I had to do it again I would find another way.
seagul is offline
post #24 of 38 Old 04-26-2009, 11:09 AM
seagul's Avatar
Of course I still need to add stain and a front baffle which I am going to make piano black. However, I am thinking of moving up in drivers so I may never do those things at all.
seagul is offline
post #25 of 38 Old 04-26-2009, 11:16 AM
penngray's Avatar
Liked: 47
Does HD or Loews have that stuff?
penngray is offline
post #26 of 38 Old 04-26-2009, 12:07 PM
Hot Grits's Avatar
Around here they dont. Lumberyard will definitely carry it.
post #27 of 38 Old 04-26-2009, 12:11 PM
penngray's Avatar
Liked: 47
Thanks, I will contact my construction buddy on Monday to get a hold of some.
penngray is offline
post #28 of 38 Old 04-26-2009, 12:26 PM
Hot Grits's Avatar
They also make pre-kerfed MDF. That is definitely a lumberyard item also.
post #29 of 38 Old 04-26-2009, 12:31 PM
penngray's Avatar
Liked: 47
Like John posted above
http://www.aitwood.com/StoreFront.As...%20Bendy%20MDF
Cool site, they even have 12 ply drum shells....hmmm, sonotube options!!
and more Veneer (good price!!)
penngray is offline
post #30 of 38 Old 04-26-2009, 12:34 PM
Hot Grits's Avatar
I just skimmed the thread. I see he posted that already.
