DIY HT Design Coax or Seperate Mid/High? - Page 9 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Coaxial Mid/High or Seperate Mid/Hi?
Coaxial 0 0%
Seperate Midrange/Tweeter/CD 0 0%
Voters: 0. You may not vote on this poll
post #241 of 265 Old 08-12-2009, 06:53 PM
penngray's Avatar
Liked: 43
Originally Posted by dlneubec View Post
The one they used is not in the poll that Mayhem posted, so how is the one that is "good enough"?
THe poll is misleading It didnt have the actually model number and most will think its was the 8CXT. People have to read down the thread to find that out
penngray is offline
post #242 of 265 Old 08-12-2009, 06:55 PM
penngray's Avatar
Liked: 43
So everyone is so enamored with using a B&C, any B&C, that they will take the inferior one that Seaton rejected rather than consider anything else. Geesh, this is unreal!
Hey, I thought it was unreal when the polls concluded..... down to 60Hz, 115dB requirements, baffle 12" wide, bookshelf, $750 total.
penngray is offline
post #243 of 265 Old 08-12-2009, 06:55 PM
mjg100's Avatar
No. If the 8CXT was a choice I would have picked it.
mjg100 is offline
post #244 of 265 Old 08-12-2009, 06:59 PM
augerpro's Avatar
Quoted: 99 Post(s)
Liked: 61
I thought I was voting for the 8CXT...sort of skimmed the first post :/ If I had to choose only one of those posted I would lean towards the 18 Sound and maybe the PAudio. But it's entirely possible the performance of those two would be poor enough that I would scratch the whole idea. Of course the 8CXT could look at that way to after I get done testing...but I have a little more faith since it's been used in successful commercial designs from people that I respect.
augerpro is offline
post #245 of 265 Old 08-12-2009, 07:36 PM - Thread Starter
mayhem13's Avatar
Quoted: 44 Post(s)
Liked: 29
God Forbid....we have to READ! That's simply unamerican.
mayhem13 is offline
post #246 of 265 Old 08-12-2009, 07:38 PM - Thread Starter
mayhem13's Avatar
Quoted: 44 Post(s)
Liked: 29
And then b@#tched at me when we had to use PylePro woofers to finish it...NO THANK YOU!
mayhem13 is offline
post #247 of 265 Old 08-12-2009, 07:42 PM
penngray's Avatar
Liked: 43
good thing Im Canadian then
penngray is offline
post #248 of 265 Old 08-12-2009, 07:47 PM - Thread Starter
mayhem13's Avatar
Quoted: 44 Post(s)
Liked: 29
Can we not post here anymore..it's getting confusing. Please post all following gripes, moans and complaints to the Poll thread. Thank you for your support.
mayhem13 is offline
post #249 of 265 Old 08-12-2009, 07:53 PM
LTD02's Avatar
Quoted: 2345 Post(s)
Liked: 2584
canadians and americans have long cherished the same values. i can't imagine closer allies.
now, quebec city, that's a whole 'nother story. ;-)
Listen. It's All Good.
LTD02 is offline
post #250 of 265 Old 08-12-2009, 07:55 PM
penngray's Avatar
Liked: 43
What kind of controlling........
penngray is offline
post #251 of 265 Old 08-12-2009, 08:00 PM
LTD02's Avatar
Liked: 2584
what happened to the stupid bms coax that i posted?
http://www.bmspro.info/12CN680.bms_1...nsducer.0.html
how is this better than the econowave over a td12-h?
?consufed
LTD02 is offline
post #252 of 265 Old 08-12-2009, 08:13 PM
mjg100's Avatar
I actually am interested in your idea of using the Eminence Beta-8cx/CD and a pair of Nomex 8's. It would take some testing of various CD's. What is the sesitivity of a pair of Nomex 8's?
mjg100 is offline
post #253 of 265 Old 08-12-2009, 11:01 PM
Quoted: 921 Post(s)
Liked: 491
Before you dismiss drivers out of hand, shouldn't you at least ask Danley and/or Seaton whether they tested the P.Audio, BMS, Eminence or other 8" coaxes and if so why they chose the B&C instead? Wouldn't it be a good idea to be sure TD will do the design work before making further decisions?
For that matter, why are we just looking at 8" coaxes? Why does it have to be a three-way? Why not just a good compact monitor with a 10" or 12" coax? That seems more appropriate for HT anyway, because one can put the smaller boxes at the same elevation over an LCD and locate the bass units remotely. (I know lots run projectors, but big LCD's way outsell projectors, and are more useful in multi-use rooms anyway)
A bespoke 12" coax with the small/cheap BMS compression driver and a Danley crossover sounds like a speaker I'd want in my flat.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #254 of 265 Old 08-12-2009, 11:31 PM
zamboniman's Avatar
I can think of all kinds of places I could use a coax based 2 way (8,10,or12)
Like my living room, surrounds in my theater, and some jammin speaks for the garage to rock the neighborhood with..
I could see building a whole army of em
zamboniman is offline
post #255 of 265 Old 08-13-2009, 12:35 AM
A9X-308's Avatar
Quoted: 1326 Post(s)
Liked: 990
Originally Posted by ZilchLab View Post
A couple of years ago, the P-Audios were considered the "bee's knees" of co-axials.
Somebody's going to have to buy a pair and measure....
I have 4 BM8CXA, 1 SN12C, 1 BM15CXHB and 2 BM15CX38 all new. But it will be a couple of weeks before I can get back to the workshop and test them.
A9X-308 is offline
post #256 of 265 Old 08-13-2009, 12:53 AM
Quoted: 921 Post(s)
Liked: 491
Exactly. A simple 2-way coax is just about the most placement-friendly speaker one can design. I say keep the mains simple, i.e. one coax driver of preferably 10" or 12", and let people add whatever they want below that. As long as it has high efficiency and plays into the modal range (say, an F3 of anywhere from 60-100 Hz) I'm fine with the low end.
Serious Audio Blog
DS-21 is offline
post #257 of 265 Old 08-13-2009, 05:24 AM
mjg100's Avatar
Guys, I agree with this 100%. Please move these posts over to the other thread to make sure that Mayhem13 sees them. I was thinking of just using an 8" though to keep it even smaller. Basically a passive "Sparks". The Sparks will go loud and down to around 70Hz. The small size will allow it to go just about anywhere.
mjg100 is offline
post #258 of 265 Old 08-13-2009, 07:28 AM
penngray's Avatar
Liked: 43
You are forgetting that one of the polls that Mayham has to follow is that this is a 3-way design!
penngray is offline
post #259 of 265 Old 08-13-2009, 07:29 AM
penngray's Avatar
Liked: 43
Many pre-existing rules from poll results exist.
penngray is offline
post #260 of 265 Old 08-13-2009, 07:39 AM
augerpro's Avatar
Quoted: 99 Post(s)
Liked: 61
I think that BMS 12" coax was cool. The only issues I have are that I doubt it will fit on a 12" baffle-and I have this issue for using the 12" woofers for bass too. And there is no polars to guage it's cone/horn performance. Although they usually look worst on axis and this looks pretty good so maybe not a problem. A last concern is this looks like a mid woofer and requires some midbass/bass reinforcement if I remember the plots correctly.
augerpro is offline
post #261 of 265 Old 08-13-2009, 10:15 AM
Mark Seaton's Avatar
Quoted: 508 Post(s)
Liked: 1319
Wow. Some crazy speculation going on in all directions. One minor point I would add is that as manufacturers both Danley Sound Labs and myself have to make choices based on more than just performance. If performance is comparable, and one supplier is much easier to deal with and has a much better history of delivery or other factors, that's highly important to a business. There were some parts I wrote off simply because supply was still too flaky to hedge my business on.
It is possible to make a few different solutions work impressively so long as they don't have any fatal flaws and are compatible with the goals you have.
DIYers may have different goals than I or Tom did. As one very obvious/simple example I needed a coaxial which would give good results in both the Spark and the Catalyst style designs. Capabilities of the woofers also play a part and the requirements will vary for different designs.
The best results always come from examining a few options to confirm you have a suitable driver for your particular use.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is online now
post #262 of 265 Old 08-13-2009, 11:05 AM
augerpro's Avatar
Quoted: 99 Post(s)
Liked: 61
Mark considering their use here, how would you compare the 8CX21, 8CXT and 18 Sound 8CX400?
augerpro is offline
post #263 of 265 Old 08-13-2009, 11:43 AM
Quoted: 921 Post(s)
Liked: 491
Maybe there should be a new poll: should these speakers be hamstrung by the results of older polls, yes or no.
A baffle for a 12" coax should probably be ~20" wide, to account for the roundover required to make a difference in terms of diffraction. Then again, an 8" coax requires a baffle of about 14" wide.
At any conceivable listening level, unless one's room is really a 150-seat auditorium, the excursion levels are going to be so low with three 12" coaxes across the front that treble modulation and other nasties that can afflict coaxes just aren't an issue. I'm able to run my three Tannoy 12 DMT II-based mains full range (supported by multiple subwoofers, of course), whereas when I was running 8" coaxes up front a highpass filter was required to avoid nastiness on fff passages.
Serious Audio Blog
DS-21 is offline
post #264 of 265 Old 08-13-2009, 12:39 PM
augerpro's Avatar
Quoted: 99 Post(s)
Liked: 61
My point was that this BMS coax appears to require bass/midbass reinforcement-it really is a mid. I don't know if an additional 12" woofer would fit in the budget and two 8" woofers would look kind of funny. Although for some creative types you could probably make some artistic look out of the weird dimensions.
augerpro is offline
post #265 of 265 Old 12-15-2011, 01:58 PM
majestik6's Avatar
Originally Posted by findbuddha View Post
Earl Gedlee has suggested that PAudio's specs are fiction. Though some people have had success with their drivers. I think there's a coax user on DIYaudio
I have both Geddes speakers and P-Audio speakers in my listening room. My Summas use the B&C 15TBX100 and my TH-Mini 'clone'* uses the P-Audio SN-12MB. The P-Audio woofer is a nice unit. It won't handle the power that the B&C will, but it is also cheaper. The build quality is excellent and the specs aren't any further off from the published numbers than what I've seen from most manufacturers. (IE, you need to measure you're drivers anyways if you're gonna DIY. It's a must.)
Not saying P-Audio is as good as B&C, but it's definitely a step up from companies like Goldwood. In some respects it's superior to midrange stuff like Eminence. I'm surprised more people don't use them.
majestik6 is offline
