QSC SC-2150 Clone - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #181 of 220 Old 01-11-2010, 12:11 PM - Thread Starter
chucky08016's Avatar
I just tried a receiver for the very first time on my speakers and it shut down at reference levels. I had to run it at -7 db's from reference for it to stay on. It did sound pretty good and I was not using my subs, just my speakers on full range. I can say this, my speakers do a really good job by themselves to 25 hz. I am trying different things with these speakers(amps and processor). All I know is that I want HD audio for sure and Audyssey did sound good at every seat. My speakers are 4 ohms but very sensitive so I am not sure what the clones are?
In passive mode, they are 4 ohm. BTW... which receiver did you try? I'm using a Sony STR-DG1000 (120 x7) and it has yet to shutdown on me at any level. Then again, I've only tested short clips (5 to 15 minutes) at very high levels.
chucky08016 is offline
post #182 of 220 Old 01-11-2010, 12:44 PM
MKtheater's Avatar
Quoted: 1588 Post(s)
Liked: 1116
I am testing the denon 2310. I ran The Dark Night and as soon as the window blew out in the very beginning it turned off. I am running passive mode right now but soon I will be biamping which will make the system go from 101 db's sensitive to 105 db's.
Marantz 7702 Atmos
MKtheater is online now
post #183 of 220 Old 02-19-2010, 11:24 AM
saddlesore's Avatar
Chucky - what did you use for dampening material in your SC-2150's? I've been lost in on-line damping discussions. Is there a reason you didn't use polyfill or the damping materials from PE? Do you know what QSC uses for dampening?
Thanks again
saddlesore is offline
post #184 of 220 Old 02-19-2010, 11:58 AM - Thread Starter
Thanks again
No idea what QSC uses. I just used fiberglass insulation and lined all inner walls.
post #185 of 220 Old 02-19-2010, 06:11 PM
penngray's Avatar
Liked: 43
Thanks again
I used carpet padding on the walls. I see zero reason to spend money on even the PE stuff.
penngray is offline
post #186 of 220 Old 02-21-2010, 12:56 PM
swnewell's Avatar
Nice looking project. I have been pondering the QSC HPR153i's for awhile now, but the cost factor and aesthetics kept me from going further than just looking.
I think I read that penngray is planning to build a clone and I await his build thread. I have attached a poor quality concept of what I am thinking based on reading many of the waveguide threads.
swnewell is offline
post #187 of 220 Old 02-21-2010, 06:09 PM
stgdz's Avatar
The 153's require a different crossover and I don't think you can use the standard 2150 crossover in a WTMW configuration.
stgdz is offline
post #188 of 220 Old 02-22-2010, 07:09 AM
penngray's Avatar
Liked: 43
I have the waveguide, CD and mid range woofer for it. I alos have some other woofers lying around but I have almost zero time these days to get into the garage
I just started measuring the 152i clone.
btw, what are you considering that HPR-153 over the HPR-152?
penngray is offline
post #189 of 220 Old 02-22-2010, 01:31 PM
swnewell's Avatar
While the HPR-152 seems to be the more common build, I like the idea of a single driver covering the dialog/vocal range. Chucky's build of the SC-2150 looks pretty cool - but I lack a AT screen so the aesthetics of speakers is more of a concern (WAF).
Looks like a design based on the SC-2150 but with a more traditional bass cabinet may be the ticket, instead of the active HPR-153. Then I could use the SC-2150 crossover instead of trying to measure and figure out my own (I am NOT proficient at mathematics and/or crossover design [I dropped out of engineering school and went microbiology instead]). Thinking I would go open baffle (2x thickness baltic birch) for the horn assembly. I believe I would need to keep the same drivers, crossover, and volume/porting of the bass cabinet as in the SC-215. Passive seems to be a cheaper option than buying the active amplifier module for the HPR-153 (Part No. WP-153001-00, $462.35/ea).
After reading more info (all day yesterday) seems like I may not need a center channel. However, the thread you have and the one by Augerpro suggest that the HPR-152 may be more than sufficient. Looking for mains that don't suck compared to my Mal-X subwoofer (based on NeoDan's 24" sealed)
If I go any further I will start my own thread - I would hate to hijack this thread as I want to see where it leads.
SWN
swnewell is offline
post #190 of 220 Old 02-22-2010, 01:33 PM
penngray's Avatar
Liked: 43
SWN
start your own thread but I would say the dialog/vocal range, goes lower then you think and those mid-range choices in the 3-way isnt good enough in my books. a two way with a might woofer handling all the way up to 1500 is key (IMO).
I would really love a horn that handles 600Hz to 15KHz!!!
penngray is offline
post #191 of 220 Old 02-22-2010, 01:48 PM
MKtheater's Avatar
Liked: 1116
This compression driver will do 630 hz-19 khz
with this waveguide
Marantz 7702 Atmos
post #192 of 220 Old 02-22-2010, 03:15 PM
penngray's Avatar
Liked: 43
MK, I wonder what the "real" performance is down that low. Im not sold on what any spec sheet says.
penngray is offline
post #193 of 220 Old 02-22-2010, 03:20 PM
MKtheater's Avatar
Liked: 1116
JBL uses electronic crossovers for their triamped version at 630 hz and the biamped version gets a passive crossover at 800hz(What I am using).
Marantz 7702 Atmos
post #194 of 220 Old 05-06-2010, 02:26 PM - Thread Starter
Hi All,
Here's a link to another SC-2150 clone build in Canada. He's using a different woofer for his build.
http://www.canuckaudiomart.com/forum...ic.php?t=15921
post #195 of 220 Old 12-07-2010, 11:58 AM
AudioJosh's Avatar
Quoted: 246 Post(s)
Liked: 225
Just rediscovered this thread. Don't know if this is apporpriate or not but I have a pair of the SC-2150 waveguides, pair of the CDs, a pair of the woofers and a quad of the mounting brackets. I bought them to experiment but had no time. I know QSC isn't selling parts anymore so if anyone is interested, drop me a line.
JoshK on most other audio forums
Quantity only when quality is ensured.
AudioJosh is online now
post #196 of 220 Old 09-12-2011, 09:33 PM
tomlang's Avatar
I aquired a pair of these waveguides. From the pictures of the crossovers, I almost have a schematic drawn.
Before I go any further, did anyone trace the crossover circuit from the board and draw a schematic?
tomlang is offline
post #197 of 220 Old 06-08-2012, 10:17 PM
Vic C's Avatar
WOW I just want to say thanks for this post....I just stummbled upon it.....
I have recently been RE-Motivated about getting my Speaker line going by some industry affiliates that have listened to my theater and not relising that what they were listening to were MY custom built speakers
Also haveing a contractor friend come check out my new theater and being blown away while we were working out the details to a custom theater I wired about 3 years ago as the room is getting close finally to having me make it "sing"
As the AV Industry is changing Ive been toying with the idea of producing speakers as another division of my company and the more I read and see whats going on in the industry and the more positive feedback I get the more I see the need to get this going.
Its also the guys on here that Im seeing are discovering things I have discovered a long time ago and said hmmmm? what if I was to offer something like that to my customers? I only know of one other company that is producing products based on the professional world and from what I see there is a market for it. What I do know atleast where I am conducting business there is no one that even knows, let alone attemps some of the technics that I have been utilizing for years in Home Theater.....
So although my reply has nothing to do with your system other then me saying..... HOLY "S" youve done some incredible work there! I wanted to say thanks for sharing this experience as again it motivates me just that much more to get a move on with it!
Vic C is offline
post #198 of 220 Old 06-09-2012, 01:14 PM
dbldare's Avatar
Vic,
I checked out your website and I don't see much detail on your theater. Can you please post some more details, images and frequency graphs?
dbl
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
post #199 of 220 Old 06-29-2012, 01:01 AM
Vic C's Avatar
I will take smore pics....Im working on a revamp ov my website and its tottally down right this minute. They say it will take a few hours for it to come back up.....I dont know what I did.
I dont know how I can get freguency graphs other then taking pics of my sofware RTA while in action......
Not sure if thats what your looking for but Ill give you more info if you looking for specfics.'
Vic
Vic C is offline
post #200 of 220 Old 06-29-2012, 01:21 AM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
Vic
Vic, if your S/W won't allow you to save images directly, use a print screen app like Gadwin Print Screen and crop and save it using a free graphics program. Then post it.
A9X-308 is offline
post #201 of 220 Old 06-30-2012, 02:34 PM
Vic C's Avatar
Heres some snapshots I was able to extract from a video I recored from listening to some Diana Krall and an instrumental at 0db ref level....
Sounds very clean WOW and one one of my 12 year old towers is starting to show its age. At low volume there is very early signs of voice coil deformation. The coil(s) arent rubbing but there is some very low distortion that sounds like the magnet gaps are not 100% even any more. and at low volume its audible to the trained ear. Other wise the speaker sounds fine at normal levels even lower then reference. Ive driven my towers during testing to points beyond their ratings and they have done extreamly well. For 12 year old prototypes. Im more then happy with them. Ill have new 2012 models complete soon and will replace these guys.
But heres the pics extracted fom realtime video. The Blue " peak" Shadow you can see in pic 3 of the RTA is hitting right at 85DB....Im using a standard Audyssey Mic plugged into my laptop.....If its good enough for Audyssey it should be close enough to get a decant basic readings.
I uploaded the video to my companies facebook site as it was too big for AVS or something so I linked it here
209209209
450
250
120
Vic C is offline
post #202 of 220 Old 07-29-2012, 09:33 PM
rlhaudio's Avatar
Quoted: 295 Post(s)
Liked: 83
I was able to locate all the parts needed to buld a 2150 clone as you did. How did you locate the internal parts list? I can copy and paste your parts, add to cart and purchase but I was thinking of DIY a smaller speaker, maybe the SC 312 or SC 412 but I cant locate which woofer, crossover, or wave guide it uses to build a clone. HELP!! Thank you..
Marantz 7702mk2, Panasonic 8000 w/ 130" AT Screen HTPC w/30 tb
DIY QSC SC-2150 L,C,R (10) QSC SR-8101 sides, rears & atmos/dst-x
DIY (4) Fusion Tempest
DIY (2) UM 15 "Sub's (4) SI 18's (2) PA460 mbm
Dayton Titanic MK4 & B&W ASW 855 both subs for sale
rlhaudio is offline
post #203 of 220 Old 11-20-2012, 09:16 PM
Looneybomber's Avatar
Liked: 25
I realize this is a crazy old thread, but it looks like PE has the SC-2150 woofers on buy-out for 58.47/ea if you buy four or more. I still have 3 of these waveguides for yet another build that never took off, but I just can see spending $360 on woofers that will just sit boxed up in the garage forever. If anyone is on the fence, or wants to complete theirs, the site/link listed on in the first post has them priced at about twice what PE does.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=299-418
YID DIY
Looneybomber is offline
post #204 of 220 Old 11-20-2012, 09:29 PM - Thread Starter
Hi Looneybomber,
Although they look the same, the woofers are different models. Look at the first page of the thread and you'll that the motor is much smaller on the PE buyouts. They also model differently.
http://celestion.com/product/97/tf1530/
With that said, they could work very well in the same application all the while saving roughly 50% in cost. I think they're a good buy.
post #205 of 220 Old 11-20-2012, 09:31 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1768
I think those PE woofer buyouts were designed for a Trace Elliot guitar style speaker.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #206 of 220 Old 11-21-2012, 07:23 AM
Liked: 25
Originally Posted by chucky08016 View Post
Hi Looneybomber,
Well disregard my post. I saw TE-BS-15300 on the the factory sticker, so I thought it was the 1530 model. I won't be buying any though, I have too many other projects to finish first.
YID DIY
post #207 of 220 Old 12-11-2012, 07:17 PM
Tony_Montana's Avatar
Quoted: 45 Post(s)
hello,
did you use any other subs except the dayton 12" ?
Tony_Montana is offline
post #208 of 220 Old 12-21-2012, 11:54 AM - Thread Starter
Originally Posted by Tony_Montana View Post
hello,
did you used any other subs except the dayton 12" ?
Yup, Mach 5 Audio had a promotion on 18's last year that were named the XMASS 18. I picked up 4 of them and use then in sealed enclosures powered by Behringer iNuke amps. These were budget 18" subs that have fantastic low end capabilities.
post #209 of 220 Old 08-29-2014, 02:51 PM
cdy2179's Avatar
Quoted: 731 Post(s)
Liked: 424
I just wanted to add my 2 cents. I have 5 new 2150s that I found a great deal on. I just sold my house and we are soon to begin building the new one. At the moment i'm only testing these in two channel. I've owned the 3677 and I absolutely love the speaker but these were just too great a deal to pass up.
These are beasts and like the 3677 have taken a while to break in. They really need to be behind a screen and in a baffle wall. My current room isn't setup well enough to really see what they can do but they'll soon be setup with the help of QSC as I called and got tons of installation tips from and I'll be setting them up per their advice.
As for the question about QSC stuffing. They take about 20x20 piece of insulation like r13 and staple in right around the driver but it almost surrounds the basket...arches toward the basket. The enclosure is built like a tank, quite a bit better than the JBL enclosure I must say. Althought he JBL was adequate, yet the JBL insulation that lined their cabinet was very thin, of course I upgraded it in my 3677s.
cdy2179 is online now
post #210 of 220 Old 09-18-2014, 07:54 AM
123viktor's Avatar
Hi
Does anybody have the user manual for the qsc 2150?
123viktor is offline
