Line array - AVS Forum | Home Theater Discussions And Reviews
post #1 of 109 Old 09-06-2009, 01:07 PM - Thread Starter
kgveteran's Avatar
Quoted: 363 Post(s)
Liked: 130
Is it possible to use full range drivers and avoid a XO ?
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is online now
post #2 of 109 Old 09-06-2009, 01:33 PM
SteveCallas's Avatar
Quoted: 141 Post(s)
Liked: 56
You wouldn't need a crossover, but you would need passive EQ if you want a flat FR, as I don't know of any single driver that can cover say 80hz - 20khz +/3db.
A line array of coax drivers could be interesting.
SteveCallas is online now
post #3 of 109 Old 09-06-2009, 01:35 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
there may be some very high efficiency drivers that can play up toward 10khz and play some bass. lowther, maybe a few others?
Listen. It's All Good.
LTD02 is offline
post #4 of 109 Old 09-06-2009, 04:21 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1771
Just out of curiosity, I know using more than one tweeter is considered bad for most speakers. But why isn't it an issue with line arrays? If it is an issue, would a narrow cabinet with an almost circular shaped baffle help out?
_______________________
The SEOS Waveguide Project
Erich H is offline
post #5 of 109 Old 09-06-2009, 05:10 PM
tvrgeek's Avatar
Quoted: 17 Post(s)
Liked: 33
You might visit the forums on the WEB for full range drivers. Quite a following. I believe the attraction is that your brain is very good at adjusting frequency response, but does not like all the time/phase nasties in multi-way systems.
My personal feeling is that line arrays are a very good tool for certain sound reinforcement problems, but not the best for living rooms.
tvrgeek is offline
post #6 of 109 Old 09-06-2009, 05:27 PM
Looneybomber's Avatar
Liked: 25
The downside to a line array of full range drivers is the center to center spacing issue. Using 4" drivers, that'd start becoming problematic at around 3300hz.
Check out PE. They have a box of 200 tweeters for 10 bucks! I want to buy a box just for the hell of it.
YID DIY
Looneybomber is offline
post #7 of 109 Old 09-06-2009, 05:36 PM
tvrgeek's Avatar
Quoted: 17 Post(s)
Liked: 33
I always wondered what 100 or so of them as a panel would work like. Say a 5 x 20 array?
tvrgeek is offline
post #8 of 109 Old 09-06-2009, 05:50 PM - Thread Starter
kgveteran's Avatar
Quoted: 363 Post(s)
Liked: 130
Yes, this would be for my living room. I could live with 14khz top end. I would ues a pair of PE kit 15" subs XO@100hz via the subs xo.
Mostly for MP3 files from my computer, party music.
Would a 1/3rd octave EQ help what ever space issues of the 4" would cause. I like the lack of a XO myself.
I would like (16) 4" full range in a very narrow cabinet. Cool project.
What are spacing issues ?
KG
post #9 of 109 Old 09-06-2009, 05:51 PM - Thread Starter
kgveteran's Avatar
Quoted: 363 Post(s)
Liked: 130
Would a line array of cheap coax drivers work ??
post #10 of 109 Old 09-06-2009, 06:01 PM
tvrgeek's Avatar
Quoted: 17 Post(s)
Liked: 33
Look in past issues of Speaker Builder. There were projects not dissimilar to this. One of the ideas was to vary how they were wired to reduce output progressively to the top and bottom. Some have tried curved baffles to reduce the deviation from driver to listener. I have some built in a helix. I have seen even driver spacing, and odd driver spacing.
I still think building a very good 2 way monitor with electronic crossover will be a far better system for a living room for less cost. My bias.
tvrgeek is offline
post #11 of 109 Old 09-06-2009, 06:03 PM
Liked: 25
Comb filtering.
YID DIY
post #12 of 109 Old 09-06-2009, 06:37 PM
mayhem13's Avatar
Quoted: 43 Post(s)
On the cheap, take a look at these Kg....
http://www.parts-express.com/pe/show...number=299-271
These would need a pair of 8's or 10's on the bottom for 150hz on down....kinda what McIntosh does on their array speakers. Functional as a stable base for an otherwise top-heavy design. BTW PE has some buyout 10's that Erich turned me onto this morning......
http://www.parts-express.com/pe/show...number=299-245
Most line array builders overcome the effect of comb filtering by power tapering the wiring.
Hey KG, hows about takin a crack at an AVS Line Array project!
mayhem13 is offline
post #13 of 109 Old 09-06-2009, 07:05 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
http://www.audience-av.com/parts/A3.php Response is flat from 40hz-22khz.
gpmbc is online now
post #14 of 109 Old 09-06-2009, 07:17 PM
penngray's Avatar
Liked: 43
I like that driver! Nice find.
penngray is offline
post #15 of 109 Old 09-06-2009, 07:23 PM
vasyachkin's Avatar
very good question. fortunately i am a genius so i can answer it.
2 tweeters are bad because it can be avoided.
in line array it can't be avoided therefore its OK.
makes sense ?
for example work is bad because we dont like to work.
but we have to work therefore work is good.
got it ?
vasyachkin is offline
post #16 of 109 Old 09-06-2009, 07:26 PM - Thread Starter
kgveteran's Avatar
Quoted: 363 Post(s)
Liked: 130
Power tapering the wiring ? I'll google it in the mean time.
post #17 of 109 Old 09-06-2009, 11:13 PM
Erich H's Avatar
Liked: 1771
http://www.greenie512.net/greenie512..._tapering.html
Erich H is offline
post #18 of 109 Old 09-07-2009, 05:47 AM
tvrgeek's Avatar
Quoted: 17 Post(s)
Liked: 33
Also look at Zaletron
tvrgeek is offline
post #19 of 109 Old 09-07-2009, 09:05 AM
mayhem13's Avatar
Quoted: 43 Post(s)
Great Link Erich!
mayhem13 is offline
post #20 of 109 Old 09-07-2009, 09:18 AM
Erich H's Avatar
Liked: 1771
Originally Posted by mayhem13 View Post
Great Link Erich!
Looking around through that side will lead to tons of different designs he has done or by others that he knows.
Erich H is offline
post #21 of 109 Old 09-07-2009, 09:25 AM - Thread Starter
kgveteran's Avatar
Quoted: 363 Post(s)
Liked: 130
I may be limited to one sub, but that should be ok. Great link. Grouping seems to be encouraged.
Now drivers.
http://www.parts-express.com/pe/show...number=269-482
http://www.parts-express.com/pe/show...number=269-480
What about the coax driver thing ? Seems like the tweeters being far apart could be an issue ? Just a guess on my part.... I'm trying to keep cost down as you can see. I really don't need them , it just looks like a cool project to do.
post #22 of 109 Old 09-07-2009, 02:16 PM - Thread Starter
kgveteran's Avatar
Quoted: 363 Post(s)
Liked: 130
By the looks of the diagram, it looks like the drivers (if 8ohms) are grouped in parallel and then the four groups are paralleled for 8.7ohms.
If not, I would need a little wiring help. Odd numbers seem to add up to three in the center group.
Alot more than meets the eye with line arrays.
post #23 of 109 Old 09-07-2009, 02:50 PM
catapult's Avatar
Jim Griffin's line array white paper: http://www.audioroundtable.com/misc/nflawp.pdf
John Murphy's full-range-driver array: http://www.trueaudio.com/array/
Dennis H
catapult is offline
post #24 of 109 Old 09-07-2009, 03:00 PM
Liked: 25
Power tapering reduces the effects of comb filtering, but it also reduces the effect of the line array. The more you taper, the closer it gets to a point source.
One of the strengths of a line array is that a person is kept in the "near field" for much farther away from a speaker than a point source. That means sound drops off at 3db/doubling of distance vs. 6db. The more you taper, the more that column of sound is reduced so you lose that near field advantage.
No free lunch.
YID DIY
post #25 of 109 Old 09-07-2009, 04:35 PM
tvrgeek's Avatar
Quoted: 17 Post(s)
Liked: 33
No free lunch.
Exactly why they work so well as PA systems in small clubs.
I was not aware of the side effect of power taper. Thanks for the tip. It makes sense when I think about it.
tvrgeek is offline
post #26 of 109 Old 09-07-2009, 04:52 PM
lennon_68's Avatar
Looks like something Vas would build. 3" full range driver with extremely light cone, huge neo motor, and 12mm xmax... Only $170 each:
http://www.parts-express.com/pe/show...number=296-220
lennon_68 is offline
post #27 of 109 Old 09-07-2009, 04:56 PM
LTD02's Avatar
Liked: 2577
not sure about those daytons. where are the specs?
if you can beat down the resonant peak, these may work well, especially for $15 a pop:
http://www.parts-express.com/pdf/297-433.pdf
LTD02 is offline
post #28 of 109 Old 09-07-2009, 05:08 PM
LTD02's Avatar
Liked: 2577
lol. "less than 1db power compression up to 95db."
lol. "exceptionally flat response from 40hz up." check the graph. 20db spread.
no doubt it kills bose acousticrap, but that's not saying much.
xbl makes it interesting. the p-p xmax spec is horse poo. divide by 2.
this driver doesn't seem to be worth the money.
LTD02 is offline
post #29 of 109 Old 09-07-2009, 06:48 PM
lennon_68's Avatar
Man, we're in the wrong business... we should all be eBay entrepreneurs:
1400% markup
post #30 of 109 Old 09-07-2009, 07:31 PM - Thread Starter
kgveteran's Avatar
Quoted: 363 Post(s)
Liked: 130
(40) per side http://www.parts-express.com/pe/show...number=289-124
PE wholesale for $1.40 each.
I think the wiring harness will cost more than the drivers !
The sub will have to be 150hz. I wonder how the 15" kit sub will handle that.
I think sealed with insulation would work fine. I'll use a hole saw, heck with a router for 80 total holes.
