Danley DTS-10 "Super Spud" DIY kit - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
Old 11-07-2009, 03:40 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
Wow, that looked straightforward to build.
A9X-308 is offline
Old 11-07-2009, 03:43 PM
Mathelo's Avatar
How would the sound from the DTS-10 be affected if it was mounted on the wall at the ceiling with the opening at the ceiling / wall boundary? This is largely dead space behind my plasma and could be an ideal location provided it would be acoustically okay.
Thought?
Louis
Mathelo is offline
Old 11-07-2009, 03:46 PM
rkinmoval's Avatar
Quoted: 36 Post(s)
Brandon,
Nice job on the assembly! Wow that's a lot of screws. I bet you know why I like to build with rabbet and dado joints now. Everything "just fits". Can't wait for everything to set up and for you to get the drivers in there and start taking some measurements.
Ryan
rkinmoval is offline
whumpf's Avatar
Are there access panels in both sides? And wouldn't it be a lot easier to install the drivers before putting the last side on? (I know you don't have the drivers, just asking for future buyers).
whumpf is offline
Old 11-07-2009, 03:46 PM - Thread Starter
brandonnash's Avatar
Liked: 32
Do you mean hanging it on the wall? If so it would work, but this really is a heavy subwoofer. I don't have any panels in it, no drivers, no paint and it's probably already over 200 lbs. Maybe well over that. It would be hard to get up there in the first place and also hard to keep up there probably.
brandonnash is offline
Old 11-07-2009, 03:49 PM
WilsonL's Avatar
So yours is actually slightly wider than posted prior , which i liked better.
final dimensions, 60"x42"x16"
http://www.avsforum.com/avs-vb/showt...2#post17392542
Will the current version any different or remaining at 44"?
Originally Posted by brandonnash View Post
Dimensions are 16"x44"x59.5"
Haven't thought about the riser option yet. Don't know how I will run that. When the drivers come in I'm going to put it at the same placement that my current large sub is in just so I can get a nice A-B comparison. Then I'll start messing around with different placement.
WilsonL is offline
Old 11-07-2009, 03:50 PM - Thread Starter
Liked: 32
Easier, yes probably so. It's not difficult though. There is already a hole for the speaker wire to run through and all you really have to do is mount it and screw the driver in. Not hard at all even with the panel on. If you put the drivers in first then put the panel on you'll be waiting for the glue to dry before you can play it. I'd rather wait till the glue dries so if there's any excess glue that leaks you can clean it up before putting the drivers in. No glue on the drivers is good.
Old 11-07-2009, 03:51 PM - Thread Starter
Liked: 32
Changing the dimensions will change the sound so I don't think they will be changing.
Old 11-07-2009, 04:06 PM
Aaron Smith's Avatar
Quoted: 139 Post(s)
Liked: 58
Looks like that was fun to build!
As whumpf asked, are there access panels on both sides?
I'm looking at using this as a fireplace base -- can you please measure the area in the red to let me know if my fireplace will clear the access panel? It may be easier to ask you if a 40x24 fireplace will fit in the red area I guess.
Aaron Smith is offline
Old 11-07-2009, 04:06 PM - Thread Starter
Liked: 32
Originally Posted by rkinmoval View Post
Brandon,
Ryan
Yeah, I'd love to do all my stuff with rabbet and dado joints. I'm not that good. I'd need a CNC to get it done like that. I'm just not that good with woodworking. That's another good thing about this. If you don't have tools to make your own DIY sub you can make this. All you need really is a power drill and some glue.
Old 11-07-2009, 04:07 PM
TnTBigman's Avatar
This looks awesome. I'm excited. Thanks for the pics.
You'll rarely hear anyone say, "I wish I'd gotten less Sub."
$ubwoofer$ and premium mango tree cultivar$
TnTBigman is offline
Old 11-07-2009, 04:11 PM - Thread Starter
Liked: 32
Yeah, there are access and panels for the mouth on both sides. Dimensions are about 29"x47" for the red area you wanted so you should be good. Not understanding really though. Where are you wanting to put the fireplace again?
Old 11-07-2009, 04:14 PM
allanf714's Avatar
"Any chance we're going to see a kit version of the TH-SPUD????"
I'm wondering that too now.
The 11" thickness makes it feasible to build one into the bottom of my couch and use another as a riser for my 2nd row of seating.
Two TH-SPUDS are a drop in replacement for the riser under my second row (exaclty as indicated on thier site). Just can't swallow the cost. A kit version of the TH-SPUD would be great hint, hint
Allan
allanf714 is offline
Old 11-07-2009, 04:16 PM
Quoted: 139 Post(s)
Liked: 58
Thanks Brandon!
The fireplace base will sit right on (actually slightly inside of as I guessed dimensions) the red lines -- it's a 2-sided corner mount fireplace.
The only thing I'm kind of worried about is rattling the metal in the fireplace -- going to have to do some judicious soundproofing in between all of the metal panels.
Old 11-07-2009, 04:41 PM
Fatawan's Avatar
On to some pics...
Brandon
Is that an optical illusion or is the top bowed up in the middle? How is the fit of the pieces on the outside when you are all done? Veneer worthy? Do the edges line up perfectly?
Fatawan is offline
Old 11-07-2009, 04:49 PM - Thread Starter
Liked: 32
I think that's just the angle of the pics. That's weird though. Edges line up perfectly. This was CNC cut so it's very precise. Yes veneer worthy, but that may be expensive depending on what you use. This is a LARGE sub.
Old 11-07-2009, 05:14 PM
Kanaris's Avatar
Brandon,I didn't read the whole thread but is this sub made for 2x 15 inch drivers? I got a pair of Classic Tempests and would like to give that a shot.
Kanaris is offline
Old 11-07-2009, 05:16 PM
michael hurd's Avatar
Quoted: 43 Post(s)
Liked: 41
2 x 12" drivers... like the LAB 12 that Eminence produces, only the driver that DSL has custom made has a larger voice coil and more Bl.
"What the heck was that crashing noise?" Me: "oh, just tossed the shampoo bottles off the shelf on the opposite side of the house. "
michael hurd is offline
Old 11-07-2009, 05:22 PM - Thread Starter
Liked: 32
Right now the only available driver that would work with this is Danley's version of the lab12. Tom has found one other driver that will probably work, but its a good bit more expensive not making it very practical for this application. When he gives the ok on that driver either me or ricci will let everyone know what it is. He has told us, but we need to keep it to ourselves so as not to have people rushing to get it just to find out it may not work.
Old 11-07-2009, 06:04 PM
mynym's Avatar
Quoted: 22 Post(s)
Very clean. I <3 how easy everything went together. No guesswork.
Does the kit come with the acoustic padding and does it tell you explicitly where to put it?
What about the access panel gaskets?
mynym is offline
Old 11-07-2009, 06:06 PM - Thread Starter
Liked: 32
Yes, yes, and yes.
Mike Hedden's Avatar
This is a very important point. With a tapped horn design, the driver has some very specific and somewhat unusual parameters. If you try to "roll your own", you do it to your own peril. Also Tom modeled a standard Lab sub driver in this cabinet and it doesn't work so don't waste your money on one in an attempt to save money.
By the way just for fun I did some quick SPL measurements of our DTS10 in our demo room which as a reminder is 80'x50'x14'. I wasn't trying to measure absolute maximum output but I measured at a meter using some really agressive metal music (Three Days Grace) it easily hits the upper 120dB, (126-128dB to be exact) but more importantly it has the punch of our tapped horns so there is substantial punch and attack on the top end of the sub as well as extreme extension. It will also effortlessly reproduce a 15Hz sine wave that fills the entire room, sounds kind of like a helicopter coming in for a landing.
Mike Hedden
Danley Sound Labs, Inc.
Mike
Mike Hedden is offline
Old 11-07-2009, 06:09 PM
mynym's Avatar
Quoted: 22 Post(s)
Did the side panels also come with tnuts/hurricane nuts already installed or did you install them?
mynym is offline
Old 11-07-2009, 06:12 PM - Thread Starter
Liked: 32
Already installed.
Old 11-07-2009, 06:41 PM
Tom Bley's Avatar
Quoted: 593 Post(s)
Liked: 529
How does it sound without the drivers?
Tom Bley is offline
Old 11-07-2009, 06:46 PM - Thread Starter
Liked: 32
Sounds hollow.
Old 11-07-2009, 06:49 PM
Tom Bley's Avatar
Quoted: 593 Post(s)
Liked: 529
Sounds hollow.
Cool I couldn't resist. Nice build! Looks like an awesome kit. Beer is good
Tom Bley is offline
Old 11-07-2009, 07:10 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
the internal panels don't appear to be pre-drilled. do the instructions suggest using self tapping screws through the side panel pre-drilled holes? i assume the side panels are pre-drilled.
for lurkers with untrained eyes, this is a very high quality design. all the stress points appear to be reinforced. all the air leakage points appear to be dadoed. this is a good...really good design.
i just hope this isn't a bait and switch. i don't care about me, but i do care about the many folks who will get excited about the possibility of having such performance at such a great pricepoint, then having it pulled on them.
Listen. It's All Good.
LTD02 is offline
Old 11-07-2009, 07:46 PM
Warpdrv's Avatar
Cool stuff Brandon.... that thing looks wicked
Your gunna have a monster on your hands.... I have no doubt Danley being the company they are will continue to provide such great products like this, especially for the DIY community...
Warpdrv is offline
Old 11-07-2009, 07:54 PM
Quoted: 139 Post(s)
Liked: 58
Mike (or Ivan or Tom),
If I use the DTS10 as a base for a 40"W x 24"D fireplace that fits within the red lines of the below pic, do you foresee any issues with having the mouth exit in front of the fireplace? What is the likelihood that I will experience problems with excessive vibration of the fireplace's metal/glass panels?
I don't want to vibrate the gas line loose and blow my house up.
