Danley DTS-10 "Super Spud" DIY kit - Page 334 - AVS Forum | Home Theater Discussions And Reviews
 25Likes
post #9991 of 10296 Old 02-01-2014, 05:53 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 234
Originally Posted by ellisr63 View Post
So would I use this for EQing all my speakers or just the sub? I have the Denon 4520 and I was told I would need the Behringer for the DTS-10s. If Iuse it as a pre EQ for the Denon then I would need 2 to do 11.2, correct?
You could EQ more, but I would just use it for the subs. You can also almost the same functionality with Behringer iNuke DSP series amps. Check the on sale thread....
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #9992 of 10296 Old 02-01-2014, 06:16 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
What about the Behringer Feedback Destroyer Pro, would this be as good?
ellisr63 is offline
post #9993 of 10296 Old 02-01-2014, 06:27 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 234
I think that would do the trick, but I am not overly familiar with that model.
Joe = LFE Addict
jpmst3 is offline
post #9994 of 10296 Old 02-01-2014, 06:46 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
I was told that the DTS-10 does it's best when it is EQ'd to 60hz or lower... If that is the case I might need to boost the bottom end on my La Scalas too. Would I need another one to do that too or would my Denon 4520 take care of that?
ellisr63 is offline
post #9995 of 10296 Old 02-01-2014, 06:57 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 234
You can cross them over at 80Hz.
If you get a miniDSP or DCX you can choose your crossover point between 60 and 80 to see what works best for you.
I had mine crossed at 80 after eliminating the humps in response using the recommended EQ settings.
ellisr63 likes this.
Joe = LFE Addict
jpmst3 is offline
post #9996 of 10296 Old 02-09-2014, 07:47 AM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
Thanks, I am picking them up Monday morning... What a shame that I won't be able to try them out for about a month or longer as the HT will be under construction.
ellisr63 is offline
post #9997 of 10296 Old 02-09-2014, 11:39 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 234
Joe = LFE Addict
jpmst3 is offline
post #9998 of 10296 Old 02-09-2014, 01:10 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
That it is... We are getting our shed built next weekend and then the garage will be cleaned out. Once it is cleaned out we begin the conversion. smile.gif
ellisr63 is offline
post #9999 of 10296 Old 02-13-2014, 12:19 PM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 46
Got a quick question. Im waiting for my mic to get here so I can run REW on my 3 dts-10's. In the meantime I am going to run audessey from my Marantz av7005. My question is this. Should I put Tom Danleys recommended filters in my mini dsp before I run audessey or after? Or not at all after audessey?
kutlow is offline
post #10000 of 10296 Old 02-13-2014, 12:23 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 234
Put them in before. You want to tame the ringing and other issues before the final EQing occurs.
Joe = LFE Addict
jpmst3 is offline
post #10001 of 10296 Old 02-13-2014, 12:55 PM
MKtheater's Avatar
Quoted: 1757 Post(s)
Liked: 1351
Too late
Mfusick likes this.
Marantz 7704
2 Outlaw 7140s
Speakers- my own creation!
subs 2 XXX ported SLLT.
MKtheater is online now
post #10002 of 10296 Old 02-13-2014, 01:12 PM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 46
kutlow is offline
post #10003 of 10296 Old 02-21-2014, 04:48 PM
audioresearch's Avatar
Is there anywhere near Boston where I can listen to a DTS-10? If not, can you set somebody up in this area to be a dealer and have subs setup for listening?
audioresearch is offline
post #10004 of 10296 Old 03-25-2014, 03:40 AM
Peterc613's Avatar
Quoted: 594 Post(s)
Liked: 965
how do I post pictures to my postings?
Peterc613 is offline
post #10005 of 10296 Old 03-25-2014, 05:40 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 234
Use the picture icon at the top of every posting window and select the pictures you want to post.
Joe = LFE Addict
jpmst3 is offline
post #10006 of 10296 Old 04-01-2014, 09:23 PM
BRAD S's Avatar
Quoted: 23 Post(s)
Liked: 48
Has anybody ever tried to place a DTS-10 outside of the footprint of their theater and have a "pass-through" a little larger than the "horn opening" on the sub? I would go to great efforts to keep any unwanted sound from entering the theater space through this hole, so I would likely double drywall/green glue around the DTS-10 outside of the theater as to not give up any of my limited theater width.
I would be passing through approximately 10". I understand I would likely be changing the "length of the horn" by having the sound travel farther than the box was designed.
My thought is to use two DTS-10's in the front behind my screen wall and implement a third DTS-10 approximately mid wall on my right side of the room.
Room is 30' x 13'4 x 8'
I do have three Triad Inwall subs I can use in columns to even out any nulls that may present themselves.
Thanks in advance for any input on this......
BRAD S is offline
post #10007 of 10296 Old 04-01-2014, 10:12 PM
chrapladm's Avatar
Quoted: 944 Post(s)
Liked: 352
I have seen it done by others. I believe there is a thread on HTS but I dont recall where.
chrapladm is offline
post #10008 of 10296 Old 04-01-2014, 11:43 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
Others have put the DTS-10 in another room and fired into the HT room. I am not so sure if mixing the Triad in wall sub with a horn loaded sub will work though.
ellisr63 is offline
post #10009 of 10296 Old 04-02-2014, 04:50 AM
Ivan Beaver's Avatar
Quoted: 16 Post(s)
Liked: 59
Just be sure not to reduce the size of the exit of the DTS10. If anything-have it expanding-especially over a length of 10".
Generally it is not a good idea to mix subs of different models (even from the same manufacturer).
THe different phase responses will cause dips and peaks in the response that cannot be eqed out.
It is far better to use more of the same sub model. That way they can all work together
MemX likes this.
Danley Sound Labs
Physics-not fads
Ivan Beaver is offline
post #10010 of 10296 Old 04-02-2014, 05:00 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 234
Mixing them can be problematic and an exercise in futility. I was able to mix my DTS-10 with my sealed subs with reasonable success, but probably less than optimal. As always, the room and listening position play the largest role.
Joe = LFE Addict
jpmst3 is offline
post #10011 of 10296 Old 04-02-2014, 08:03 AM
BRAD S's Avatar
Quoted: 23 Post(s)
Liked: 48
Thank you for everybody's input!
BRAD S is offline
post #10012 of 10296 Old 04-03-2014, 11:31 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 234
Sure thing! Also, I should mention that I am now running a LOWARHORN in place of my former DTS-10 that I have had a high degree of success integrating with my existing sealed subs as well. Once again, probably less than optimal, but I am happy with the results.
It definitely takes some fine tuning but you might be able to do reasonably well too.
Joe = LFE Addict
jpmst3 is offline
post #10013 of 10296 Old 05-15-2014, 01:58 PM
TCARCIO's Avatar
Quoted: 110 Post(s)
Liked: 95
I put mine behind a wall and it worked out great. I just extended the horn mouth. Here are some pics.
TCARCIO is offline
post #10014 of 10296 Old 05-15-2014, 04:20 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
Did yours have the opening on the end or did you make it... Mine only has the side opening.
ellisr63 is offline
post #10015 of 10296 Old 05-15-2014, 05:04 PM
t6902wf's Avatar
I also ported mine through the wall.. I am not in a position to post pictures.
T6
Clearwave 4TSE and 4CC build thread
http://www.avsforum.com/avs-vb/showt...1#post19489740
t6902wf is offline
post #10016 of 10296 Old 05-15-2014, 05:08 PM
TCARCIO's Avatar
Quoted: 110 Post(s)
Liked: 95
Not exactly sure what you mean. It was the kit that Danley was selling a couple of years ago and they were all the same.
TCARCIO is offline
post #10017 of 10296 Old 05-15-2014, 05:13 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
Mine is the kit also but the port on mine is on the side... Not the end like yours is. I was told there were 2 versions made... One with the port on the side and one that had the port on the end .
Mine is just like the one in the first post of the thread... Side opening only. I am curious as I am thinking of making one of mine end exit and plug the side exit. Then I can make a horn to bring it closer to my screen.
TCARCIO likes this.
ellisr63 is offline
post #10018 of 10296 Old 05-15-2014, 06:03 PM
TCARCIO's Avatar
Quoted: 110 Post(s)
Liked: 95
Oh, I didn't know that they made two versions.
TCARCIO is offline
post #10019 of 10296 Old 05-16-2014, 04:35 AM
t6902wf's Avatar
I don't think they made two versions. One of your photos is a bit of an illusion.
Here is mine installed
The grill to the right of center is the port.
Here is the other side.
TCARCIO likes this.
T6
t6902wf is offline
post #10020 of 10296 Old 05-16-2014, 10:14 AM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
There are definetly 2 versions... Look at this one, DTSend_zps8d47d015.jpeg[/URL] . No illusion at all..
ellisr63 is offline
