Danley DTS-10 "Super Spud" DIY kit - Page 337 - AVS Forum
 7Likes
post #10081 of 10107 Old 08-04-2014, 08:10 AM
Al Sherwood's Avatar
Quoted: 335 Post(s)
Liked: 126
What about these 'new' drivers?
This are the drivers from your DTS-10?
If so do you have the proper Hpass in place? Is this your second pair of woofers or who are these from?
I know DSL uses custom drivers in their cabinet so regular ones wont work. LMSR 12's do work in the DTS 10 though if you need replacements.
Originally Posted by autox320 View Post
Have you damaged drivers in the cabinet before?
How much power are you using?
Are you sure all hatches and drivers are sealed when closed up?
Have EQ filters in place? what are they? Danley recommended ones to start with?
Which year cabinet do you own? Some earlier ones barely had enough clearance for the excursion of the surround. This can be remedied by just doubling the gasket to the face of the driver that's mounted facing inward.
It's always hard to tell by photos but many things can be at play together. If there's an air leak or one driver causes one the other will follow. The horn relies on a sealed system to work efficiently and apply full power. If not drivers will fail and yes the surround is the weakest part being foam.
Actually the LMSR isn't the only thing after sliced bread. The lab12C works as a replacement but can't handle as much wattage. DSL have replacements available that are OE; yes slightly different parameters and larger vented 3" coils. The Alpine Type R; SWR-12D4/2 also works and has more robust parts.
Just got an email from Parts Express about these from Eminence, would they be suitable? http://www.parts-express.com/eminenc...gn=email080414
Al
Al Sherwood is offline
post #10082 of 10107 Old 08-04-2014, 08:15 AM
martinq's Avatar
Quoted: 22 Post(s)
One look at the Xmax should give you the answer. (Hint: No!)
martinq is offline
post #10083 of 10107 Old 08-04-2014, 08:19 AM
Quoted: 335 Post(s)
Liked: 126
Hmmm, didn't look at that, what is the Xmax of the supplied drivers?
(need to clear so space and build mine... )
Al
post #10084 of 10107 Old 08-04-2014, 09:35 AM
autox320's Avatar
Liked: 38
No i'd say those aren't suitable at all. No real xmax and freq response is too high.
The lab12c is real close to the Danley OE drivers. Ran them in one of my cabs for about 35 days.
http://www.parts-express.com/eminenc...4-ohm--290-668
"I should really see what dB levels I'm pushing. Long as it can't foam my beer during a movie we are ok "
autox320 is offline
post #10085 of 10107 Old 08-04-2014, 10:27 AM
Quoted: 335 Post(s)
Liked: 126
Interesting how much smaller the Voice Coil is 2.5" versus 4"
Only 35 days and then what...
Al
post #10086 of 10107 Old 08-04-2014, 02:04 PM
autox320's Avatar
Liked: 38
Voice coil difference matters little depending on engineering. The Danley DTS10 driver has a 3". The alpine SWR 12 has a 2.5" but it's flat wound aluminum and forced venting handles as much as most copper wound 3" coils.
After 35 days or so I tried the alpines(borrowed), then after a couple days I put back the Danley OEM drivers. I wanted to measure but honestly lots of other projects got in the way. Sorry no data for you guys. If the alpine drivers last for reliability I'd say they are the best bang for the buck. Reason I question reliability is some mixed reviews on them. My guess is they are priced to sell and get abused so hard in car audio things happen. Some I'd chalk up to improper setups of cabinet and power expectations. Very well engineered motor venting.
autox320 is offline
post #10087 of 10107 Old 08-04-2014, 07:32 PM
kutlow's Avatar
Quoted: 16 Post(s)
I put the LMSR-12 in my 3 dts-10's and they sound 3 x as good now.
kutlow is offline
post #10088 of 10107 Old 08-04-2014, 08:06 PM
autox320's Avatar
Liked: 38
The alpine have the advantage over the lms-r up to 120db....more area under the curve in the lowest freqs. 32mm one way just like the lms-r for a fraction of $, and honestly more motor tech.
I honestly plan to use these if the factory drivers die, or next upgrade itch.
ellisr63 likes this.
autox320 is offline
post #10089 of 10107 Old 12-13-2014, 05:50 PM
Mfusick's Avatar
Quoted: 240 Post(s)
Liked: 1179
This thread has the most views of any thread in the history of this forum... I just realized that.
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is offline
post #10090 of 10107 Old 12-13-2014, 05:55 PM
Quoted: 335 Post(s)
Liked: 126
And you made me look too!
One day hopefully soon I will build the 2 kits I have...
Al
post #10091 of 10107 Old 12-13-2014, 05:57 PM
Mfusick's Avatar
Quoted: 240 Post(s)
Liked: 1179
I wish I could find a kit for sale...
atabea likes this.
Mfusick is offline
post #10092 of 10107 Old 12-13-2014, 06:07 PM
Quoted: 335 Post(s)
Liked: 126
A few years back when I was looking (just before the last Danley sale), I found a couple on places like Craig's list, but some were more then the kit sold for and others were so far away that it would have been a night mare to get them.
In the end a group buy from Danley came about, still shipping to my location was about $750.
Good luck in your quest!
Mfusick likes this.
Al
post #10093 of 10107 Old 12-13-2014, 08:04 PM
TCARCIO's Avatar
Quoted: 43 Post(s)
Liked: 48
Can someone tell me which driver has been found to be the best replacement for the original that came with the DTS-10? I know it is probably posted here somewhere but I might be dead before I find it. Thanks for any info.
TCARCIO is online now
post #10094 of 10107 Old 12-13-2014, 08:06 PM
Mfusick's Avatar
Quoted: 240 Post(s)
Liked: 1179
Lms
Mfusick is offline
post #10095 of 10107 Old 12-14-2014, 11:41 AM
jpmst3's Avatar
Quoted: 72 Post(s)
Liked: 224
As stated above, it is the TC Sounds LMS-R. However, I am not sure they are available at the moment.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is online now
post #10096 of 10107 Old 12-14-2014, 11:50 AM
TCARCIO's Avatar
Quoted: 43 Post(s)
Liked: 48
If I cant get the LMS then how about the Alpine that has been mentioned?
post #10097 of 10107 Old 12-14-2014, 11:52 AM
jpmst3's Avatar
Quoted: 72 Post(s)
Liked: 224
I guess it depends on what your goal(s) are. If you want an upgrade, the LMS is the way to go. It has been documented and tested.
If you just need a replacement driver and don't want to pay Danley prices, the Alpine might work but I am not aware of any testing with it.
Joe = LFE Addict
post #10098 of 10107 Old 12-14-2014, 04:19 PM
TCARCIO's Avatar
Quoted: 43 Post(s)
Liked: 48
Great, Thanks for the info. Right now my DTS is working fine. I just wanted to know what driver I should use if I need a replacement in the future. I would really just want something that would work as well as the original without paying what the Danley replacement would be like you said. I think the Alpine would be my answer in that case. Now I just need to find out exactly which model Alpine that would be and see what the cost is. If it is reasonable I might get one for a spare just in case.
post #10099 of 10107 Old 12-16-2014, 06:55 AM
lemonslush's Avatar
Quoted: 364 Post(s)
Liked: 95
I wonder if they will ever offer them again
lemonslush is offline
post #10100 of 10107 Old 12-16-2014, 07:25 AM
jpmst3's Avatar
Quoted: 72 Post(s)
Liked: 224
I don't know, but having had a DTS and a LOWARHORN, I would definitely prefer the latter which can be build for about the same price or even less depending on driver choice. ...and with lower THD, more output, better form factor (IMO).
The only real advantage is quick assembly with the CNC panels on the DTS.
Mfusick likes this.
Joe = LFE Addict
post #10101 of 10107 Old 12-16-2014, 08:25 AM
Quoted: 335 Post(s)
Liked: 126
Not sure, have tied searching places like Craig's List and other local Used sales forums?
Out of curiosity I will have to look at the "LOWARHORN", the other unit I actually have plans for is the LABhorn ( IIRC also a Danley design), it uses a more generic Eminence driver and does a good job for most. In the end as mentioned the group buy came back and I took the plunge. http://www.prosoundweb.com/article/l...pecs_and_more/
Al
post #10102 of 10107 Old 12-16-2014, 08:28 AM
lemonslush's Avatar
Quoted: 364 Post(s)
Liked: 95
I doubt I would ever find Danley stuff let alone the sub I want on CL. Maybe its more common in the state they are produced in or something. I barley find Danley stuff on Ebay. But it would need to be local as shipping on the thing would be nuts I expect.
post #10103 of 10107 Old 12-16-2014, 08:54 AM
jpmst3's Avatar
Quoted: 72 Post(s)
Liked: 224
If you use the UXL driver at ~$540 (or even less if you can find them in the classifieds under $400) and a couple hundred dollars in wood, you have something that easily trumps the DTS-10 for $600-$800. You even have the option of the two footprints: GJALLARHORN/LOWARHORN
Joe = LFE Addict
post #10104 of 10107 Old 12-16-2014, 10:24 AM
MKtheater's Avatar
Quoted: 426 Post(s)
Liked: 543
Easily trumps? I don't think so, above 20hz yes, not below. If you put those beefy cheap alpine drivers in as replacements the DTS-10 alpine would most likely beat the GH below 16hz and come much closer above. Of course for all the trouble of finding a DTS-10 and modifying it I would just build the GH. Waiting for the drivers is another matter, you might find a DTS-10 by then!
AVR-Yamaha A830
amps-5 Adcom 555 in 850 watt monoblock mode
sub amp-Sanway FP14K
LCR-Dual stacked BFM DR-250's
Surrounds- Dual stacked BFM W10's
subs-12 SI 18's ported 6hz.
MKtheater is online now
post #10105 of 10107 Old 12-16-2014, 10:42 AM
autox320's Avatar
Liked: 38
I've not heard the LMS-R, but had the Alpine TypeR's a short bit. They were awesome. From my notes LilMike PM'd that the Alpine's KILL the LMS-R up to 120db, then the LMS have an advantage. I"ve also had a couple LAB12c's and they were fine, but just didn't handle the same power at the same volume with certain movies. Other than that they sounded just the same. A quick sweep with REW and the graph looked the same. Not played with anything else since. Still have all stock Danley drivers right now. Plan to upgrade to the Alpines if need replacements.
autox320 is offline
post #10106 of 10107 Old 12-16-2014, 04:07 PM
noah katz's Avatar
Quoted: 432 Post(s)
Liked: 196
... the Alpine's KILL the LMS-R up to 120db, then the LMS have an advantage.
Kill how?
Noah
noah katz is offline
post #10107 of 10107 Old 12-17-2014, 06:33 AM
Mfusick's Avatar
Quoted: 240 Post(s)
Liked: 1179
Probably smooth or as good for way less $ is what he meant.
Mfusick is offline
