myn's Tuba HT Review (LLT vs THT) - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #391 of 407 Old 01-11-2010, 08:28 PM - Thread Starter
mynym's Avatar
Quoted: 22 Post(s)
I just need to move to Kansas with the rest of you guys .
THT capital of the USA.
mynym is offline
post #392 of 407 Old 01-11-2010, 08:32 PM
reecew's Avatar
LOL it is starting to seem that way isnt it. Even Superedge is from kansas.
List your favorite BASS movies here...http://lfemovies.pbworks.com/FrontPage
reecew is offline
post #393 of 407 Old 12-27-2010, 12:35 AM
Maxjr's Avatar
Time to bump this awesome thread back from the dead!
I'm interested in building one of these. Does the Tuba HT limit bandwidth to the sub in any way? Like a bandpass box? I'm just curious as to what the tradeoffs are with an THT is versus Sealed or Ported (other than it's large footprint and volume requirements). What are the negative tradeoffs of a THT?
Maxjr is offline
post #394 of 407 Old 01-27-2011, 05:41 PM
DIYHomeTheater's Avatar
Will the Tuba HT be adequate for my HT?
DIYHomeTheater is offline
post #395 of 407 Old 01-28-2011, 07:27 PM
dbldare's Avatar
WOW! Wipe the dust off this thread!
Yes, if you can live with the size. It's 24"-36" X 36" X 36". I'm VERY happy with mine! BTW, this thread was my inspiration to build mine!
dbl
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
post #396 of 407 Old 01-28-2011, 07:30 PM
dbl
Space behind my false wall is 30". Is 24" the depth? Then it will fit.
post #397 of 407 Old 01-28-2011, 07:38 PM
goku14139268520's Avatar
The THT's dimensions are as follows,
36" Height
36" Depth
The recommended width with a fifteen inch driver installed therein ranges from 24" to 36" wide. The wider the cab, the flatter the frequency response within the THT's passband.
goku14139268520 is offline
post #398 of 407 Old 01-28-2011, 07:45 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Better make sure you have a way of getting it in the house and to where you want to place it.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #399 of 407 Old 01-28-2011, 08:15 PM
How about building it in the theater?
post #400 of 407 Old 01-28-2011, 08:17 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
You basically have to if you don't have 36" door openings and wide corners.
Joe = LFE Addict
jpmst3 is offline
post #401 of 407 Old 01-29-2011, 06:58 PM
dbldare's Avatar
I built mine in the theater, but I also went with the 24" version so I can get it back out of the 30" door. The main the difference between the different widths is a smoother low end response. Believe me, the 24" is a monster!
dbl
dbldare is offline
post #402 of 407 Old 12-12-2012, 01:37 AM
omholt's Avatar
Picking up an old thread.
Are there any outdoor/ground-plane measuements of the Tuba HT?
At least a waterfall would be great to see. I'm particular interesting in seeing if FLH has resonances and peaks which can be seen with tapped horn.
omholt is offline
post #403 of 407 Old 12-12-2012, 07:58 AM
Ricci's Avatar
Quoted: 184 Post(s)
Liked: 472
I believe there were some measurements of a THT taken years ago at one of the prosound shootouts hosted by Wayne Parham.
The short answer to your question is yes there can be significant ringing artifacts in FLH's just like with TH's. I have seen a few decay measurements that show this to be the case. However I have also seen others for both horn types that are very well behaved. Each individual design is different and needs to be judged on its own merits. I have never seen these measurements for a THT. Sorry if that doesn't really help you much.
Ricci is offline
post #404 of 407 Old 10-16-2015, 04:15 PM - Thread Starter
mynym's Avatar
Quoted: 22 Post(s)
As it's approaching the 6th year anniversary of this being completed and the birth of the horn revolution on AVS, Just thought i'd say my THT is still going strong and haven't had the need to upgrade.
Also haven't had any neighbor complaints as they have all moved away :/.
PassingInterest likes this.
mynym is offline
post #405 of 407 Old 10-16-2015, 10:33 PM
holyindian's Avatar
Quoted: 83 Post(s)
Liked: 44
I am on my 4th year as well, with my THT, i will use it for another 2 years, and then build a wall of 18" with 8 LMS (i guess they are discontinued now), but something on the sidelines of 18" 8 or 10 drivers.
holyindian is offline
post #406 of 407 Old 10-17-2015, 11:12 AM
dbldare's Avatar
Great to hear guys! Mine is still thumping as well. Very glad I built it.
Now back to the movie.....
dbl
dbldare is offline
post #407 of 407 Old 10-17-2015, 11:12 AM
dbldare's Avatar
dbl
dbldare is offline
