The Reed TubaHT Build - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 12-07-2009, 09:20 AM
onebadgsx's Avatar
does anyone know where i can get a bash 500. parts express is out of stock...
onebadgsx is offline
Old 12-07-2009, 09:43 AM
Bill Fitzmaurice's Avatar
Liked: 4653
Google buy bash 500, there are a few sources.
Bill Fitzmaurice is online now
Old 12-07-2009, 03:14 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
maxmercy is offline
Old 12-07-2009, 03:32 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
o-audio has boost if i recall that may or may not work for this application. i can't find the curves anymore. did they disappear from the site, or can i just not find them right now?
Listen. It's All Good.
LTD02 is offline
Old 12-07-2009, 06:16 PM
onebadgsx's Avatar
oaudio.com does have a parametric eq . will this not work because of that??
has anyone one ever bought anything from them?
Old 12-07-2009, 06:27 PM
Liked: 4653
It's one of the reasons in its favor. Their version actually looks better than the one sold by PE.
Old 12-07-2009, 08:56 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
http://www.oaudio.com/docs/manual_v1_6.pdf
Check page 12. Yes it has boost. It helps the low end of the THT bringing up the response some where the THT falls naturally. Experiment with both the SS filter setting and the parametric EQ to get best freq response and lowest distortion. I use the 16Hz setting. If you want to push the hell out of the THT, use the 20 or 25Hz setting. Excursion maximum should be around 20Hz for THT. The 25Hz setting should allow you to push all kinds of power into the THT for max output. I sacrifice output for extension in my setup, I get good ouput into the high teens that way at 10dB below reference (above this level, my mains complain some, they are the limiting factor in my system).
JSS
maxmercy is offline
