Reece's THT build just had to be a follower - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 610 Old 01-13-2010, 12:03 AM - Thread Starter
reecew's Avatar
You too may have your very own THT for 10 easy payments of $39.95. But wait if you act by 2/28/10 well knock it down to 9 easy payments of $39.95. Amps on sale $40 off till then lol.
List your favorite BASS movies here...http://lfemovies.pbworks.com/FrontPage
reecew is offline
post #452 of 610 Old 01-13-2010, 06:16 AM
RyguyOK's Avatar
Reece, what speakers are you using for your LCR? I saw in another thread you had mains with a (I think) WMTW layout....
RyguyOK is offline
post #453 of 610 Old 01-13-2010, 06:31 AM - Thread Starter
reecew's Avatar
Theyre the cheapie sony's. But do have tmww layout and put out big sound for what they are. They have great midbass and i just dont want to give that up just for better highs. I want both lol.
reecew is offline
post #454 of 610 Old 01-13-2010, 12:15 PM
oikos's Avatar
but i lack the talent to DIY like you can u build for me?
oikos is offline
post #455 of 610 Old 01-13-2010, 01:13 PM - Thread Starter
reecew's Avatar
If you lived by me id lend a hand. But its not as hard as you would think it the instructions are fairly detailed.
reecew is offline
post #456 of 610 Old 01-13-2010, 02:42 PM
Kevin A's Avatar
The THT plan may seem intimidating at first, but if one follows the plans (and if you have a few basic power tools), even the novice DIYer can probably do a pretty capable job. BFM's THT design seems pretty forgiving with regards to finish & joinery.
Kevin A is offline
post #457 of 610 Old 01-13-2010, 03:46 PM
dbldare's Avatar
oikos,
Where are you located? Maybe someone in your area can help you out.
dbl
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
post #458 of 610 Old 01-13-2010, 07:12 PM
MStrickland1988's Avatar
Very nice subwoofer (jesus that's massive) and room. Like it a lot. Now just gotta do something about the sonys....
MStrickland1988 is offline
post #459 of 610 Old 01-13-2010, 07:17 PM - Thread Starter
reecew's Avatar
Thankyou... Yes it is huge but its worth sacrificing size for the performance you get. Im trying to figure out something to do about the sony's at the moment. Its a tough decision though since i dont want any commercial offerings. Although they do not disappoint at all. You would honestly be surprised at the sound they put out. I really dont need to get rid of them they do fine i just want something new.
reecew is offline
post #460 of 610 Old 01-13-2010, 07:37 PM
Check out Klipsch man I've been a huge fan ever since I got into them a few years ago. While some say they may not be the most accurate speaker I haven't heard any that speaker that sounds as transient and dynamic them (own RF-5s). Upper frequencies sound very crisp and the horn really helps spread them throughout the room. Bass extension is also very good, never needed a sub for music. They are generally very very efficient and come to life with very few clean watts. If you're looking for a good cheap speaker the KG series is definitely something worth looking into (you don't get the beautiful copper though ) Anyway, that's my 2 cents.
post #461 of 610 Old 01-13-2010, 08:04 PM
snickel's Avatar
Hey Reece I have been playing with REW just about ready to post some graphs just need to work out some bugs.
snickel is offline
post #462 of 610 Old 01-13-2010, 08:33 PM - Thread Starter
reecew's Avatar
Thats awesome i plan on taking some measurements this weekend my self. So far hows it looking? Are you going to take measurements nearfield or from your listening position? And max spl or at your regular listening volumes?
reecew is offline
post #463 of 610 Old 01-13-2010, 08:57 PM
brandonnash's Avatar
Liked: 32
One thing that both of you and really anyone with an identical sub should do is both of you take a measurement right at the mouth of the horn to see if you have identical response graphs. If the subs are built correctly then you should have very similar graphs. When I have messed with REW I try to take a measurement right at the horns mouth then one at the primary seating location. The seating location is more important for your hearing the subwoofer than the measurement right at the mouth. The mouth measurement is more for reference.
brandonnash is offline
post #464 of 610 Old 01-13-2010, 09:10 PM - Thread Starter
reecew's Avatar
I plan on doing a ton of measurements if i could ever figure this program out. Im still in the reading stages. Ill do max spl and normal listening volume, from the LP, from nearfield at the horns mouth, and with the sub in different placements. Have you posted any graphs of your DTS-10?
reecew is offline
post #465 of 610 Old 01-13-2010, 09:30 PM
Liked: 32
Yes I have posted some. They were at a previous location and I haven't run it since then. I am just using a spl meter for a microphone so the extreme low end isn't picking up that well. The graph that I run is probably 50 pages back in the thread. I will try and find it and post it. Its not that great of a graph and I am not sure if its my room or mic or what. Probably my room. Its a large room and no acoustic treatments.
post #466 of 610 Old 01-13-2010, 09:35 PM - Thread Starter
reecew's Avatar
As long as you loaded the proper cal file for your meter, from what ive read it should get it fairly accurate within +/- a few DB. Cool ive been looking through that thread but its so monstorous and easy to miss something. Im in the same boat as you with the room. I dont expect as great number as others with mine since im in a 6900+ cuft room open to upstairs. I just want to confirm what levels i am getting that are making me love this sub so much.
reecew is offline
post #467 of 610 Old 01-13-2010, 10:34 PM
goku14139268520's Avatar
Hey mike,
Have you come to a firm decision regarding what your next project will be, between another THT or the SLA's?
goku14139268520 is offline
post #468 of 610 Old 01-14-2010, 05:23 PM
snickel's Avatar
Originally Posted by goku14139268520 View Post
Hey mike,
yep,its going to be the SLAs.Starting on the build this weekend.
snickel is offline
post #469 of 610 Old 01-14-2010, 05:37 PM - Thread Starter
reecew's Avatar
Thats great mike. Im going to have to check them out. The next movie you need to watch is street fighter. Insane midbass i think they made this movie for THT owners lol. Every time someone got punched kicked or shot i felt it with extreme authority .
reecew is offline
post #470 of 610 Old 01-14-2010, 05:41 PM
Air Supply's Avatar
Street Fighter? Isn't that movie from the 80's? lol
Add your favorite bass-heavy movies here; http://lfemovies.pbworks.com/
Air Supply is offline
post #471 of 610 Old 01-14-2010, 05:46 PM - Thread Starter
reecew's Avatar
Nah. The new one on blu-ray Street Fighter Lengend of Chun Li.
reecew is offline
post #472 of 610 Old 01-14-2010, 05:53 PM
Air Supply's Avatar
Right on, is it a decent flick?
post #473 of 610 Old 01-14-2010, 05:56 PM - Thread Starter
reecew's Avatar
No, haha. Horrible acting but its a damn comic book film with all d list actors so thats to be expected. Great LFE though its worth a watch.
reecew is offline
post #474 of 610 Old 01-14-2010, 06:10 PM
Have you noticed that Moon Bloodgood, the chick who played "Blair Williams" on "Terminator Salvation", plays "Det. Maya Sunee" on Street Fighter? For some reason I find that to be kinda' funny. But she can be in any movie she wants as far as I'm concerned, 'cause I certainly don't mind lookin' at er'.
post #475 of 610 Old 01-14-2010, 06:29 PM - Thread Starter
reecew's Avatar
Your pic or link doesnt work. But i know what you saying shes the only reason why i didnt just close my eyes and listen. Chris Klein should honestly be ashamed of himself for taking on that role. I dont think it was him just the character they tried to make him portray. Anything for a paycheck.....
reecew is offline
post #476 of 610 Old 01-14-2010, 07:20 PM
snickel's Avatar
I have made near field and listening position graphs.Just need to make sure I am doing everything right before I post graphs.
snickel is offline
post #477 of 610 Old 01-14-2010, 07:28 PM - Thread Starter
reecew's Avatar
POST THEM thats way you can find out if its right lol. Im anxious to see what i FELT.
reecew is offline
post #478 of 610 Old 01-14-2010, 07:46 PM
snickel's Avatar
Just need to figure out how to post graphs lol plus I just made some new cables to see if it solves the problems I am having.
snickel is offline
post #479 of 610 Old 01-14-2010, 07:47 PM - Thread Starter
reecew's Avatar
Well mike maybe someone can jump in here i dont know how to post graphs either haha.
reecew is offline
post #480 of 610 Old 01-14-2010, 07:54 PM - Thread Starter
reecew's Avatar
actually i do sorry went braind dead for a spell. hit function and the print screen button. and then paste that in paint. and then save the file and then put the file on a file hosting site to give you the URL. then you can post it here
reecew is offline
