Reece's THT build just had to be a follower - Page 21 - AVS Forum | Home Theater Discussions And Reviews
post #601 of 610 Old 02-02-2010, 01:13 PM
Kevin A's Avatar
Originally Posted by mj79 View Post
Hope you dont live in a crappy climate .. I got the best 3 sheets out of 3 huge stacks.. There were in an outdoor wearhouse about 10 degrees and damp, got them home laid them on the ground of my garage( I have slab heat ) and by the next morning 1 piece was hooked, one was bowed, Im assuming from the drastic difference in temp and dryness. I think everyone who has built a THT thus far has had better luck than me , so dont mind me , Im just against araucoply aas it has raised my blood pressure qyite a bit in the past 3 days
Mild California climate with little humidity...
I plan on laying them flat & off the ground on 2x4s; with weights to help maintain the flatness once they're cut.
Kevin A is offline
post #602 of 610 Old 02-02-2010, 01:16 PM
Bbieger's Avatar
Just like Bill said. I would have been shocked if they didn't warp. You should always keep wood off the ground when acclimatizing it. some simple 2x2's on the ground and between the sheets will work.
Wood is a more complex creature than people think. Especially hard woods. You have to factor in movement and warping when your building something of decent quality. I never buy wood at HD for that reason. All there wood is flat sawed crap and as you are finding out, much of there plywood is poorly glued. This is flat sawn wood.. http://www.inthewoodshop.org/methods/lumber.jpg
So the lesson here is that if you have a wood supply store near you, it is worth the little extra money to go and get a decent sheet of plywood.
Bbieger is offline
post #603 of 610 Old 02-02-2010, 01:50 PM
PassingInterest's Avatar
Quoted: 185 Post(s)
Liked: 504
Great advice!
The 2x2 "stickers" between the sheets is the part that a lot of guys miss.
You need air circulation on both sides of each sheet in the stack.
Here's a tip for straightening cupped panels.
I think MaxMercy mentioned it elswhere on this forum.
Lightly spritz some water mist onto the concave side, then turn that side down on the pavement.
The uneven evaporation will pull the panel in the other direction.
Just keep an eye on it and stop the process when it is flat, or you will end up with your panel bowed in the other direction.
Then use the 2x2 stickers (the name for the dividers used to create an air gap), to allow for uniform air circulation.
PassingInterest is offline
post #604 of 610 Old 02-02-2010, 04:38 PM
mj79's Avatar
yea i dunno what i was thinking.. I usually would put it up but space was limited, as were supplies.. Hopefully I can get the bend out of whats left, and remember to spend $3 more next time for a few 8 foot 2x4s
mj79 is offline
post #605 of 610 Old 02-02-2010, 08:00 PM
snickel's Avatar
Reece's wife and kids must be home.It's not like him to be gone for 2 days.
snickel is offline
post #606 of 610 Old 10-07-2012, 06:58 PM
BIG INJUN CHIEF's Avatar
Liked: 194
It seems as if most of the THT build threads are around 2010-ish. I stumbled upon the plans a bit behind the curve and was curious if anyone is still building THT's. I believe I have read most of the build threads and find the info invaluable. I began my build over the weekend and make decent progress thus far.
BIG INJUN CHIEF is offline
post #607 of 610 Old 10-07-2012, 07:55 PM
Brad Horstkotte's Avatar
Liked: 73
Let's see some pics / build thread! I still love my pair of THT LPs.
Brad Horstkotte is offline
post #608 of 610 Old 10-08-2012, 09:18 AM
dbldare's Avatar
Awesome!
Start your own build thread!!! Post pics too!!!!
dbl
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
post #609 of 610 Old 10-08-2012, 01:57 PM
Liked: 194
These things seem amazing. Thanks for the encouragement. I will take your advise and snap a few photos and start a build thread. I read dbldares thread but do not think I stumbled across a Brad thread.
Edit: Build thread started. http://www.avsforum.com/t/1433051/injun-tht-build/0_40. I apologize in advance if posting a link in another thread is considered bad taste.smile.gif
post #610 of 610 Old 10-08-2012, 09:44 PM
Liked: 73
