Reece's THT build just had to be a follower - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 610 Old 12-27-2009, 03:36 PM - Thread Starter
reecew's Avatar
Originally Posted by Air Supply View Post
Word of advice, when it comes time for the outer panels. DO NOT smear the PL around. It's a mother to sand off and you'll damage the wood trying to do so.
Yea i saw in super's build thread it was mentioned to just let the PL dry as is and use a chisel to take it off. So i didnt smear it smooth on the exterior and it does come off easy with a good chisel. But on the interior of the box i used the PL as caulk and used my finger to smooth it out.
List your favorite BASS movies here...http://lfemovies.pbworks.com/FrontPage
reecew is offline
post #182 of 610 Old 12-27-2009, 03:37 PM
Air Supply's Avatar
Originally Posted by Bill Fitzmaurice View Post
PL on an open surface scrapes off easily with a decent chisel or scraper. It olny grabs tenaciously within joints where it expands into and bonds with the wood fibers.
Well, I used a putty knife to flatten out the squeeze out. That left a 2 inch wide smear of PL. Neither one of my scrapers removed the stuff, only the beaded up stuff.
Add your favorite bass-heavy movies here; http://lfemovies.pbworks.com/
Air Supply is offline
post #183 of 610 Old 12-27-2009, 04:59 PM
snickel's Avatar
Originally Posted by goku14139268520 View Post
You can never have to many clamps.Every time I go to Harbor Freight I have to buy one or two
snickel is offline
post #184 of 610 Old 12-27-2009, 06:14 PM
goku14139268520's Avatar
Contact Leland at www.speakerhardware.com. He's got a full line array HT, and is in Kansas.
Thanks Bill.
goku14139268520 is offline
post #185 of 610 Old 12-27-2009, 06:18 PM
Yeah, no kidding. I've always looked at em', just never bought any. Then I look at different build threads here and on other forums and what do I see? Photos with 10 clamps attached to a box as it's being put together.
post #186 of 610 Old 12-27-2009, 06:21 PM
snickel's Avatar
you will love the one handed quick clamps.I just have the old school pipe clamps
snickel is offline
post #187 of 610 Old 12-27-2009, 06:22 PM
Yeah, I've been playing with them since I got em', walking around the house clamping random objects together. I also like that you can reverse the "heads" on the larger clamps and use them as a spreaders.
post #188 of 610 Old 12-27-2009, 06:30 PM
snickel's Avatar
I am jealous.Time to buy more clamps!!
snickel is offline
post #189 of 610 Old 12-27-2009, 06:32 PM
post #190 of 610 Old 12-27-2009, 06:42 PM - Thread Starter
reecew's Avatar
HAHA you guys are nuts. John you sound just like me when i get a new tool i walk around the house just trying to find stuff to use it on. Well i have my access panel done and and waiting for it to dry that way i can give this sucker a test run for air leaks. I may go ahead and start filling the screw holes since that shouldnt affect my testing for air leaks it actually may help me not find any. Ill post some pics in a few minutes.
reecew is offline
post #191 of 610 Old 12-27-2009, 06:50 PM
snickel's Avatar
I use a brad nailer,smaller holes to fill.Get that sucker fired up and tell me how it sounds
snickel is offline
post #192 of 610 Old 12-27-2009, 07:00 PM
snickel's Avatar
Did all of your measurement come out correct? Number 8 panel was off by a 1/2 of a inch for me
snickel is offline
post #193 of 610 Old 12-27-2009, 07:02 PM - Thread Starter
reecew's Avatar
I tell you what on the tight fit areas on this box a brad nailer came in handy and was almost a must IMO. Since i dont have a million clamps my only other option was screws. This was before i knew you had an arsenal of clamps. But only on one side of each brace could you get screws into so thats when the brads came into play is on the other side. And on the access panel flanges.
reecew is offline
post #194 of 610 Old 12-27-2009, 07:05 PM
snickel's Avatar
Yes I was able to nail both sides
snickel is offline
post #195 of 610 Old 12-27-2009, 07:06 PM - Thread Starter
reecew's Avatar
Well thats because 8 9 and 10 need to be 35.5". But yes they were correct i went 100% off the instructions for my measurements. I didnt fiddle around with the precut panel dimensions as that wouldve thrown me off. The only one that was off for me was the final side panel and it was partially my fault (crooked cut )so i cut a new one and it fit perfectly.
reecew is offline
post #196 of 610 Old 12-27-2009, 07:07 PM
snickel's Avatar
The brad nailer is my favorite tool
snickel is offline
post #197 of 610 Old 12-27-2009, 07:19 PM - Thread Starter
reecew's Avatar
Heres a few pics of the box at the stage i am at now:
The front, i take bad pics but the braces i assure are level and straight.
Now the driver access hole with flanges in place.
And lastly a pic to show how clean the PL scraps off with minimal effort and a chisel. This is as long as you do not smear the squeeze smooth.
reecew is offline
post #198 of 610 Old 12-27-2009, 07:22 PM
Dude that looks great! How big does it seem in real life?
post #199 of 610 Old 12-27-2009, 07:23 PM
snickel's Avatar
Looks good.
snickel is offline
post #200 of 610 Old 12-27-2009, 07:25 PM
snickel's Avatar
Did you ohm out your coils? I am talking with another guy that is getting strange readings.
snickel is offline
post #201 of 610 Old 12-27-2009, 07:27 PM - Thread Starter
reecew's Avatar
Its huge im not going to lie. Its alot bigger than any normal person would want sitting out in their living rooms. Before i lifted it up on the saw horses alone i called and scheduled an appointment for a hernia removal lol. Just wait till i post the pics of it in my room. My rooms only the larger side and i have a gigantic Entertainment Center thats over 12ft long and i guarentee it will not scale the box down any.
reecew is offline
post #202 of 610 Old 12-27-2009, 07:29 PM - Thread Starter
reecew's Avatar
No i havent even got to the breaking in of the driver or testing yet. I figured i can bring all my equipment to the garage at once test for leaks and then break in the driver while im painting the box. But another reason i havent done the sub yet either is because i broke my meter last time i used it haha. So im going to have to buy/borrow one very soon.
reecew is offline
post #203 of 610 Old 12-27-2009, 07:33 PM
snickel's Avatar
My room is small,if this works out I will have to stack one sub on top of it and get rid of 2.
snickel is offline
post #204 of 610 Old 12-27-2009, 07:34 PM
snickel's Avatar
You just hit 200 posts in this thread Yea
snickel is offline
post #205 of 610 Old 12-27-2009, 07:37 PM - Thread Starter
reecew's Avatar
SUPPOSIBLY, I can not confirm nor deny these claims but i have read this is the only sub youll need. Unless you think you need something that can get down into the single digits and destroy your organs. what sub would you be stacking on top of this?
reecew is offline
post #206 of 610 Old 12-27-2009, 07:37 PM
snickel's Avatar
I have never broke in a sub,just take it easy for a few days.
snickel is offline
post #207 of 610 Old 12-27-2009, 07:40 PM
snickel's Avatar
My 15 inch tempest or my 18 inch ED sub.
snickel is offline
post #208 of 610 Old 12-27-2009, 07:42 PM - Thread Starter
reecew's Avatar
I am wanting to know how one of these compare to this danley DTS-10 "Super Spud" that seems to be catching alot of attention. The only reason is this being 2.5 times less the cost of the DTS-10. Who knows??
reecew is offline
post #209 of 610 Old 12-27-2009, 07:44 PM
snickel's Avatar
Don't go there you will get flamed with many charts and readings hahaah
snickel is offline
post #210 of 610 Old 12-27-2009, 07:46 PM
mynym's Avatar
Quoted: 22 Post(s)
Looking really clean
What you going to finish it with?
Now's the time to be breaking in the driver. It will make ALOT less noise with 13 volts freeair in contrast to what it will sound like in the enclosure with the same voltage
mynym is offline
