My first TC SOUNDS DIY sub! ***LOTS OF PICTURES*** - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 83 Old 01-07-2010, 08:09 PM - Thread Starter
maintrain's Avatar
Liked: 37
Originally Posted by maintrain View Post
On the webpage in that link in the first post, the author refers to an excel spreadsheet he used to calculate the mass needed for his passives. Maybe it will help someone else who's trying to figure this out.
http://www.danmarx.org/audioinnovation/passive.xls
@oachalon
maintrain is offline
post #62 of 83 Old 01-07-2010, 08:13 PM
oachalon's Avatar
Quoted: 13 Post(s)
maintrain, thanks for the help.
oachalon is offline
post #63 of 83 Old 01-07-2010, 08:16 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 76
Originally Posted by oachalon View Post
does anybody have a passive radiator calculator online, im too lazy to calculate by hand right now. All the links i found were dead. AE speakers used to have one but it looks like the link is dead as well.
I just use WinISD Pro, they have a PR option.
mjaudio is online now
post #64 of 83 Old 01-07-2010, 08:19 PM
oachalon's Avatar
Quoted: 13 Post(s)
so with a 6-6.5 cubic ft enclosure i would want to add about 1550g to the exodus passive radiators. that will give me 1850g each and tuning of around 17-18hz.
oachalon is offline
post #65 of 83 Old 01-07-2010, 08:19 PM
Kingdaddy's Avatar
Nice job, good exicution!
Kingdaddy is offline
post #66 of 83 Old 01-07-2010, 08:22 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 76
I haven't run the numbers but that sounds about right.
post #67 of 83 Old 01-07-2010, 08:38 PM
spanish68's Avatar
maintrain, a crossover of 60hz or below would work great with the TC 3k sub. Measure the sub in the PR box and see what you get, if your response is great to 80hz, that's where I would cross it at.
spanish68 is offline
post #68 of 83 Old 01-09-2010, 04:20 PM - Thread Starter
maintrain's Avatar
Liked: 37
Holy &%$!
I cannot believe how good this thing sounds! Terminator Salvation soundtrack is ridiculous and this sub is LOUD! I can't turn the ep-2500 past 1/4 gain with out it completely overpowering all the other speakers. My wife was caught completely off guard during one of the action sequences and nearly jumped off the sofa! Back to the movie!
post #69 of 83 Old 01-09-2010, 04:41 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 234
Holy &%$!
Sweet!
Glad you have the results you desire. Nice work!
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #70 of 83 Old 01-09-2010, 08:00 PM
spanish68's Avatar
maintrain, what crossover did you use for the TC 3K? Did you do any frequency measurements? Yes, the TC 3k sub can go low and hits hard in the low bass when called upon.
post #71 of 83 Old 01-10-2010, 11:19 AM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 76
I am really happy to hear the performance matches the look of your great sub.
What sub were you using before?
post #72 of 83 Old 01-11-2010, 04:47 AM - Thread Starter
maintrain's Avatar
Liked: 37
It's crossed @ 50hz but I haven't had a chance to do any measurements yet.
Audiosource SWfifteen. Doesn't even come close to sounding like this!
I now have a little hum coming from the audiobuddy pre-amp. Hum disappears when I bypass the pre-amp but I lose a lot of volume from the sub without it. I've read threads about grounding issues using a rca to xlr adapter. This is the one I'm using: http://www.parts-express.com/pe/show...number=240-438 . Would I be better off using a cheap ground loop isolator or running a 1/4 to rca adapter on the high impedance input?
post #73 of 83 Old 01-11-2010, 03:48 PM
zhillsguy's Avatar
Read this page and try building a cable according to the chart, #17:
http://www.rane.com/note110.html
Too many threads here on hum already.....give it a shot, it may cure the problem.
Cable_A.pdf 33.9052734375k . file
zhillsguy is offline
post #74 of 83 Old 01-11-2010, 03:49 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 76
Hey Marcus,
Why would you use the audiobuddy pre-amp if you only have the gain turned up 1/4 of the way on the amp? You can rub the gain all the way up on your amp, I do and control the volume from either my pre-pro or Velodybe SMS-1.
You could try one of these to connect you receiver to the sub-amp:
Just some suggestions as I noticed you commented on having the gain only 1/4 up on your amp before when watching a movie.
post #75 of 83 Old 01-12-2010, 01:14 PM
Reaper737's Avatar
Just wanted to say very nice build man, it looks and I'm sure sounds awesome.
Reaper737 is offline
post #76 of 83 Old 01-18-2010, 04:36 PM - Thread Starter
maintrain's Avatar
Liked: 37
Yeah I read about that. I ended up buying a Sampson s-convert and that solved all my hum problems and gave me a stronger signal into the amp. I picked it over the art cleanbox seeing that I wouldn't have to mod it. It's working perfectly.
Hey Marcus,
I'm ditching the audio buddy. Truth is, I couldn't turn it up over 1/4 without picking up noise from the sat antenna cable. I didn't get noise when testing at work. All is well using the Sampson S-Convert and I'm using the avr sub volume control.
Thanks Reaper. I'm enjoying it more everyday.
post #77 of 83 Old 01-18-2010, 06:10 PM
zhillsguy's Avatar
Glad it worked out for you, mt. Funny how everyone's mileage varies......I had to ditch my S-Convert, ends up it was amplifying all AC switching noises in my house beyond comfort level as described in my earlier thread:
http://www.avsforum.com/avs-vb/showt...969&highlight=
I ended up getting a MIC2200 to provide boost/eq....truth be told, I could have gotten by without it and am running everything at 0db level, no boost. My older Onkyo AVR provides enough output to the EP2500 as long as I keep my audio signal separate from any chassis ground (as in cable config #17). With chassis connected on the EP input side I get hum up the wazoo and a big signal loss. When I hook up my Yamaha powered mixer (unbalanced output) to the EP with no special cables (chassis tied to signal common via adapters) it works great. Go figure, you never know when interfacing "home" with "pro", trial and error is necessary.
BTW, great build!
post #78 of 83 Old 02-12-2010, 08:02 AM - Thread Starter
maintrain's Avatar
Liked: 37
minor update. i've changed amps. went from the ep2500 to and yamaha p7000s. I'v read threads that state the yamaha pxxxxs amps don't perform very well @ low freq but i am experiencing the opposite. the yamaha is giving me better performance <30hz and i truly do NOT miss that fan noise! Another thing, it's running 4ohms bridged and doesn't seem to have any problems running that load. I plan on spending more time with it this evening.
post #79 of 83 Old 09-06-2010, 11:00 AM
NcHalfrican's Avatar
Amazing build quality...love me some TC Sounds
NcHalfrican is offline
post #80 of 83 Old 11-22-2011, 09:41 PM - Thread Starter
maintrain's Avatar
Liked: 37
I can't believe it has been on over a year since I updated this page. I have a new video to post. Check it out: http://www.youtube.com/watch?v=dfu_B7kTC-o
post #81 of 83 Old 11-25-2011, 07:27 AM
Exocer's Avatar
I admire your work! Excellent stuff. Inspires me to back into DIY!
Only time will tell what the future holds...so until then JAM LIKE THERES NO TOMORROW!
-Rob
My Natalie P project
Exocer is offline
post #82 of 83 Old 11-25-2011, 06:33 PM
chrapladm's Avatar
Quoted: 944 Post(s)
Liked: 351
Can you play this on your sub and tell me what you think?
http://www.youtube.com/watch?v=ZgcDxm1HI60
Either way awesome sub.
chrapladm is offline
post #83 of 83 Old 02-05-2013, 11:13 AM
brybo86's Avatar
I am jealous of those passive radiators. This sub looks very nice. I just have a couple questions. What made you decide to notch the wood for the binding posts? Also why not make the TC Sounds Logo straight across? Do you have any REW plots of the frequency response? Anyways, very nice sub.
brybo86 is offline
