My first real attempt with hornresp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 02-02-2010, 06:13 AM - Thread Starter
Rightbrained's Avatar
Ok , I have been trying to get my head wrapped around hornresp.
I would like for you guys who know it pretty well to check this out and inform me if I am going about this correctly.
If at first you dont succeed , get a bigger hammer !
Rightbrained is offline
post #2 of 25 Old 02-02-2010, 07:00 AM
brandonnash's Avatar
Liked: 32
I am still kind of new at it too so good chance I am wrong, but your segments are going from large to small. I don't know if its calculating correctly when it does that.
brandonnash is offline
post #3 of 25 Old 02-02-2010, 07:20 AM
Oklahoma Wolf's Avatar
Quoted: 20 Post(s)
Looks very good, but it's a tapped TQWT (tapered quarter wavelength tube) rather than a tapped horn, because the flare goes the other direction. Might be interesting to see how it performs when built. Been thinking of using Hornresp for a similar design or two.
Compression ratio is high at the tap though (S3 - I'm getting above 6:1).
Oklahoma Wolf is offline
post #4 of 25 Old 02-02-2010, 07:21 AM
Bill Fitzmaurice's Avatar
Liked: 4459
It is calculating correctly assuming the design is a reverse tapered pipe.
Bill Fitzmaurice is offline
post #5 of 25 Old 02-02-2010, 07:36 AM
LTD02's Avatar
Quoted: 2334 Post(s)
Liked: 2562
like brandon said, your design is unconventional as it goes from large to small. as a result, who can say how it will perform.
Listen. It's All Good.
LTD02 is offline
post #6 of 25 Old 02-02-2010, 08:10 AM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
RB,
I'd say it's worth a shot at a build.... but the last length segment is maybe too small in length to fit the driver......
What's the excursion look like?
Good stuff!
JSS
maxmercy is offline
post #7 of 25 Old 02-02-2010, 09:09 AM
Liked: 32
I see. I thought he was going for a tapped horn though.
post #8 of 25 Old 02-02-2010, 09:11 AM - Thread Starter
post #9 of 25 Old 02-02-2010, 09:12 AM - Thread Starter
I was going after a tapped horn but like I said , this is really my first attempt with hornresp.
Please feel free to give me pointers.
post #10 of 25 Old 02-02-2010, 09:33 AM
Quoted: 20 Post(s)
To make it into a tapped horn, just switch S1 and S4 around... then go into the loudspeaker wizard (or TH wizard if you still have the older Hornresp), set S2 to variable, and the program should correct the rest of the parameters. You can then tweak from there.
If leaving it the way it is now, try increasing S4 to 200 in the wizard, and then L12 and L34 to match at 20cm for easier folding... the graph doesn't look as nice, but the compression ratio at the front of the diaphragm is healthier.
Not sure if the impulse and phase response looks good for this type of design or not (someone with more knowledge than I will have to help there), but the response still looks pretty decent even if it is a little bowed in the middle.
post #11 of 25 Old 02-02-2010, 09:39 AM - Thread Starter
Thanks for the pointers wolf. Hornresp is a little harder for me to grasp than the normal box programs.
post #12 of 25 Old 02-02-2010, 09:50 AM
Quoted: 20 Post(s)
You'll get the hang of it... all it takes is hours and hours of obsessing over the very smallest of horn tweaks
post #13 of 25 Old 02-02-2010, 11:05 AM - Thread Starter
thats what I was afraid of lol
post #14 of 25 Old 02-02-2010, 11:19 AM
lilmike's Avatar
Quoted: 61 Post(s)
Liked: 159
First - if it is a TTQWT, take a look at the impulse response.
That should be more than enough to make you look at design alternatives.
Second - and far more significant - get the latest version of Hornresp - Major upgrade released today.
It is COOL - sliders are supported for all sorts of different designs now!!!
lilmike is offline
post #15 of 25 Old 02-02-2010, 11:21 AM - Thread Starter
lilmike ,
I have the new version.
Now , I need to work on learning some more because I actually want a tapped horn.
Pointers and critique are most welcome.
post #16 of 25 Old 02-02-2010, 11:59 AM
lilmike's Avatar
Quoted: 61 Post(s)
Liked: 159
General pointers:
S1 = Sd/3
S4 = Sd * 2
Total length = (344/Fs)/4 X 100
L12 = driver diameter/2
L34 = adjustable for tuning
L23 = what's left
Seriously - mess around a bit with Hornresp, then read through the tutorials thread again - the basics are explained pretty well there in the first couple of posts, then we get into more detail. Things will make more sense as you work with it.
The new version is slick - makes lots of designs go much quicker.
lilmike is offline
post #17 of 25 Old 02-02-2010, 12:09 PM
Quoted: 20 Post(s)
+1 on the tutorials... they help a lot. I did a little tweaking in there to see if I could come up with something, and the woofer does seem to have some potential, though like most woofers I try to model a TH with it could always be better in one way or another.
The expanded loudspeaker wizard is a godsend... I was waiting for him to add more functionality to that. All it needs now is a folding wizard
Too bad I don't remember enough of my computer programming training, or my high school geometry training, or I'd try to whip one up myself.
post #18 of 25 Old 02-02-2010, 12:19 PM - Thread Starter
The woofers I am trying to model for a tapped horn are the Eminence made buyouts that PE had a while back. This is the 12 inch DVC model which is sold out but the 10 inch is still available.
These were only 30 bucks so its a cheap way to play around with new alignments.
post #19 of 25 Old 02-02-2010, 01:06 PM - Thread Starter
I am going back to re-read the tutorial and hopefully I will retain a little more of it.
post #20 of 25 Old 02-02-2010, 01:55 PM - Thread Starter
Ok , after further reading I decided to try again. Of course this still needs plenty of tweaking but perhaps I am headed in the right direction.
post #21 of 25 Old 02-02-2010, 02:00 PM
stgdz's Avatar
So do horns/tapered horns start to fall apart at 100-120hz and above?
stgdz is offline
post #22 of 25 Old 02-02-2010, 02:07 PM
Liked: 4459
Tapped horns do. The trick is to get at least 95dB sensitivity in half space from the driver Fs to at least 100 Hz. It's not easy, and requires a very good match of driver and horn.
post #23 of 25 Old 02-02-2010, 02:20 PM
lilmike's Avatar
Quoted: 61 Post(s)
Liked: 159
Looks like a tapped horn this time. Now - try changing some things to kill that big dip in the response at 60 Hz. (I'd start with L34)
In most cases, dips are worse than peaks in the passband.
lilmike is offline
post #24 of 25 Old 02-02-2010, 02:24 PM
Quoted: 20 Post(s)
Getting close to what I was doing with it earlier - that big dip at 60Hz can be tamed a bit too by increasing the mouth size (S4) to somewhere around 2000. But then it gets to be a real big horn.
L12 and L34 need some tweaking yet too. I find that I can just about tell when I have a good phase and impulse response by looking for the slinky effect in the wizard's response screen. If the waveform looks like it does a smooth boing-boing-boing down a set of imaginary stairs with no jaggies sticking out, I find when I go check the actual impulse and phase response it's getting close
post #25 of 25 Old 02-02-2010, 02:31 PM - Thread Starter
Cool , thanks for the tips. I am doing taxes right now so I will play with hornresp a little later.
I have 2 of these drivers so I may see what they will do together in one horn.
