Power ratings demystified - AVS Forum | Home Theater Discussions And Reviews
Old 02-14-2010, 01:47 PM - Thread Starter
Th3_uN1Qu3's Avatar
Here's some food for thought illustrating pro audio test standards. Now you know exactly how PA speakers are rated (notice the bass slope on all the tests, so they're obviously not rated for HT use ). http://www.sonidoprofesional.com/doc...erhandling.htm
I'll try to add to this thread any info i can find about audio power ratings. I'll try to find a document explaining amp power ratings as well.
Originally Posted by Ivan Beaver
The nice thing about standards is that there are so many to choose from.
Th3_uN1Qu3 is offline
Old 02-14-2010, 01:57 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2577
maybe not all pa are the same? footnotes on page 2 of this jbl 'sub' seem more rigorous than what you have posted.
http://www.jblpro.com/catalog/suppor...pe=3&docid=626
Listen. It's All Good.
LTD02 is offline
Old 02-14-2010, 02:20 PM - Thread Starter
Th3_uN1Qu3's Avatar
That's some nice explanations there. Lemme see if i can find another reference that says the same.
Old 02-14-2010, 04:27 PM
Ivan Beaver's Avatar
Liked: 57
Danley Sound Labs
Physics-not fads
Ivan Beaver is offline
Old 02-14-2010, 06:13 PM - Thread Starter
Th3_uN1Qu3's Avatar
It was about time for me to change my sig.
Old 02-14-2010, 07:14 PM
kryptonitewhite's Avatar
amen
kryptonitewhite is offline
Old 02-14-2010, 07:40 PM
stgdz's Avatar
So what is the general rule of thumb for db drop off per meter?
stgdz is offline
Old 02-14-2010, 10:38 PM
cavu's Avatar
Loss of what per meter of what??
Electricity in copper?
Sound in air??
In either case, it depends.
If it is sound in air, check HERE.
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
Old 02-15-2010, 05:56 AM
Liked: 57
Assuming a free field (outside) and a device that is small in relation to the wavelength being reproduced (ie not a long line array), you lose 6dB per doubling of distance.
When the device becomes large-all sorts of things start to change.
It is not about lose per meter. but rather a ratio of distances involved.
The loss from 1M to 2M will be 6db, but from 100-101M will not even be noticed.
Danley Sound Labs
Physics-not fads
Old 02-15-2010, 12:43 PM
stgdz's Avatar
stgdz is offline
Old 02-15-2010, 05:49 PM
mjg100's Avatar
Thank you.
mjg100 is offline
Old 02-16-2010, 11:47 AM
Looneybomber's Avatar
Liked: 25
I think there's too many folks with quotes from Ivan in their sigs. Doesn't Penngray also have an Ivan quote?
YID DIY
Looneybomber is offline
Old 02-16-2010, 12:22 PM
Drew Eckhardt's Avatar
thanks ivan that is what I was looking for.
Although the 6dB number is not appropriate for determining SPL in enclosed reverberant spaces like a home theater or concert hall.
If you were in a uniform diffuse field the SPL would not drop 3dB regardless of how far you moved beyond the critical distance.
Unfortunately, that situation is also not applicable.
In practice, real spaces have total SPL 3dB over the direct sound at what would be the "critical distance" and tend to average a 3dB draw down rate per distance doubling.
Drew Eckhardt is offline
