Dual Opposed AV15H Subwoofer Build - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 820 Old 07-18-2010, 09:16 AM
Pure-Evil's Avatar
Liked: 150
Originally Posted by pbc View Post
You could cut the cost by about $500 with a lesser amp, the wood costs a tad with MDF, and I guess use less expensive drivers. The CSX SDX-15" would have been $1k shipped, tax in IIRC, but they are not made anymore and when I was looking they would have been the last 4 apparently. But would have saved another $200 that way.
I had just heard so much good stuff about the SQ of the AV15Hs that I didn't want to cut corners and wonder "what if", so the AV15H's x 2 per sub it was, plus about 800 to 900 watts per driver (1000 watt PE IIRC).
do you think if i swapped out the stock driver from an MFW-15 for an AV15Hs it would work? i bottom my drivers out cause the amps (v1) have too much power for the cheap drivers put into the mfw15's. i have always been thinking about doing that. would it be worth my efford/money? right now i can only turn my gain up to around 11 o'clock, with the better driver i'm betting i could turn the gain up to 3 or 4
Pure-Evil is offline
post #452 of 820 Old 07-18-2010, 11:10 AM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Originally Posted by nith View Post
I didn't take Baltic Birch plywood because it is only 18mm, it is not a truly 3/4".
Are you saying your wood is better than my wood!
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #453 of 820 Old 07-18-2010, 11:15 AM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Thought I recalled your alias, think you had your MFW's up for sale ages ago on Canuckaudiomart and I was curious about how they were performing.
Well, it sounds like the AV15H drivers are being used by Seaton and someone else in their MFW-15 mod (there's a thread for a $750 upgrade with amp and driver IIRC). But I think they had adjusted the T/S parameters of the AV15H somewhat, and of course they have used the Parts Express external 1000 watt amp and supposedly tweaked the parameters of the amp as well.
Hard to know how well it would work without understanding the capabilities of the amp and how the amp in the MFW has been tweaked for that particular driver.
Try modelling the MFW enclosure with the AV15H driver and whatever watt amp you have in that enclosure as a starting point.
pbc is offline
post #454 of 820 Old 07-18-2010, 11:16 AM
nith's Avatar
LOL, no. Thickness tolerance matters, right?
nith is offline
post #455 of 820 Old 07-18-2010, 11:29 AM
Pure-Evil's Avatar
Liked: 150
ya i sold one of my MFW-15's and it's still working perfectly. I still have my 2 Diamond Palisander Rosa though and they work great, but i'd of course like more punch. I have always said the drivers they used were cheap, and i know my amps put out more power than the drivers can handle hence the bottoming out if i turn up the gain. that's why i thought putting in a beefier driver might solve the issue
post #456 of 820 Old 07-18-2010, 11:37 AM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Try emailing John at AE and see what he says. You could also try calling Bob at Creativesound.ca to see how much the TC Sounds LMS-R 15" woofers are (check canuckaudiomart for his listings). Though when I was looking they were at least double the cost of the AV15's.
pbc is offline
post #457 of 820 Old 07-18-2010, 01:23 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
"do you think if i swapped out the stock driver from an MFW-15 for an AV15Hs it would work?"
should work just fine. a mid-low twenties tune with about 5 cubic feet models well. the only question is the amp. the av15's have a pretty low impedance and that can take its toll on some amps. the av15x will give you a little more spl from 30-40hz, but i'd take the av15h with its stronger motor any day of the week.
personally, i don't think the dayton driver has enough motor for a ported enclosure. others will disagree.
Listen. It's All Good.
LTD02 is offline
post #458 of 820 Old 07-18-2010, 01:55 PM
LTD02's Avatar
Liked: 2577
pbc, any post mortem on you build? things you might do differently/advice to others?
LTD02 is offline
post #459 of 820 Old 07-24-2010, 10:14 AM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
LTD02 - will post some thoughts on my DIY when I get a chance. In the mean time, have pulled my front bookshelves off of their wall mounts and am patching up the wall as I'll be placing the S2's on top of the two subs as originally planned. My son is a huge fan of the Cars movie, and we literally watch it almost every day in bluray (he's 3.5 y/o, and can recite almost every line). It's a decent move for testing the SQ with some decent bass passages, and a great song at the end where the credits come up (second song in). Bass sounds great to my ears, literally am amazed at how cohesively the two subs seem to blend with the two bookshelves. Pretty much as if I have truly capable front/left speakers with extension well below 20hz. Much better cohesiveness than the single sub could provide.
pbc is offline
post #460 of 820 Old 07-24-2010, 10:18 AM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
So here are some pics of the final product (as I wait for my patching to dry so I can sand and touch up the front wall!), starting with the original Google Sketchup Design.
pbc is offline
post #461 of 820 Old 07-24-2010, 10:21 AM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
... and with no grills ...
... a single pic of the second sub (terminal cup side)...
pbc is offline
post #462 of 820 Old 07-24-2010, 10:23 AM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Still deciding whether to put on the Paradigm feet or not, thinking I will and maybe use some threaded inserts.
Could they look better? Sure, if you get up close and personal you can see some imperfections, but I'd say overall they look pretty darn good.
Overall, still can't get over just how well they turned out for a first time build.
I think what I'm most disappointed with is the fan noise from the QSC amp, even after the fan modification. Will have to figure something out for that, or maybe move to plate amps at some point.
pbc is offline
post #463 of 820 Old 07-24-2010, 11:13 AM
nith's Avatar
Those look amazing! What kind of stain is that?
nith is offline
post #464 of 820 Old 07-24-2010, 11:19 AM
John_E_Janowitz's Avatar
Quoted: 26 Post(s)
Liked: 81
There will be an upgrade kit for that in the near future. Not offered by myself, but someone is working on it.
john
John E. Janowitz
Acoustic Elegance, LLC
"Learn from the mistakes of others... you can't possibly live long enough to make them all yourself"
John_E_Janowitz is offline
post #465 of 820 Old 07-24-2010, 11:56 AM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
john
Think you meant to post this in Pure-Evil's DIY Questions thread?
Edit: Nevermind ... forgot that he posted that question up above as well!
pbc is offline
post #466 of 820 Old 07-24-2010, 11:59 AM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
See from this post onwards for a few ...
http://www.avsforum.com/avs-vb/showt...7#post18467787
Heed the warning on the stain/dye labels though and wipe off any excess stain/dye after 10 minutes or so!! Would have saved me considerable time had I done that!!
pbc is offline
post #467 of 820 Old 07-24-2010, 12:42 PM
Tom Bley's Avatar
Quoted: 593 Post(s)
Liked: 529
Ha, Ha! You said you applied General Mills dark brown dye stain (coco puffs). You must have had cereal on the brain. General Finishes makes some great stuff.
Tom Bley is offline
post #468 of 820 Old 07-24-2010, 01:23 PM
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
find some used fanless crown k2 amps. I have very good luck with one right now. NO FAN NOISE.
datranz is offline
post #469 of 820 Old 07-24-2010, 02:17 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
+1
Used a K2 for a couple of years, good amp and no fan.
mjaudio is offline
post #470 of 820 Old 07-24-2010, 02:25 PM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
I only have space for 1 amp though, hence why I went with the QSC 5050 for the stereo power (1600 to 1800 watts per CH or something along those lines)..
pbc is offline
post #471 of 820 Old 07-24-2010, 02:25 PM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Ha! Ooops...
Will have to go edit that ...
pbc is offline
post #472 of 820 Old 07-24-2010, 02:28 PM
LTD02's Avatar
Liked: 2577
pbc, yours is one of my favorite builds. if john j. were smart he would find somebody to produce flat packs for your design. that would be a damn hot item.
LTD02 is offline
post #473 of 820 Old 07-24-2010, 03:17 PM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Wow, thanks LTD. I ended up starting my build just before JEJ put out the info on his dual sealed box. Unfortunately (or maybe fortunately as it's a gorgeous design) it's just too large for my family room anyhow, whereas my boxes while still large aren't over the top!
pbc is offline
post #474 of 820 Old 07-24-2010, 10:12 PM
LTD02's Avatar
Liked: 2577
you have a good design...it won't be long before others pick up on it. yours is quite similar to the seaton submersive...another dual opposed 15" design. i'd much rather have what you chose, hence my comment about flat packs from john j.
any regrets other than the time involved with a diy build and the stupid fan (surely this can be fixed)? just a few years ago, the kind of performance that you are achieving would have cost over $10k...
LTD02 is offline
post #475 of 820 Old 07-26-2010, 07:12 AM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
The design was inspired by several subs, including most recently the Empire. But I still just can't fathom how the Empire can be as good as everyone says with the small stamped woofers (possibly nothing wrong with them I guess), relatively weak amp for dual woofers in a sealed enclosure, etc. Maybe he's pulled a rabbit out of the hat and has even more efficient woofers than we know of, but there has to be several design compromises at the price I would think.
Of course the Seaton Submersive, Dennis's dual Av15H sub (think it was Dennis).
Plus, I used to own a "ported" Mirage OM-200 (dual 8" woofers) which I really liked and was dying to own a Mirage BPS-400.
The SQ of my current sub is simply amazing. Was listening to Eagles Hell Freezes Over DTS demo yesterday (auditioning my Onkyo 876 for someone who bought it) and he was amazed at how clean my subs sounded. Kept saying how "boomy" his old 15" Velo sounded in comparison.
I would love to be able to test the low end of this puppy as I keep wondering whether it can keep up with the PB13, but it's so difficult to tell by ear and not sure my Galaxy CM-140 (or most SPL/Mics) is that useful for under 20hz...
pbc is offline
post #476 of 820 Old 07-26-2010, 02:34 PM
LTD02's Avatar
Liked: 2577
i think mr. seaton uses stamped drivers in his submerrsive, but i'm not sure. i'd be really interested to see some measurements on the back of the stamped vs. cast baskets. given their construction, it strikes me that stamped should be pretty solid. if basket strength were a limiting factor, we'd likely see forged baskets, but of course, we don't.
it also seems that lesser quality drivers can be used in sealed enclosures and produce satisfactory results. the stronger the drive, the better the sound, but the point of diminishing returns or other aspects such as inductance linearity begin to dominate past a point.
it is interesting to see that epik and even craigsub's venture tweakcity are both using drivers with stronger motors than what would maximize spl in the sub frequencies and then fixing that with eq. i.e. they are using more 'efficient' drives than they should be.
i must have missed john j.'s dual sealed cab. i'll have to check that out.
LTD02 is offline
post #477 of 820 Old 07-26-2010, 02:48 PM
LTD02's Avatar
Liked: 2577
with respect, i think john j. missed the target on the p1500.
maybe another option, p1500s for "small" would be worth adding to the product lineup.
a dual opposed with 2.5 cubic feet internal that minimizes front area like the epik or depth like the submerrsive. i'd bet there is a larger market for minimizing front area like the epik.
shoot, it's too bad that john j. and chad can't work together. john j.'s drivers in chad's design would be a nice upgrade option for the empire.
LTD02 is offline
post #478 of 820 Old 07-26-2010, 02:56 PM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Although I'm assuming John's box would be the "perfect" size for the stock dual AV15H in terms of cubic feet? If I recall, WinISD modeled a larger enclosure for the dual woofers vs what I had to use due to space constraints.
Edit: though maybe you're simply saying increase the depth and decrease the face ...
pbc is offline
post #479 of 820 Old 07-26-2010, 05:23 PM
LTD02's Avatar
Liked: 2577
there is no perfect.
winisd models q=0.707 at 2.5 cubic feet for dual av15h drives.
john j.'s will give a little more spl from about 40hz down for a given amplifier power. it is a good design if space is not a limiting factor.
we are bucking up against the so-called 'iron law' here. all i was suggesting is that there would be many more buyers for the smaller sub, even if it lacked a couple of db among the deepest frequencies.
LTD02 is offline
post #480 of 820 Old 07-26-2010, 05:43 PM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Agreed, I actually went 2" less deep than I originally wanted to after modelling it out and noticing a less than 2 db loss (think it may have been 1 db). Don't think I could have gone any less deep though, the drivers are fairly close as is, and IIRC Simon at the AE site recco'd around 3 to 4" of air space between the drivers.
pbc is offline
