Diy line arrays!! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 113 Old 04-01-2014, 12:16 PM
WVSyd's Avatar
Liked: 47
Presuming that the resistive shading ( re post #66) is addressing aspects of pattern interference(?)
"Beware of Salesmen: They are the modern Svengali, immune to Science and Reality"
WVSyd is offline
post #92 of 113 Old 04-01-2014, 08:14 PM
Rick Craig's Avatar
Quoted: 80 Post(s)
Liked: 77
Originally Posted by WVSyd View Post
I'm guessing the Ribbons xover had an aggressive slope?
Yes - 96db is possible with the DEQX.
Selah Audio
Thinking Inside the Box...
Rick Craig is offline
post #93 of 113 Old 04-01-2014, 08:19 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5958 Post(s)
Liked: 5003
i wonder if the comb-filtering inherent to line arrays is largely filtered out by our brains.
a typical speaker measured in a room suffers from a lot of "grass" in the high frequencies because of all the reflection-based cancellations, but I'm not sure we hear any of that.
I've always wondered that too. I'd like to think that the environment also would play quite an effect on that brain auto EQ.
Scott Simonian is offline
post #94 of 113 Old 04-02-2014, 03:43 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
Questions for the experts: how does crossover building & design on line array speakers compare to the crossover efforts on conventional 2-way or 3-way designs?
Martycool007 is offline
post #95 of 113 Old 04-02-2014, 04:42 AM
Ivan Beaver's Avatar
Quoted: 16 Post(s)
Liked: 59
Originally Posted by Rick Craig View Post
This new design works quite well Ivan :-)
Works "quite well" in what way?
Do you have measured data?
Danley Sound Labs
Physics-not fads
Ivan Beaver is offline
post #96 of 113 Old 04-02-2014, 06:06 AM
WVSyd's Avatar
Liked: 47
Originally Posted by Martycool007 View Post
...how does crossover building & design on line array speakers compare to the crossover efforts on conventional 2-way or 3-way designs?
With drivers aligned on an axis: The spatial offset of the drivers reduces the effective coupled bandwidth, so the HF crossover has to be lowered.
* Rick utilized an active crossover with a very high slope on a lower frequency point to allow better acoustic integration.
This slope rate could not practically be achieved with passive components.
* Disclaimer: my take on HIS approach cool.gif
WVSyd is offline
post #97 of 113 Old 04-02-2014, 07:45 AM
LTD02's Avatar
Quoted: 2501 Post(s)
Liked: 2835
ivan, i suspect that he is shooting for something like this:
http://www.xlrtechs.com/dbkeele.com/CBT.php
but in a little easier to work with form factor.
Listen. It's All Good.
LTD02 is online now
post #98 of 113 Old 04-02-2014, 09:20 AM
Rick Craig's Avatar
Quoted: 80 Post(s)
Liked: 77
It helps smooth out the vertical response. Here's a link to Don Keele's AES paper for further explanation http://audioartistry.com/Papers/CBT%20Paper6%20PerformanceRankingof%20Line%20Arrays.pdf
WVSyd likes this.
Selah Audio
post #99 of 113 Old 04-02-2014, 09:42 AM
WVSyd's Avatar
Liked: 47
Yeah Rick:
Keele's papers are an invaluable source ( downloaded and read them repeatedly cool.gif )
Didn't want to speak for you - but surmised as much;
As I recall "resistive shading" popped up on occasion in Ed Dell's mags, and Phillips experimented with it as well.
WVSyd is offline
post #100 of 113 Old 04-02-2014, 09:57 AM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 235
Key being ... frequency invariance, that's the good stuff.
Keele is an audio giant.
I've been fortunate enough to have experienced Rick Craig's CBTs, head-to-head up against Synergies, Catalyst', and Noesis, they're great ... and a real effort to mitigate acoustic distortions imposed by the room.
popalock likes this.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #101 of 113 Old 04-02-2014, 10:24 AM
WVSyd's Avatar
Liked: 47
Nice...
RE: Keele selections:
#32 "Implementation of Straight-Line and Flat-Panel Constant Beamwidth Transducer (CBT) Loudspeaker Arrays Using Signal Delays,"
http://www.xlrtechs.com/dbkeele.com/PDF/Keele%20(2002-10%20AES%20Preprint)%20-%20CBT%20Paper2.pdf
WVSyd is offline
post #102 of 113 Old 04-02-2014, 01:29 PM
Rick Craig's Avatar
Quoted: 80 Post(s)
Liked: 77
We can measure many things but sometimes it's difficult to define how audible the results are. This kind of falls into that category.
Selah Audio
post #103 of 113 Old 04-02-2014, 01:44 PM
Rick Craig's Avatar
Quoted: 80 Post(s)
Liked: 77
I've been taking measurements and hop to have everything done in a week or less. I'm not sure if you know but I've worked with Don Keele on some CBT array designs including the largest one ever built
I understand that with pro sound being your main focus that you're often bidding on jobs where others are suggesting line arrays. All speakers have their limitations, regardless of the design - it's just a matter of what tradeoffs you want to make (or what the room dictates). I have heard commercial arrays that sound very good as well as not so good. The same is true with more conventional horn systems and also Danley designs.
Selah Audio
post #104 of 113 Old 04-02-2014, 02:00 PM
WVSyd's Avatar
Liked: 47
So have I - In a couple of cases it was the fault of the operator.
Sometimes one hears a bad review of a system and has an opportunity to hear it in real life, and finds that reviews are not the fault of the system but the failure of the installer/operator.
WVSyd is offline
post #105 of 113 Old 04-02-2014, 07:21 PM
Rick Craig's Avatar
Quoted: 80 Post(s)
Liked: 77
It really depends on the design - some are more difficult and others less complicated.
Selah Audio
post #106 of 113 Old 04-10-2014, 09:22 AM
Rick Craig's Avatar
Quoted: 80 Post(s)
Liked: 77
Here are some of the initial measurements of the Lineoceros. I'm using a DEQX for the crossover but have not applied the room correction.
Scott Simonian likes this.
Selah Audio
post #107 of 113 Old 04-11-2014, 05:08 AM
Quoted: 280 Post(s)
Liked: 181
So you are saying that the space between the drivers, (mid-range or tweeters?) reduces the way the mids and tweeters couple or sum in certain areas of the bandwidth? So the lower the frequency that you crossover the tweeters to the mid-range drivers, the better they will couple or sum to form one wide pattern of sound that the listener perceives as one complete & cohesive sounding speaker? Do I have the basic theory right or am I way off in left field? How does having the HF's crossed over lower affect the coupled bandwidth?
So being that the tweeters have to be crossed so low, is this the reason for the ultra high slope used in the active crossover? If I understand correctly, with a 96db slope crossed at 1200hz the tweeters would be 96db's down at one octave below that at 600hz, thus saving the tweeter from playing lower than it's intended, and keeping the SQ clean with reduced distortion as you would normally have with a tweeters crossover slope being higher at say 6db or 12db. Do I have this part correct as well?
post #108 of 113 Old 04-11-2014, 06:22 AM
WVSyd's Avatar
Liked: 47
You are one the right track in both paragraphs:
The key phrase is "mutual coupling"
See if you use Google Books to get to page 78,79 of
Electroacoustical Reference Data
By John Eargle
Acoustic Summation is not an easy concept to convey
However mutual coupling is a concept in optics and electronics and radio/microwave communication.
http://hyperphysics.phy-astr.gsu.edu/hbase/audio/spk.html
http://www.bnoack.com/index.html?http&&&www.bnoack.com/audio/mutualcoupling.html
http://www.zainea.com/mutualcoupling.htm
WVSyd is offline
post #109 of 113 Old 11-12-2014, 10:07 AM
Satansfx's Avatar
So here we are, 4 years later and still no DIY Line Array was ever built... Why not?
I still have my 3 cases of Sony drivers - and still no design or $$ LOL
Satansfx is offline
post #110 of 113 Old 11-12-2014, 10:11 AM
Bass Enabler
Liked: 5003
Expensive
Not to mention people around here are afraid to build their own speakers that are not from a kit. There are not very many DIY line array 'kits' available.
post #111 of 113 Old 11-12-2014, 10:47 AM
asarose247's Avatar
Quoted: 816 Post(s)
Liked: 621
a set of SLA plans from BFM certainly isn't a "complete kit" except that with the "right attitude"
it IS!
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is offline
post #112 of 113 Old 11-12-2014, 01:59 PM
chrapladm's Avatar
Quoted: 931 Post(s)
Liked: 348
You can always start with a few components and apply a protective Hpass on highs and do a basic lowpass crossover in a sealed cabinet and see how you like it. Then go from there. Trial and error does work well for me.
chrapladm is online now
post #113 of 113 Old 11-12-2014, 02:34 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
Line arrays are just cool.
Mfusick is offline
