Reed Exodus Anarchy 25hz Tapped Horn - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 55Likes
post #451 of 1010 Old 02-17-2011, 12:59 PM
TSIMonster's Avatar
Originally Posted by radman12 View Post
Totally off topic, what bedroom set is that?
My HT:
Denon AVR-2113 Receiver
Mains TBD
Surrounds TBD
Subwoofer TBD (SVS SB1000, NHT B-10d, Rythmik LV12R, Klipsch RW12-D)
TSIMonster is offline
post #452 of 1010 Old 02-17-2011, 04:33 PM - Thread Starter
radman12's Avatar
Liked: 27
its one from "complete suites" they were going out of business so i snagged a nice bed, that dresser and two night stands. i replaced all the hardware though as the original knobs were black and it was all too black for me
most big cities have a "complete suites" store
radman12 is offline
post #453 of 1010 Old 02-18-2011, 10:53 AM
18000rpm's Avatar
I think you'd be better off finding a friend or neighbor with a table saw. The local lumber yard will likely butcher the cuts and they're notorious for being way off on measurements. On this design, you want to be as close as possible. If you can't find anyone with the tools, I'd look up a local wood worker.
Unfortunately, you're probably right, but... I'm still a little lazy, don't have any friends (with tools that is) and time is a bit of a luxury so I just dropped of a cut list to a lumber yard 5 mins from my house. They "promised" it would not be a problem keeping dimensions as tight as 1/16th of an inch. They asked $30 for labor so I think it is worth a shot. The order should be ready for pick up mid next week. Can't wait...
Oh, and according to UPS my Anarchys are out for delivery
18000rpm is offline
post #454 of 1010 Old 02-19-2011, 04:47 PM
Maxjr's Avatar
if your onto the next build...try out the shopsub designed by lilmike, $100 and you got a pounder for your garage.
I'd love to, except I'm not done with my home system. I'm thinking of trying a 10" or 12" single tapped horn next. If it sounds good, build 2-4 of them. Then, move to the garage
Maxjr is offline
post #455 of 1010 Old 02-20-2011, 03:33 PM
VinBau's Avatar
Originally Posted by 18000rpm View Post
What do you guys think? Any suggestions?
Nice increase in spl...
48"H x 21 3/8" x ? width?
regards
-Vincent
VinBau is offline
post #456 of 1010 Old 02-20-2011, 06:39 PM
18000rpm's Avatar
regards
-Vincent
Thanks Vincent,
Outer dimensions are 48" x 21 3/8" x 7". I will try to add a cut list tomorrow or Tuesday in case someone is interested.
Btw, my Anarchys arrived a week after I ordered them, well packaged and in good condition. Not bad since DIY Cable is on the west coast and I am on the east coast.
18000rpm is offline
post #457 of 1010 Old 02-20-2011, 07:28 PM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Thanks Vincent,
Better be wider than 7" on the outside, or the drivers wont fit in there.
lilmike is offline
post #458 of 1010 Old 02-21-2011, 12:45 AM
VinBau's Avatar
OK, at least large enough to fit the drivers then, or is the width an integral part of the formula as well? With the cost of the drivers being so low here, I gather that two drivers in series inside (then @ 8Ohm) also means that two such dual driver boxes in parallel (then @ 4 Ohm again) would be able to handle a lot more power, increasing the spl even further?
One other question I have is this:
If I am mainly interested in reaching 30Hz and do not really care that much for optimizing the parameters for reaching 25Hz, could a TH be designed for a higher spl, or at least avoiding any x-max problems, and maybe even get something like a 30-120Hz instead of a 25-100Hz? I am not requesting any revised designs here, just wondering...
- Vincent
VinBau is offline
post #459 of 1010 Old 02-21-2011, 12:50 AM
VinBau's Avatar
Thanks Vincent,
- I am interested, since I have access to materials and equipment this week for building the original Insubnias, so I only need the dimensions and it need not be a fancy document for starters. If you give me the main dimensions (lengths) I can quickly render a 3D Sketchup drawing for you.
- Yup, things can travel fast these days, my best case was ordering a LCD touch screen overlay in Hong Kong on a Friday that arrived on the following Thursday! - and worked too
-Vincent
VinBau is offline
post #460 of 1010 Old 02-21-2011, 07:06 AM
18000rpm's Avatar
Correct you are LilMike
Correct dimensions should be 48" x 21 3/8" x 8". It had been a looong day.
We are currently finishing our basement and are putting in a gym, bar and a family room/home theater.
We have had a contractor helping us with a lot of stuff, framing, drywall, plumbing, electrical and some trim work but unfortunately he needs to be micro-managed and he also seems to think he is done. He doesn't respond to my emails or voicemails in a timely fashion, shows up only every other week to work for one hour and so. I decided that it is time to finish it my self so we get to enjoy. In the last few weeks I have spent many more hours in the basement than I was planning on. But Hey, at least I can justify buying a lot of new cool tools
On a positive note, building a HT (or at least putting in a PJ with surround sound) is how I found AVS Forum in the first place. I dabbled a bit with speaker builds when I was younger (a lot younger, over half a lifetime ago...) so I am somewhat comfortable in that area but you will probably see me asking noob questions in other threads when I get to controlling all equipment including lights using hopefully only one remote.
18000rpm is offline
post #461 of 1010 Old 02-21-2011, 07:20 AM
Quoted: 3256 Post(s)
Liked: 2743
If you have the speakers in hand what is the overall diameter? From the spec sheet it looks like allowing 7 inches inside is a little tight. I know LilMike's design is 7 1/4 inch.
post #462 of 1010 Old 02-21-2011, 09:36 AM
18000rpm's Avatar
If you have the speakers in hand what is the overall diameter. From the spec sheet it looks like allowing 7 inches inside is a little tight. I know LilMike's design is 7 1/4 inch.
That's a pretty big ooooops Looks like I might have some grinding in my future... Actually, I will probably just route a shallow pocket in the sides of the cabinet to accommodate for the driver overhang. I think my mistake is still small enough that I should be ok.
Thanks for the heads up BIG. At least now I now not to be pi**ed when the drivers don't fit right
This weekend I cut a lot of plexi shelves for our bar and I have been telling myself, measure twice, cut once.... Can't belive I made such a rookie mistake...
18000rpm is offline
post #463 of 1010 Old 02-21-2011, 11:25 AM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Unless the wood's cut already, I'd just cut the interior parts wider.
A quick run through an excel sheet will get you the new values to toss into HR to see if it works OK.
lilmike is offline
post #464 of 1010 Old 02-21-2011, 06:53 PM
18000rpm's Avatar
Thanks LilMike, I have left the lumber yard a voicemail to make the internal pieces 7 1/4" wide. Hornresp gives me an 0.2-0.3 dB increase at 26Hz and 75Hz, 40Hz is virtually unchanged. I doubt I will ever notice.
Either way, it's pretty embarrassing...
18000rpm is offline
post #465 of 1010 Old 02-22-2011, 07:23 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
bump
Any updates on getting these 6.5 horn kits?
Panasonic AE-2000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
vitod is offline
post #466 of 1010 Old 02-22-2011, 07:33 AM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1771
Originally Posted by vitod View Post
bump
From what I understand, they should be getting cut this week if all goes well.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #467 of 1010 Old 02-22-2011, 07:40 AM
cecaa850's Avatar
First and foremost, thanks for "putting this together". I asked in the other thread about a flat pack Lab12. I've PM'd the designer but haven't heard back. Will you eventually work on a design for a 20Hz TH?
120@20@14'
cecaa850 is offline
post #468 of 1010 Old 02-22-2011, 08:04 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Great! What's the basic total cost including driver, shipped? Is shipping a flat rate?
vitod is offline
post #469 of 1010 Old 02-22-2011, 08:05 AM
Erich H's Avatar
Liked: 1771
I think Lilmike is working on some things. But they will be many times bigger than the 6.5" Anarchy.
Erich H is offline
post #470 of 1010 Old 02-22-2011, 08:07 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
I think so. http://www.diysoundgroup.com/Subwoofers.htm
vitod is offline
post #471 of 1010 Old 02-22-2011, 09:10 AM
cecaa850's Avatar
For 20Hz, I would think so.
Staying tuned!
120@20@14'
cecaa850 is offline
post #472 of 1010 Old 02-22-2011, 11:20 AM
3AMRecords's Avatar
I know this might be a little late, but I just checked DIYcable, and they are working on prototyping some new sizes for the Anarchy line.
This could lead to some really interesting design opportunities.
(I'm just thinking out loud here...)
Max
Dual Dayton RSS390HF-4 15" Sonosub Build thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1223658
"You mean, you um, you built those things?"
"Yep!" "Why?" *Power on* "Oh, that's why"
3AMRecords is offline
post #473 of 1010 Old 02-22-2011, 06:45 PM
18000rpm's Avatar
3AM,
I actually asked Kevin at DIY Cable about the 8" drivers a couple of weeks ago and his response was that "the timeline for the new drivers is probably going to be somtime this summer".
Bummer since I was itching to build something right now. But... maybe I need a new project this summer
18000rpm is offline
post #474 of 1010 Old 02-23-2011, 03:23 PM
cecaa850's Avatar
Erich (and lilmike), if you want to cut the Lab-12 TH, it's a go. Here's a copy and paste of Don's reply to me when I asked him about having you guys flat pack his design. It even has his contact info.
Hi cecaa850,
All my designs are public domain. If you want DXF or DWG files, just email me at:
dsnyder1@san.rr.com and request the one you want.
Don Snyder
120@20@14'
cecaa850 is offline
post #475 of 1010 Old 02-23-2011, 03:25 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
That's a bonus!
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #476 of 1010 Old 02-23-2011, 04:09 PM
cecaa850's Avatar
It would certainly save some R&D time on a 20Hz TH.
120@20@14'
cecaa850 is offline
post #477 of 1010 Old 02-27-2011, 01:10 AM
VinBau's Avatar
Looking at that frequency response, which is similar to the Insubnia response, just a tad higher spl... looking especially at the +10/12db ripples at 100, 200 Hz... how much effort will I have to apply to get rid of them? Will a "normal" plate amp like a Dayton 100W crossed in at 80Hz be good enough to avoid them?
-Vincent
VinBau is offline
post #478 of 1010 Old 03-04-2011, 02:22 PM
AudioJosh's Avatar
Quoted: 248 Post(s)
Liked: 227
Did you ever measure the TB in this TH? I saw the modeled comparison, was looking for the measured comparison. I happen to already own 4 of the TB drivers and was wondering if it made sense to upgrade.
JoshK on most other audio forums
Quantity only when quality is ensured.
AudioJosh is offline
post #479 of 1010 Old 03-08-2011, 08:16 AM
DIYHomeTheater's Avatar
Ask and ye shall receive.
Measured 1W 1M SPL is blue, modeled is red.
We measured outdoors over a driveway, so this was not a perfect 2pi measurement by any means. Ambient noise was ~50 dB, so >25 dB down from the measurement levels. This measurement is certainly adequate to verify the performance of the design. We are essentially flat (+/- 3 dB) from 25 Hz to 100 Hz. 2.83 V yields about 86 dB at 1M, which is very close to the prediction.
Drive voltage from amplifier was set at 2.83V into an 8-ohm resistor with my most accurate voltmeter. My equipment is probably accurate to a dB, and should be flat within the area I have presented. Measurements were made with REW using the equipment I have described elsewhere.
I also did a little experiment with HolmImpulse.
Measured SPL and THD:
2nd Harmonic:
3rd Harmonic:
Hmmm, it is a 25 Hz tapped horn design and the THD takes over below that, pretty much as I expected, and exactly as theory predicts. I did not bother with the higher harmonics - they were buried in the noise.
Not sure how to interpret the bottom charts with the green lines. What do each of the two lines represent? There's no legend/key.
Do you have any frequency response measurements in a quiet areas? Apparently the first chart was with ambient noise at 50 dB. Am I missing something? Thanks
DIYHomeTheater is offline
post #480 of 1010 Old 03-08-2011, 09:29 AM
notnyt's Avatar
Quoted: 2156 Post(s)
Liked: 1985
The lower line (for most of the graph) is distortion.
notnyt is offline
