Reed Exodus Anarchy 25hz Tapped Horn - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 55Likes
post #811 of 1012 Old 04-07-2014, 06:00 PM
Anthony_Gomez's Avatar
Quoted: 66 Post(s)
Liked: 187
How are these subs with just a simple 80hz XO like what is typically in receivers? Do the higher frequency resonances cause too much issue, requiring an EQ?
Anthony_Gomez is offline
post #812 of 1012 Old 04-07-2014, 06:07 PM
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
you really need a HPF to cut below 20-25Hz on these per the OP
the receiver LFE setting should take care of everything else above 80 or wherever you set it
Sibuna is offline
post #813 of 1012 Old 04-07-2014, 06:25 PM
Quoted: 66 Post(s)
Liked: 187
ok thanks. I wasn't sure if horns unloaded the same way ported did below tuning.
post #814 of 1012 Old 04-07-2014, 06:55 PM
ejh2854's Avatar
Quoted: 26 Post(s)
Liked: 34
Agreed- these little THs do a good job to surprisingly low, but will make decidedly unhappy noises if you don't protect them from the deepest LFE.
There is no Honor in Mediocrity
ejh2854 is offline
post #815 of 1012 Old 04-26-2014, 11:16 AM
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
Finally finished mine today
some pics
They are back in place where that pic a few posts up showed with these guys sitting on top of them
Sibuna is offline
post #816 of 1012 Old 04-26-2014, 11:35 AM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
laugsbach is offline
post #817 of 1012 Old 04-26-2014, 01:31 PM
pressedmeat's Avatar
Nicely done Sibuna.
Does anyone know if I can use the minidsp to limit the amount of power that my speakers receive? I'm looking at possibly getting an EP4000 now for some future upgrades, but wondered if I could run my 2 anarchy tapped horns off of it...without melting them of course.
pressedmeat is offline
post #818 of 1012 Old 04-26-2014, 02:23 PM
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
Sibuna is offline
post #819 of 1012 Old 04-26-2014, 02:58 PM
moosifee's Avatar
Quoted: 16 Post(s)
Liked: 52
The Behringer iNuke DSP models will do voltage limiting.
moosifee is offline
post #820 of 1012 Old 04-26-2014, 05:58 PM
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
yea im using one for that reason, I got the 1000 DSP which does 150x2 @ 8 ohms, i have it set to ~120 right now
if you wanted to grab a 3000 or 6000 DSP model for future proofing you could do the same limiting with them on these guys without fear of killing them
Sibuna is offline
post #821 of 1012 Old 04-26-2014, 07:17 PM
Not a bad idea, I just hate the idea of getting another DSP having just bought the minidsp not all that long ago. Would the NU1000 (non dsp version) at ~150w x 2 still be too much?
post #822 of 1012 Old 05-01-2014, 04:40 PM
Rypy's Avatar
Well, not long signed up to this site, been looking for a while tho. I'd like to be able to build this horn as my first foray into all this but i dont have the permission to download the pdf. Never mind. Just like to say ive tried hornresp, and it is getting on my goat, very frustrating. Tried to input my driver specs but still get confused. I aint stupid but it sure feels like i am. Anyway, i plan on a horn build for my tv system, and will surely be getting plans for some Bill M stuff for outside. i take my hat off to all and sundry who have built horns and admire those who can use hornresp. If i could, i'd love to be able to model a woofer i have just to see if it could work in a horn. Please, can anyone tell me if i need to use hornresp to model the driver, then use this sketchup to design it? is that the way she goes? Sorry, just trying to clarify, im doing my best and will not be happy at all until i have a grasp on all this. I know this is off topic so my apologies to the old faithful. I admit i am getting desperate lol. And if anyone is interested the driver i have is a pioneer tsw 309 d4, have 2 actually, sittin around doing nothin, would love to put them to use doing something, anything. Thanks and apologies once again.
Rypy is offline
post #823 of 1012 Old 08-11-2014, 10:41 PM
AVT
Liked: 0
Does this horn need a steeper low pass filter than 12db/octave? I am concerned about the big peak near 110hz, here's what Hornresp shows:
AVT is offline
post #824 of 1012 Old 08-19-2014, 02:38 PM
DizRotus's Avatar
I love these subs so much I purchased a second pair. The first pair is operational, but unfinished. The second pair, also operational, is near to being finished in Duratex. At that time, they will be switched for the first pair so that pair can be finished in Duratex.
With help from "Lilmike" I modified two used Dayton 240 plate amps. One worked flawlessly, but one did not work properly. A call to Parts Express (PE) brought advice to send it to PE, which I did. An accompanying note described the history and requested help, authorizing the tech to dispose of it if not fixable or worth fixing.
Shortly thereafter I received an email advising the unit was repaired. I need only pay $11.46, the return shipping cost. The amp now works perfectly.
PE is a great company with which to do business. Send most companies a defective, discontinued, modified product that had been purchased used and they would suggest an unnatural act for you and the product. PE is a great asset to the DIY fraternity.
DizRotus is offline
post #825 of 1012 Old 09-05-2014, 04:01 AM
teddytusen's Avatar
And we're off! Havent startet gluing yet, but all the cuts for two horns are done.
teddytusen is offline
post #826 of 1012 Old 09-19-2014, 11:37 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
What is the cost on the drivers for these?
Total cost of the project?
I need a sub for my PC.
Mfusick is offline
post #827 of 1012 Old 09-19-2014, 01:04 PM
CodyO's Avatar
Driver: ~$74 from diysoundgroup.com
Sheet of 1/2" Plywood (sandply): ~$40 from HD
Glue, Stain/paint, finishing: ~30
Amp: Dayton SA100 $90 here at parts express
HPF for 20 HZ: $25 from parts express
Total: 258
I don';t have any experience with the FMOD's yet. Maybe someone else will chime in regarding a HPF option.
CodyO is offline
post #828 of 1012 Old 09-19-2014, 01:50 PM
wormraper's Avatar
Quoted: 325 Post(s)
Liked: 176
Total: 258
The spa 100 plate amp should already have an hpf built in I believe
wormraper is offline
post #829 of 1012 Old 09-19-2014, 04:14 PM
CodyO's Avatar
I can't seem to find any info on whether it does or doesn't. I don't think it matters for most setups, but the guys here are strongly recommending a HPF for this driver.
CodyO is offline
post #830 of 1012 Old 09-30-2014, 10:06 PM
Liked: 0
What mains would work well with this sub. In my setup I'll need to stack the mains on top of the tapped horn, so something about the same width would be preferred.
tunafoot is offline
post #831 of 1012 Old 10-01-2014, 05:54 AM
ejh2854's Avatar
Quoted: 26 Post(s)
Liked: 34
While they aren't stacked atop one another, I'm using 2x of these THs with Fusion4 Quad-4 LCR in a smallish room and think they're well-suited to this match; the TH is just over 8" wide, and the F4Q4 just under 6" so your plan could come together pretty readily.
ejh2854 is offline
post #832 of 1012 Old 10-01-2014, 08:14 PM
CodyO's Avatar
The fusion 6's would also fit, and although they aren't finished yet, I imagine that the Volt 6" Coxail would also wind up being the same width. It really comes down to the width of the driver, anarchy is a 6" (ish) so look for speakers that use a 6" driver or less.
CodyO is offline
post #833 of 1012 Old 10-01-2014, 08:20 PM
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
Sibuna is offline
post #834 of 1012 Old 10-07-2014, 12:20 PM
teddytusen's Avatar
Wow... What can I say. Not often I get surprised anymore, but today was one of those days. Built it about a month ago, but havent had the time to test. Today I was home alone, and hooked it up. RF-3 mains and just an Rotel 976 to power it (150w bridged). How the he-double hockey sticks is this possible? I see more TH in my future.
DizRotus likes this.
post #835 of 1012 Old 10-14-2014, 10:43 AM
Chesafreak's Avatar
Looking to put a pair of these into a cabinet. Would there be any ill effect to the tuning if I were to close off the current opening and open a new one into the bottom adjacent to the current opening?
Chesafreak is offline
post #836 of 1012 Old 11-17-2014, 01:30 PM
pitviper33's Avatar
Quoted: 267 Post(s)
Liked: 116
Hey all. I've scanned through the whole thread, and I didn't notice any discussion around these two points.
1. Any issues with turning this sub on its side? Meaning the opening would be facing either up or down and the driver mounting plane would be horizontal. I know horizontal mounting isn't really good for any driver, but some handle it better than others.
2. How's the vibration on these at full tilt? I suspect with the small driver and relatively heavy enclosure, it's minimal. But I'd love to hear from somebody that's using one.
I'm thinking of building a pair of these as narrow end tables for our family room where WAF is high priority. The unusual orientation mentioned above is to get the height right (after the addition of some feet). The vibration concern is to make sure they function well as tables. WAF plummets if her wine glass plummets.
pitviper33 is offline
post #837 of 1012 Old 11-17-2014, 01:45 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
No, orient however you need to. You just need to keep the mouth a few inches away from a wall or other obstruction.
Very little vibration that I have noticed. You can always widen the base if you are standing on end.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #838 of 1012 Old 11-17-2014, 02:35 PM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
I am using three ATH this way for the same reason...no problems at all with moderate to high levels while playing music. Wine glasses stay put as well...
post #839 of 1012 Old 11-17-2014, 02:54 PM
pitviper33's Avatar
Quoted: 267 Post(s)
Liked: 116
Thanks both of you for the info. Laugs, got any pictures? You might help me sell the idea!
post #840 of 1012 Old 11-17-2014, 04:08 PM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
I don't but I could take one for you...
They are "naked" at the moment...the wife has been slow to suggest a color!
