21" Maelstrom Curved Box Build - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #721 of 743 Old 04-16-2013, 03:56 PM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
"Ricci measured..."
those are 2 meter measurements, so add 6db if comparing to winisd which is 1 meter model. then add 6db for two subs and power.
Listen. It's All Good.
LTD02 is offline
post #722 of 743 Old 04-16-2013, 04:25 PM
brian6751's Avatar
Quoted: 1168 Post(s)
Liked: 1140
Originally Posted by bass addict View Post
GEEZ. i thought my 14DB was a lot!
That's not science! - Cyborg
FOR SALE: nothing at the moment
Rivers Edge Theater
brian6751 is offline
post #723 of 743 Old 04-16-2013, 05:07 PM
MoFinWiley's Avatar
"Ricci measured..."
Yeah, it works out to a little over a 1db more for the 21 vs two SVS13's....which seems like a wash, which certainly doesn't seem like the SVS should be doing a "much better job"
MoFinWiley is offline
post #724 of 743 Old 04-17-2013, 02:42 PM
noah katz's Avatar
Quoted: 1107 Post(s)
Liked: 387
possibly the low bass may be MIA if there's no EQ
Noah
noah katz is offline
post #725 of 743 Old 04-17-2013, 08:20 PM - Thread Starter
corock's Avatar
Lets me start with...This thread got me back into audio...
But, I have to say that I'm surprised it doesn't dig deep enough for HT? I'd love to see measurements
Let me also say that I now have two of these drivers, and they dig pretty deep. I am only running ~300 watts to each driver, but my enclosures are about 15 cu. ft. each.
The EQ'd measurements are post 619 on page 21.
http://www.avsforum.com/t/1238601/21-maelstrom-curved-box-build/600
It is reaching lower than I thought. I just know that some points in a movie will cause the sub to make terrible sounds. It could be because I have no filter for the really low signals. 7 cubic ft is a small enclosure for this driver. I don't worry about it because i built it for music. As well, I also built it as a piece of art and have it sitting in my living room instead of hidden in the dark home theatre.
corock is offline
post #726 of 743 Old 04-18-2013, 01:44 PM
noah katz's Avatar
Liked: 387
Originally Posted by corock View Post
Are you sure it's not the amp clipping?
Noah
post #727 of 743 Old 04-18-2013, 02:35 PM
BassThatHz's Avatar
Quoted: 2383 Post(s)
Liked: 2155
The roll off at 15hz is not by design, but I would assume it's due to the small sealed enclosure. 7 cubic feet is as small a box as this driver can be realistically be packed in. I wouldn't be able to eq it flat to 10 hz, it would demand way too much of the amp, which is an ep4000. Not to mention rew only eq's down to 20hz. I'm not concerned about going lower any way. I built this sub to be dedicated to music. I'm building a basement home theater this winter and my dual PB13's will handle the movie duties.
It's making terrible sounds because that amp is way-insufficient, even bridged.
However 1 ch of an FP14k would be more-than sufficient, but no less.
I used to run my 21's on EP4k's, and then I switched them to clones. I'd never go back. Difference is night and day.
If I recall correctly it took about 9db more gain below 20hz to get the same response as my LMS 18's does in the same sized box.
BassThatHz is offline
post #728 of 743 Old 04-18-2013, 05:09 PM - Thread Starter
corock's Avatar
I hadn't even considered that the sub might be under powered by the EP4k. It would make sense that the gain in the lower regions could cause it to clip. I might have to investigate this FP14k you speak of; I haven't even looked at alternatives before.
corock is offline
post #729 of 743 Old 04-18-2013, 07:09 PM
BassThatHz's Avatar
Liked: 2155
Here's the first excursion vid I've made of my 21's powered by a clone, at half-power.
At full power, it would rip this driver apart. As you can see.
post #730 of 743 Old 11-07-2013, 06:29 PM
Lonely Raven's Avatar
Quoted: 34 Post(s)
Liked: 42
I still have my 21" Maelstrom, and I'm looking for a second one (or that new IS 24") to add some pressure to the room.
Where does one purchase a clone from? Are there any other, more reliable, but still inexpensive options out there?
Lonely Raven is offline
post #731 of 743 Old 11-07-2013, 09:37 PM
LTD02's Avatar
Liked: 2888
not sure if this is something that you are looking for:
http://www.istonline.ca/mach5_ftw_21.html
LTD02 is offline
post #732 of 743 Old 11-09-2013, 03:16 PM
Quoted: 34 Post(s)
Liked: 42
Sorry, I was tired and should elucidated.
I was talking about that 14000 amp. I've heard of the clone amps, but I've never seen one for sale anywhere.
post #733 of 743 Old 08-19-2014, 06:48 AM
PHN2's Avatar
Awesome build, and great skills.
Did you have any problems with cracking of the walls? Others have experienced problems with translam-builds:
PHN2 is offline
post #734 of 743 Old 08-19-2014, 07:12 AM
Quoted: 34 Post(s)
Liked: 42
Wow, I wonder where all that tension is coming from that caused that to tear the plywood!
I know from experience, that if you clamp projects improperly, they will hold, but they are constantly under tension.
When I was 20 I made a chess board out of maple and walnut. I cut all these little scraps and glued them together - it was really beautiful. The cuts were slightly off here and there, and I corrected it by squeezing them into place with the clamps. It made sense at the time, but one really hot day I had the chess board in the back seat of my car, and had to slam on the brakes because someone cut me off; the board slid off the back seat and hit the floor of the car, then broke with a sound like a gunshot splitting up one of the glue lines (the wood cracked, not the glue).
That's my guess as to what's happening here.
post #735 of 743 Old 09-12-2014, 10:11 AM
PHN2's Avatar
That particular project used steelrods going through the sides. People on the other thread thought those were the cause of the cracks, since the rods would not ajust to the wood, when moving under temperature and moisture shifts.
PHN2 is offline
post #736 of 743 Old 07-22-2015, 03:20 PM
edwardccm's Avatar
Sorry to be rehashing this thread but do you still happen to have the plans or template for Sketchup that you originally used. I will be attempting to do a simmilar build with a 15 inch driver and it would be great of great help if you had your originals still.
edwardccm is offline
post #737 of 743 Old 07-23-2015, 08:13 PM - Thread Starter
corock's Avatar
No I don't have any of the plans. There wasn't anything significant about them that couldn't be recreated. I just used Sketchup to come up with the design as a visual reference so that I could wrap my head around how to create it. And then I used it to create a picture for the curve so that I could print it off and use that to draw the curve onto the wood. Cutting each piece of plywood a different size to create the cylinder was just a little math. If you need any assistance on how to go about that feel free to send me a message anytime. I've helped a couple of guys out. I don't know if anyone actually built another one though.
corock is offline
post #738 of 743 Old 07-26-2015, 03:10 PM
LitoGeorge's Avatar
Quoted: 53 Post(s)
Liked: 56
Corock, I thought I have to complement you on your final outcome. Your rendering of the faceplate + granite top was simply sublime.
I do hope you get your faceplate, it is the finishing touch, the cherry on top. Screw that prick in Edmonton.
LitoGeorge is offline
post #739 of 743 Old 10-17-2015, 02:17 PM
Iron Maiden's Avatar
Quoted: 537 Post(s)
Liked: 208
No question my favorite build simply because of the amount of work involved. The amount of hand work and love that went into it is a thing of beauty.
I want to find that Azzhole who took your faceplate and beat the living chit out of him for not allowing you to realize your final vision of this sub. I'm sure you explained to him what it was for and what had went into it. Makes me sick to think someone could just disregard that and never respond to you. He could have at least returned it. I'm not ashamed to say I hope he died and that was the reason you never heard back from him!!!
What an awesome build! Thanks for wasting an entire morning/afternoon reading through ths entire thread!!!! LOL I couldn't stop reading it!!!
I'm gonna ask a question on the other thread you have on this sub. A bit more appropriate on that thread than this one.
60" Panasonic Plasma ~ BenQ HT1075 / 92" Screen~Onkyo TX-NR3008(Pre/Pro)
Earthquake Cinenova Grande Amplifier ~ Oppo BDP-103 ~ Xbox One & PS4
Musical Fidelity Tri-Vista Tube DAC ~ Monster Cable Signature Series HTPS7000
Energy Veritas V2.3i (mains)~Veritas V2.4i (Front Wides)~Veritas V2.2i (center)
Energy Veritas V2.1 & CAT Tiburons(Surr)~Subs: 2 FTW-21's~Fp10000q clone/2x4dsp
Iron Maiden is offline
post #740 of 743 Old 10-27-2015, 08:43 AM
16hz lover's Avatar
Quoted: 55 Post(s)
Liked: 66
It took me only 2 songs to blow up one of those subs. Felt bad about going to someones house and cooking their woofer, but it simply had its limits.
Earth: The Insane Asylum of the Universe, nowhere else could things be this screwed up.
16hz lover is offline
post #741 of 743 Old 10-27-2015, 12:01 PM
Quoted: 537 Post(s)
Liked: 208
The Mal 21 or the FTW?
Pretty generic statement when we have no clue what kind of enclosure it was in. What amp was pushing it. What kind of DSP was applied.
Could have 100% been user error and the reason it blew. Any sub will blow if not uses properly. There are guys on this forum using full power from Fp14K's to them with no problems.
post #742 of 743 Old 10-27-2015, 08:55 PM
16hz lover's Avatar
Quoted: 55 Post(s)
Liked: 66
Mal 21. not user error, this was back when they had serious build quality issues and had lots of failures with the spiders
Iron Maiden likes this.
post #743 of 743 Old 10-28-2015, 11:02 AM
Quoted: 537 Post(s)
Liked: 208
Thanks for clarifying which sub. Was it ported or sealed?
I'm about to get two of the FTW's so glad to hear it was the "other" 21's you were dogging. lol
