Official Rythmik Audio DIY Subwoofer Kit thread - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #391 of 403 Old 02-18-2016, 01:51 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
Originally Posted by bob_m10 View Post
I was looking over the plans for the DS1200 for down firing sealed configuration. The baffle is made of two layers, why do we need to recess the driver and attach to the inner baffle? Why not just cut the same size hole in both baffles and mount to the outside. Since it is down firing you will never see the driver? Bob
The recessed driver mounting is just for aesthetics, a carry over from the design of the front-firing enclosure. Mounting the woofer on a double-thick baffle is actually better, it being less resonant and that resonance at a frequency further above the passband of the driver, than that of a single baffle thickness. Just make the legs an extra 3/4" or so taller to compensate. I built my front-firing enclosures with double-thickness baffles (1.5") and the woofers recessed into a third 3/4" layer of MDF, just to make sure!
BDP24 is offline
post #392 of 403 Old 02-18-2016, 05:31 AM
bob_m10's Avatar
Quoted: 86 Post(s)
I think I am may do that, put them both together and cut one large hole. I have read that if I do that, I should chamfer out the back of the baffle a bit to allow good air flow around the back of the driver, does that make sense?
With the jasper jig, could I actually dado out say 1/4" of the top baffle by using increasing larger circles?
bob_m10 is offline
post #393 of 403 Old 02-18-2016, 07:56 PM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
Yep, the Jasper will do that, but if you mount the woofer with the rubber flange ring removed, the recess should be 3/8" deep rather 1/4". With the ring left on, I believe it needs to be 1/2" deep. For the backside, at subwoofer frequencies a chamfer is not necessary, but doesn't hurt either, so why not!
BDP24 is offline
post #394 of 403 Old 02-23-2016, 05:34 AM
bob_m10's Avatar
Quoted: 86 Post(s)
Thanks for your help, can you verify that the cutout for the 1201 is 11-3/16"? Bob
bob_m10 is offline
post #395 of 403 Old 02-24-2016, 07:43 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
Sorry, no. I just moved 1100 miles, and all my stuff is in storage at the moment. An email or call to Rythmik should get you that info.
BDP24 is offline
post #396 of 403 Old 05-31-2016, 05:06 AM
dlynch34's Avatar
Quoted: 308 Post(s)
Liked: 132
Has anyone built a 1501 kit with the HX800 amp? I have built 2 enclosed cabinets with this kit and seem to be having some confusion on the wiring of this particular amp. I am just curious if anyone else has any experience with particular amp?
Don
Anthem AVM-60,Sunfire Cinema Grand Signature Five-Channel Power Amplifier, Emotiva XPA-1l x2,Outlaw 5000. Rhythmik DIY 15inch x2, Plus, Magnapan 3.7i, Magnepan CC5,Magnepan MC1,JVC RS400, DIY 125" 2:35 Elite Screen cinegray 3d .
dlynch34 is offline
post #397 of 403 Old 07-25-2016, 03:38 PM
Liked: 0
There is a discrepancy on the sealed DS1200 plan. For the driver cutout, one sheet calls out 11 3/16" and another calls out 11 3/8". Does anyone know which is the correct dimension?
AuralFission is offline
post #398 of 403 Old 07-28-2016, 12:14 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
3/8".
BDP24 is offline
post #399 of 403 Old 04-02-2017, 03:11 PM
wreckingball's Avatar
Quoted: 170 Post(s)
Liked: 74
This was a late 2016 build, a pair of FVX-15 kits...was a lot of fun.
Pics are of various stages of completion, the round one is sealed, and made of all maple ply ~16mm thickness. 1.5" baffle and cap made of Baltic Birch
The other obviously ported and made of all 18mm Baltic Birch.
Both subs are downfire (now), tucked away nicely into two corners of main-floor HT.
Couldn't decide, so I built one sealed and one ported, it may stay that way, as I like just the one sealed while playing music, and both on during movies.
Aesthetically, I may sand down the black ring on cap of sealed sub, should have stayed with the cherry stain on that... I'll fix that this spring.
The direct servo works just as advertised, subs start, and more importantly, stop on a dime, even the ported one.
Cheers
ID:	2064337   Click image for larger version
ID:	2064345   Click image for larger version
ID:	2064353   Click image for larger version
ID:	2064361   Click image for larger version
badgerpilot likes this.
Actually, I love tube amps..
I play guitars through them.
wreckingball is offline
post #400 of 403 Old 04-02-2017, 03:29 PM
badgerpilot's Avatar
Quoted: 75 Post(s)
Liked: 45
Cheers
^^^^Beautiful craftsmanship 😁👍🏻
wreckingball likes this.
badgerpilot is offline
post #401 of 403 Old 04-04-2017, 06:56 AM
bob_m10's Avatar
Quoted: 86 Post(s)
Cheers
Nice job!
bob_m10 is offline
post #402 of 403 Old 05-12-2017, 04:16 AM
mxl160's Avatar
Liked: 1
Cheers
Excellent craftsmanship!
mxl160 is offline
post #403 of 403 Old 05-12-2017, 12:00 PM
Fatawan's Avatar
If anyone in the Chicagoland area is thinking of building the 15" version of these Rythmik subs, I have two enclosures that I built way back that are free for the taking. They are baltic birch with MDF laminated on the outside. These have a primer on them.
ID:	2132769   Click image for larger version
Fatawan is offline
