Difference between two amps.. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-30-2010, 04:44 PM - Thread Starter
Kanaris's Avatar
I picked up an old QSC 1400 amp...cleaned it up..and wanted to see if it's okay..so I switched my Crest CPX2600 for it on my 2xTHT's and to my amazement they sounded different.... at the same volume level the sound sounded like it had more bass... Now I know the Crest is rated at about 750 per side in 4 oms and the QSC 300.... So my question is ..'is it my imagination or something is happening? Granted I was always scared to crank the Crest fearing I would blow something... but still... Maybe those old "made in the USA' amps were underated or something...
Kanaris is offline
post #2 of 8 Old 03-30-2010, 04:56 PM
penngray's Avatar
Liked: 43
can you measure the response for each of them and post it? It could show if the QSC has a filter or something.
penngray is offline
post #3 of 8 Old 03-30-2010, 05:27 PM - Thread Starter
Kanaris's Avatar
I'll do that this weekend.. cause my stuff is not setup..
I think you are correct... in saying there's a filter in there.
When I got the Crest playing the subs are more omnidirectional with the QSC they stick out more.
Kanaris is offline
post #4 of 8 Old 04-02-2010, 06:01 PM - Thread Starter
Kanaris's Avatar
I took a couple of sweeps..
This is with the Qsc..
This is with the Crest
This is with the meter close to the throat area...
These are two THT's with their throats attached...
Kanaris is offline
post #5 of 8 Old 04-02-2010, 07:48 PM
Speedskater's Avatar
Quoted: 20 Post(s)
Did you move the mic or the sub between the above sweeps?
What do the sweeps look like at a more reasonable level?
Kevin
Speedskater is offline
post #6 of 8 Old 04-02-2010, 07:51 PM - Thread Starter
Kanaris's Avatar
I can't move the subs.... and the mic was at the same place.
The only thing I might of fudged up is I had the window open .... and it might have picked some noise up.
Kanaris is offline
post #7 of 8 Old 04-02-2010, 07:57 PM
Quoted: 20 Post(s)
You were hitting almost 120dB! How much more noise could come in the window?
Redo your sweeps at low volume (90 or 95dB) and at high volume.
Which ones look similar?
Kevin
post #8 of 8 Old 04-03-2010, 11:37 PM
whoaru99's Avatar
Liked: 69
"At the same volume level..." do you mean same measured volume level, or same volume knob setting?
If it's the latter and the two amps have different gain, that might explain the perception of more bass because an amp with higher gain will play louder at any given volume setting.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
