displacement and sensitivity - AVS Forum | Home Theater Discussions And Reviews
Old 04-03-2010, 02:35 PM - Thread Starter
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
lets say, i want to build a mtm speakrs, my mids are zaph audio 5", rated at 87db/1w. If i use 2 in a mtm config, would the sensitivity of the system increase to 90 db/1w? I ask because i am hoping to use this w/ a ribbon cross at 2.5K. The ribbons at 96db/1w.
datranz is offline
Old 04-03-2010, 02:38 PM
gooki's Avatar
Yes at 1 watt input you would see an increase of 3db.
International HDDVD Screenshot Archive (Full 1080p Images): www.hdmovies.co.nz
gooki is offline
Old 04-03-2010, 02:52 PM
Bill Fitzmaurice's Avatar
Liked: 4668
Yes and no. The half-space 1w sensitivity would go up by 3dB. But below the baffle step frequency you're not going to get 90dB, it will roll off down to 84dB.
One of the reasons for the MTM is baffle-step compensation. If you have an 8 ohm 87dB tweeter, for instance, and a pair of 8 ohm 87dB midbasses and you configure the crossover and baffle step correctly you can end up with 87dB/2.83v throughout the speaker bandwidth.
In your case if you want to get that 90dB/watt full bandwidth you'll need to find a way to keep the midbasses in half-space, such as wall mounting.
Bill Fitzmaurice is online now
Old 04-03-2010, 03:28 PM
LTD02's Avatar
Quoted: 2343 Post(s)
Liked: 2581
speaker sensitivity is limited by the lowest sensitivity driver in the system (more or less). mating a high sensitivity ribbon to a pair of low sensitivity drivers might not be the best option. 18sound has a high sensitivity 8", 8nmb420 iirc...yes, here it is:
http://www.eighteensound.com/index.a...roduct&pid=256
that might come really close to a sensitivity match and that will have many other benefits that i won't argue here.
Listen. It's All Good.
LTD02 is online now
Old 04-03-2010, 03:34 PM
Looneybomber's Avatar
Liked: 25
8" woofers in an MTM and a ribbon in the middle will likely have the CTC spacing of the woofers at 10-11". How do you make that work with a crossover point of 2500hz?
YID DIY
Looneybomber is offline
Old 04-03-2010, 04:11 PM
LTD02's Avatar
Liked: 2581
the 8" that i pointed to has about the same sensitivity as the ribbon, so no need for an mtm design...just a simple tm should be fine.
edit: but crossing a little lower would still be advised, as the 8" may be beaming more than the ribbon at 2.5khz.
LTD02 is online now
Old 04-03-2010, 05:34 PM
penngray's Avatar
Liked: 43
Is this your G3 ribbon project? Great price on those
If you want to stick with the comercial designs maybe the SB Acoustics drivers with their > 90 dB sensity.
But my choice would be the new TD6M from John @ AE speakers. I believe they will be shipping at the end of April ($150/each initial "preorder" soon).
penngray is offline
Old 04-05-2010, 06:36 AM
MBentz's Avatar
Quoted: 24 Post(s)
Liked: 43
Amplifiers are essentially voltage sourcing devices so when you put two speakers in parallel, the impedance halves and you get double the power for the same input voltage.
So, if your speakers are 8ohm nominal, then your sensitivity spec is for a 2.83V input. When you hook the speakers in parallel, your amplifier will put out 2W, and thus so you will end up with 93dB SPL. So if your ribbon is 96dB for a 2.83V input, then your woofers will only be 3dB down.
Ribbons tend to beam quite a bit as you go higher in frequency, so you might consider going with a gentle shelf filter to pad down the lower levels of the ribbon by ~3dB and leave the highs tipped up a bit (to get back to a flat power response in the room). If you're clever with the xover design, then you might be able to do this with just one additional cap...so not a huge cost. Worst case you'd need to add a capacitor and a resistor.
Another thing to keep in mind is that in order to get more sensitivity from another driver, either the cabinet needs to get larger, or you need to accept less low frequency extension...Hoffman's Iron Law.
-Mike Bentz
~It's all about compromise~
MBentz is offline
Old 04-05-2010, 06:46 AM
MBentz's Avatar
Quoted: 24 Post(s)
Liked: 43
That doesn't tell the whole story...unless you're outside in an open field.
In a typical home setting, if your front baffle is relatively close to the front wall (as if often the case), then you don't have any baffle step issues to deal with. Flush mounting on an infinite baffle would be the extreme scenario of this behavior, and that's how the drivers are measured (in the engineering world at least).
In fact, anywhere the system polars are wide enough (and the boundaries are close enough to not comb-filter), then you could even see 93dB or even up to 99dB depending on speaker position. That's also assuming the walls are perfectly reflective, but that's never the case.
If you're going to pull the speakers way out into the room, then I would recommend choosing a wide Q porting alignment and turning a bit high...and then you don't need to pad anything down and waste precious amplifier power (or really, voltage swing in this case). But then you better sit really close so that the comb-filtering doesn't dominate. I'd say a rough rule of thumb would be about half the distance of the shortest reflection path...so maybe 3ft or so? So basically a studio monitor configuration.
-Mike Bentz
MBentz is offline
Old 04-05-2010, 06:50 AM
MBentz's Avatar
Quoted: 24 Post(s)
Liked: 43
Technically that's too high for even a pair of 5" too if you want to match polars.
I suppose they could always be splayed to fire wider on the front baffle to help keep the DI down.
Bose Panaray?
-Mike Bentz
MBentz is offline
Old 04-05-2010, 09:19 AM - Thread Starter
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
thanks everyone for replying with so much info. Its almost too overwheming. But i will find my way to comprehend everything since i like this hobby enough. Got to start somewhere.
datranz is offline
Old 04-05-2010, 10:01 AM
kbgl's Avatar
Two 5 ohm resistors will reduce the ribbon output to 87 dB. Different resistor values will let you adjust up or down from there if needed. The 96 dB sensitivity is not an issue at all. The required 2.5k x-over point is an issue, and will mean that the midbasses need to be very clean to 3k or higher for the best results.
Can your amp handle a 4 ohm speaker load?
kbgl is offline
Old 04-05-2010, 10:17 AM
kbgl's Avatar
These Peerless 5.25" HDS drivers are about $29 each. A sealed .6 cu-ft box (.3 cu-ft per woofer) should have an f3 of 84 hz.
http://www.parts-express.com/pe/show...TOKEN=17686603
kbgl is offline
Old 04-05-2010, 11:51 AM - Thread Starter
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
this will be my music only system. I am thinking of an emotiva upa 2 amp w/a sub crossed at 80hz. my reason with 2 mids is because i want it to be at least 100db at 9ft away.
datranz is offline
Old 04-05-2010, 11:53 AM - Thread Starter
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
thats a great price, ordered 4. thanks man.
datranz is offline
Old 04-05-2010, 12:33 PM
kbgl's Avatar
For the record, I haven't used those drivers, but they look good based on the specs. I've been very pleased with two other Peerless HDS drivers that I have used.
I think you will be happy with them, but dang that was a quick decision!
You might need more than two for that kind of SPL. Might be a good idea to port them. Box will need to be bigger though I think. Maybe someone can model the response for you.
Specifications: *Power handling: 110 watts RMS/155 watts max *VCdia: 1" *Le: 0.8 mH *Impedance: 8 ohms *Re: 5.36 ohms *Frequency response: 57-7,000 Hz *Fs: 58.5 Hz *SPL: 87 dB 1W/1m *Vas: 0.31 cu. ft. *Qms: 4.32 *Qes: 0.56 *Qts: 0.49 *Xmax: 3.5 mm
kbgl is offline
Old 04-05-2010, 12:54 PM - Thread Starter
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
well, the spec looks pretty good up to 5k. i was also kinda looking at the zaph audio 5" but this has a higher power handling.
datranz is offline
Old 04-05-2010, 01:03 PM
kbgl's Avatar
How big is your room? How much more than 100 dB are you after?
There's two kinds of power handling. One is thermal. I think these may be good there due to the copper voice coil, and venting. The other is excursion. These drivers should be pretty clean at 3mm excursion, but I don't know how loud that will be. Ported should get you a couple more dB than sealed at the same excursion.
kbgl is offline
Old 04-05-2010, 01:33 PM
Drew Eckhardt's Avatar
The sensitivity will increase 6dB if they're wired in parallel and 0dB for series.
The efficiency in both cases will increase 3dB.
Drew Eckhardt is offline
Old 04-05-2010, 02:34 PM - Thread Starter
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
well, i dont think i will listen that loud but its nice to know i can get there.
datranz is offline
Old 04-05-2010, 02:35 PM - Thread Starter
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
thanks.
datranz is offline
