amp choices for active speakers - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 44 Old 06-20-2010, 12:56 AM
DL86's Avatar
|sidebar|
dl86, did you ever get your horn sub time aligned? i'm curious to know if after time alignment if it adds much beyond your direct radiating 18 sound sub.
Yes, everythings working great, has to be the best bass I have heard in my room, very defined. Death metal sounds absolutly sick, drumming comes through great.
I had to get rid of the filter on the THT it was causing a weird FR in room. The THT is definately more efficient overall and can play deeper than the 18 sound with less THD.
I also got rid of the harshness in my mains with a new crossover design.
To improve the black level performance of your projector: Shine bright light into your eyes every 5 minutes.
DL86 is offline
post #32 of 44 Old 06-20-2010, 01:13 AM
LTD02's Avatar
Quoted: 2350 Post(s)
Liked: 2587
what delay are you running on the tht in order to time align it with your mains?
Listen. It's All Good.
LTD02 is offline
post #33 of 44 Old 06-20-2010, 01:19 AM
DL86's Avatar
I am not running any delays in my system, apart from the distance setting in my receiver which is set at 14ft for all of my 3 subs.
Eagerly awaiting the Integra 40.2
DL86 is offline
post #34 of 44 Old 06-20-2010, 01:25 AM
LTD02's Avatar
Liked: 2587
14 ft seems about spot on for the tht.
i was thinking time alignment might be an issue, but apparently not.
LTD02 is offline
post #35 of 44 Old 06-20-2010, 01:31 AM
DL86's Avatar
Every case is different.
In my case I didn't feel it was required from measurements I took.
DL86 is offline
post #36 of 44 Old 06-20-2010, 01:40 AM
LTD02's Avatar
Liked: 2587
ok...i'm smacked down...
LTD02 is offline
post #37 of 44 Old 06-20-2010, 03:13 AM
DL86's Avatar
Just sayin, what I thought before hand as to what the delays should be set at wasn't true once the speakers were in the room and measurements were being done.
Bit hard to predict 3 different subs working together :P
DL86 is offline
post #38 of 44 Old 06-20-2010, 05:46 AM - Thread Starter
Hot Grits's Avatar
So far it seems like the A500 is a great budget option minus the youtube vid DL86 posted.
I really like the idea of no fan noise.
I would probably use it for the cds and the woofers.
Maybe I would bridge it for the woofers. but the extra 3db doesnt seem worth it.
For reference, my room is about 20 x 14 with 17' cathedral ceilings at its highest point. It is completely open to a large kitchen. My listening distance is about 14'.
Quick off topic question.
If I do run into a problem mixing pro and home gear, I understand I could get a line shifter like the ART cleanbox.
Where in the chain does this go? Would I need something for each channel or would one cleanbox take care of everything.
Hot Grits is offline
post #39 of 44 Old 06-20-2010, 02:07 PM
LTD02's Avatar
Liked: 2587
i'd skip the a500 and go for the ep2000. it's only a hundred bucks more, but is a hell of a lot more amp--no gain control issues, bigger power supply, a lot more secondary capacitance, etc. with the big amp you also get the benefit of a reduced risk of clipping your signal and frying your tweets.
LTD02 is offline
post #40 of 44 Old 06-20-2010, 02:09 PM
LTD02's Avatar
Liked: 2587
if you are running a dcx2496 crossover, you shouldn't need a cleanbox. the box would typically be put in between the pre out on your receiver and the input on the pro amp.
LTD02 is offline
post #41 of 44 Old 06-20-2010, 02:30 PM
penngray's Avatar
Liked: 43
I tried using the EP2500 with my tweeters. Its not really a great full range amp, honestly. I can not tell you what the problem was but it wasnt a clean sound.
penngray is offline
post #42 of 44 Old 06-20-2010, 03:23 PM
LTD02's Avatar
Liked: 2587
penn, good info...can you post a distortion plot or something as that may provide some clues as to what is wrong...
LTD02 is offline
post #43 of 44 Old 06-20-2010, 03:58 PM - Thread Starter
Hot Grits's Avatar
I already got an ep2500 not being used. Was gonna use it for an av15 pr box after my mains are done.
I'm a little worried bout fan noise with more than one running.
post #44 of 44 Old 04-17-2013, 07:16 AM
LetItRane's Avatar
I know I am late to the party answering this question but I thought to answer it anyway for future AV questions. As my screen name implies LetItRane I'm rather fond of the Rane MA 6 multi-channel amps. I have a few of them all without VC's. I use them with a Outlaw 7.1 pre amp and B & O RL 60 speakers for the (LCR RS/LS RRS/LRS + Subs). The amps have a fan and 1/4" mono-phono plugs and screw speaker terminals. The MA 6 are well made and will deliver more than enough power for your system. They can be bridged for added power which I have done for the (LCR & Subs) but it is not necessary. Depending on where you have the amp the fan can be herd when system is in mute. These amps will last you forever and are very dependable. Bring a friend when installing a Rane MA 6 because it's a heavy one! The Rane MA 6 with the VC's would be the correct amp to use for your situation.
Your VC problem could be due to dust in the VC mech and a can of compressed air blown into it might fix your problem if it's touchy or it scratches when moved. Take off the top of the pre amp to do this so to get the best angle to spray.
You see MA 6's often on eBay and can get a great deal on one depending on how bad you want it. Myself I like the non-VC MA 6's because you already have a VC on the pre amp and adding another VC is unnecessary. If you still are having problems with your VC, use your remote to control the VC and adjust each speaker through the pre amps menu to make sure your getting the best out of your pre amp and amp. Hope this helps.....
LetItRane is offline
