AkAbak for Dummies ;) - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #61 of 71 Old 08-29-2012, 10:37 AM
DDAUDIO's Avatar
Hi guys,
I've found this thread absolutely FANTASTIC! Before that, I though AkAbak as a not-viable software for my simulations, but now I can model everything and I am really in love with it!
Just one question comes to my mind: if I would like to simulate a car audio subwoofer response INSIDE of the vehicle, where the environment closed volume is small compared to box volume and have its effect on the response, is it possible in AkAbak to "tell" to the software that the subwoofer is located inside a bigger box, and place the mic somewhere inside this big box?
I'm Italian, so I hope you can get what I mean with my English.
What I would like to get is a plot of frequency response measured at the fron window of the car, giving to AkAbaK all needed measures (clearly we must virtually consider the inside of the car as a squared small room, but even with this approximate of shape the results should be good).
DDAUDIO is offline
post #62 of 71 Old 01-03-2013, 09:58 PM
OscarJr's Avatar
Quoted: 12 Post(s)
Liked: 24
the major problem with trying to do that is getting the cabin leakage and absorption losses. Unless your vehicle is airtight and made of lossless walls that are infinitely rigid, it will be almost impossible to determine these things. The walls of a vehicle flex too much for the "lossless" approach to be close to valid---just look at how windows and roofs flex with multi-thousand watt systems.
OscarJr is offline
post #63 of 71 Old 01-05-2013, 07:24 AM
Ricci's Avatar
Quoted: 248 Post(s)
Liked: 574
The best thing to do is take a small sealed subwoofer and measure it at a known drive level at 1m outdoors and the again with it inside the vehicle. Subtract the outdoor response from the in cabin and you will have a good picture.
Mfusick likes this.
Ricci is offline
post #64 of 71 Old 01-01-2014, 08:22 PM
suktan's Avatar
This is a very useful thread. I am an Akabak beginner.
suktan is offline
post #65 of 71 Old 01-02-2014, 06:19 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 234
Cool resource here!
Thanks for posting this.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #66 of 71 Old 07-30-2014, 02:51 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I just wanted to say thanks for this thread
Mfusick is offline
post #67 of 71 Old 09-27-2016, 04:46 AM
Liked: 0
Hello and thank you for this tutorial
I would like to know how to simulate two subwoofers in series, and 2s/2p ou 2p/2s
Alexandre Bitter is offline
post #68 of 71 Old 08-16-2017, 12:46 PM
OscarJr's Avatar
Quoted: 12 Post(s)
Liked: 24
Does anyone know of an easy way to make Akabak work on Win-10, 64-bit? (tried & true)
OscarJr is offline
post #69 of 71 Old 08-19-2017, 03:04 AM
3ll3d00d's Avatar
Quoted: 1666 Post(s)
Liked: 646
Install XP in a VM (eg virtualbox)
3ll3d00d is online now
post #70 of 71 Old 09-09-2017, 02:04 AM
frenchfries's Avatar
Quoted: 54 Post(s)
Liked: 25
You could also use hyper v, which is already installed if you have pro
Sent from my ASUS_Z017DA using Tapatalk
frenchfries is offline
post #71 of 71 Old 09-09-2017, 02:04 AM
Quoted: 54 Post(s)
Liked: 25
Our you could try the compatibility modes
