THT LP Build - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 92 Old 12-12-2012, 06:39 PM - Thread Starter
premiertrussman's Avatar
Quoted: 17 Post(s)
Originally Posted by Brad Horstkotte View Post
Arauco if you can find it (check Lowes) - not sure if the supply problem got sorted out yet?
I'll check with Lowes...I work with several different Lowes and any given day anyway.
_____________________________________
Shades of Grey Theater
Currently Playing: Overwatch/WoW - Legion
premiertrussman is offline
post #92 of 92 Old 12-12-2012, 07:38 PM
dcg58's Avatar
Yes I have played with it a bit today. I can't believe how clear it sounds. I have it powered by the BASH 300w plate amp and it isn't even turned up 1/4 of the way. I ran Audyssey Mult EQ and found that I did have to bump up the settings 6dB for the subwoofer but that is all I have done so far. I am going to let the driver break in a bit more before turning it up but things already vibrate in the basement and main floor at this level. I have no doubt that you will be impressed. I think the key is to make sure there are no air leaks anywhere.
If you end up having any build questions just shoot me a PM if you need help.
My Vintage style Home Theatre Build thread:
http://www.avsforum.com/t/1400234/vintage-look-diy-theatre-build
dcg58 is offline
