DIY bass horn build...Up next - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #421 of 455 Old 08-05-2011, 01:17 PM - Thread Starter
Ricci's Avatar
Quoted: 178 Post(s)
Liked: 461
Somehow I missed these questions a month ago...I just saw them when I came to update the CEA2010 data.
Ricci could this cabinet design be used for live applications?.
I guess it should certainly be loud enough if you use 2-4, for most applications, but really the cab loading is lower than needed, and it is really big and heavy. You could gain a lot of top end output and efficiency in the meat of the live sound range if you moved the corner up a whole octave higher. You know like the Othorn. Basically the Gjallerhorn would be OK 40-90hz, but some smaller, lighter cabs can compare favorably over that range. It isn't until the octave and a half below that range that it starts to set itself apart from the normal live sound gear. In most live or SR instances that sort of content is pretty much non existent anyway though. Everybody usually filters below 30hz pretty heavily to protect their equipment and cabs and live music doesn't have much below 30hz anyway, so the extra extension is wasted in that application.
Don't get me wrong I am using them for live sound right now but they are stationary, it is only for myself and I run the system.
Originally Posted by 04FLHRCI View Post
Any estimations how one of these guys would perform in a ~3000 cube HT LPF @80Hz?
Violently. The pair that I have have been pushed in the >10,000cu ft very lossy space they are in a few times, just having fun with them and it is more than plenty for that space. They can shake the entire building and easily pressurize the space with Jurassic Lunch and I only have about 1300w of amplifier going to each one. They aren't even using all of that power. Some people say there is no such thing as overkill, but seriously the Gjallerhorn is simply not needed in any sort of domestic environment. Even one will do reference levels to 16hz in a normal room without breaking a sweat. I guess if you had a screen wall it might make some sense, but most of the time I doubt that you would use much of the available headroom. Most situations would be better served with multiple smaller, more modest subs scattered about the room to smooth the response.
I'd be lieing if I said that I wouldn't like to experience what they would do "opened up" in someone's HT room just once though. Maybe someone will have a GTG I can drag one to.
Ricci is offline
post #422 of 455 Old 08-05-2011, 01:32 PM - Thread Starter
Ricci's Avatar
Quoted: 178 Post(s)
Liked: 461
Here are the CEA2010 distortion results to go along with the basic output spl numbers.
Gjallerhorn CEA2010 output. Referenced to 2 meters, rms, outdoor groundplane.
10hz-----90.2db-----Distortion
12.5hz---105.2db----Distortion
16hz-----118.3db----Amplifier
20hz-----122db------Driver noise
25hz-----124.9db----Driver noise
31.5hz---125.8db----Driver noise
40hz-----128.4db----Amplifier
50hz-----127.2db----Amplifier
63hz-----130.2db----Distortion
80hz-----130.9db----Amplifier
100hz----131.1db----Amplifier
125hz----123.6db----Amplifier
Here is 10hz distortion at just about maximum output. Obviously this is not clean or a passing result. This is way below the cab loading and the distortion is very high, but it shows what the Gjallerhorn can do dynamically down that low before getting the driver into mechanical trouble.
93.2db at 10hz
Ricci is offline
post #423 of 455 Old 08-05-2011, 01:57 PM
LTD02's Avatar
Quoted: 2334 Post(s)
Liked: 2562
wow.
did you run out of amp at 100hz and 125hz? is that why the blue line never touches the red line distortion limit or is it something else?
also, it looks like your getting the hang of running these kinds of measurements. hopefully that is cutting down the time required.
Listen. It's All Good.
LTD02 is online now
post #424 of 455 Old 08-05-2011, 02:01 PM
LTD02's Avatar
Liked: 2562
also, what kind of signal is being used for these tests? is it a standard that you can link to or is it something else?
i'm particularly interested the crest factor. manipulating that seems to be increasing in popularity as a way to hit higher peak outputs and appear to have higher sensitivity.
LTD02 is online now
post #425 of 455 Old 08-05-2011, 02:10 PM - Thread Starter
Ricci's Avatar
Quoted: 178 Post(s)
Liked: 461
The signal is the standard CEA2010, 6.5cycle duration, Hann shaped, 1/3rd octave bursts. 100 and 125hz are very short duration. Nothing more than a blip. The program usually just records them like that.
I ran out of amp at 16hz, 40, 50, 80, 100 ,125hz. There were driver distress noises that made me leery of extra level at 20,25,31.5hz despite low distortion results. Distortion limited 10 and 12.5hz and 63hz. That is if I remember all of this right.
Ricci is offline
post #426 of 455 Old 08-05-2011, 04:24 PM
LTD02's Avatar
Liked: 2562
if running out of amp all over the place, what is actually being measured? is it distortion caused by the driver/enclosure or by the amplifier as it is running into clipping?
edit: i see you updated the numbers with notes. that makes some sense and suggests that there is even more output potential of the subwoofer.
LTD02 is online now
post #427 of 455 Old 08-05-2011, 04:33 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5223 Post(s)
Liked: 4116
*laughs* Just kidding. Well, sort of ... I'd go for it if I didn't already have too much on my plate.
Ricci, your Gjallerhorn is CRAZY STUPID CLEAN through the whole lower bass region. Frickin' insane output out of one. It's too bad it gets so 'meh' above 80hz. I bet if you were to cross a cluster of the Gjaller to some uber midbass array you would have the ultimate bass system for outdoor venues. As long as you never had to move them... ever again, anyway.
Love the work you're doing, Josh.
Scott Simonian is offline
post #428 of 455 Old 08-05-2011, 05:42 PM
LTD02's Avatar
Liked: 2562
is it a big pain to have the scale be absolute instead of relative like the old ed mullen charts? they seemed pretty easy to read. i REALLY like the additional information about distortion limited vs. amp limited. that adds another important dimension.
LTD02 is online now
post #429 of 455 Old 08-05-2011, 08:11 PM - Thread Starter
Ricci's Avatar
Quoted: 178 Post(s)
Liked: 461
John with this type of burst testing even a 1" dome tweeter can withstand many kilowatts of input in certain frequency ranges. These same power inputs can cook even an LMS coil easily. It is only the very short duration that allows them. Every sub is going to be amplifier limited at a lot of frequency bands.
I like Ed's old charts. I had already been listing the limiting factor for long term signals on my Excel charts. It does make sense to include it for cea2010 as well.
Ricci is offline
post #430 of 455 Old 08-05-2011, 10:37 PM
LTD02's Avatar
Liked: 2562
i see what you mean.
LTD02 is online now
post #431 of 455 Old 08-19-2011, 09:02 AM
mph33's Avatar
i want this bass horn!!!!
mph33 is offline
post #432 of 455 Old 08-19-2011, 09:25 AM
lilmike's Avatar
Quoted: 61 Post(s)
Liked: 159
Excellent results.
Is there a DIY version of this test, or was that a specific package that you used?
I'd love to be able to use the same methodology on my builds - there is a TON of information presented there.
lilmike is offline
post #433 of 455 Old 08-19-2011, 11:20 AM
martiandancer316's Avatar
wow, i've very glad that this thread got brought up again. It's literally a gold mine, between the entertainment of pages 1-7, and the very, very good science and discussion.
martiandancer316 is offline
post #434 of 455 Old 08-19-2011, 02:48 PM
mph33's Avatar
over kill or not... i would put this bad boy in a bedroom lol
mph33 is offline
post #435 of 455 Old 08-19-2011, 04:00 PM
LTD02's Avatar
Liked: 2562
"Is there a DIY version of this test, or was that a specific package that you used?"
a "behind the measurements" would make for a great technical article ricci, if you don't think that would be stepping past the line.
"i would put this bad boy in a bedroom"
something about that statement doesn't sound quite right. :-)
LTD02 is online now
post #436 of 455 Old 08-20-2011, 07:16 AM - Thread Starter
Ricci's Avatar
Quoted: 178 Post(s)
Liked: 461
Mike,
The program runs under a software package called IgorPro. Powerful and very deep software for audio. It is sort of like a measurement and graphical presentation tool kit. What I mean by that is it is sort of open for the user to set up routines or experiments or setup what you want to do. It is $600 for a license if I remember right. The experiment that runs this was created by Don Keele. It is not available for purchase anywhere still. You would also need some other minimum equipment to run it foremost being an SPL calibrator.
I will give the plans to anyone who wants to build it. All you have to do is pm me your email.
I would like to put 2 in the back of a shortie Astro van and see what would happen on a termlab at 16hz myself. Just for fun of course.
Ricci is offline
post #437 of 455 Old 08-20-2011, 02:37 PM
bossobass's Avatar
Quoted: 77 Post(s)
Liked: 667
Now this is a real curiosity. When I first put the cabs together and applied power I took some close mic graphs. These all show a 100hz dip that was not apparent in the simulation. I then ran the pair lightly in a pa set-up for a few days. Fast forward...I get one of them outside to test it and lo and behold the 100hz dip is gone and between 90-110hz the response has changed. The 100hz dip is no longer there. I freak out thinking perhaps I had damaged something in this cab, or the driver, or both, which wouldn't have been out of the realm of possibility considering the beating bestowed on it, so i run inside and take a measure on the other cab and it is now missing the 100hz dip too. That one hasn't been used very hard at all. I thought that perhaps I somehow had EQ engaged during the original measurements but there is no way. The drivers were brand new and had never been above about 2v so perhaps they had a major break in and this is responsible but I find that a hard pill to swallow. The cabs are 13ply BB with pocket screws and are PL'd together and built by a professional cabinet shop who's owner owns DTS-10's and is familiar with speakers so I have a hard time believing that a panel came loose and shifted enough to cause the response change either. I am at a loss to explain it really. I have attached a couple of measurements illustrating this as well. The 100hz notch is easily seen in the original measurement. The other one is the current response where there is no longer a 100hz dip. Very odd. Atleast it is a response improvement.
Attachment 214743
Attachment 214742
Just doing some catching up and noticed this post. Since I was reading through, I remembered this post before it:
Bentz,
These quick and dirties are with the mic positioned middle of the mouth and coincident with the plane of the side. The cab is rotated tall with the mouth off of the floor and the whole thing is on a furniture dolly rolled outside onto a dock.
It seems likely that your mic was exactly 1/4 wave distance from the floor (33-34") for your close mic graph and otherwise for the measurements that show no null at 100 Hz.
Without the dimensions, I'm just taking a probability stab at this. Maybe you can verify the distance of the mic-to-floor dimension in the 100 Hz null measurement vs the non-100 Hz null measurements?
To verify if this is the case, you could repeat the exercise (measure one with mouth up and mic centered in mouth).
Bosso
bossobass is offline
post #438 of 455 Old 08-20-2011, 06:43 PM - Thread Starter
Ricci's Avatar
Quoted: 178 Post(s)
Liked: 461
Bosso
Well....That is a possibility I guess. I am stabbing at the distance from the floor to the mic but it was probably around 40 to 45". I wouldn't expect the reflection to cause that strong of a cancellation but maybe so. I also had a thought about a reflection from the mouth back into the horn which would also be 45" or so. I only plan to do one more test on these that requires me to drag one outdoors. If I remember I will try to check this again. Right now these are under JBL 4675-c's which aren't too easy to lift down off of them.
Ricci is offline
post #439 of 455 Old 08-21-2011, 12:12 PM
lilmike's Avatar
Quoted: 61 Post(s)
Liked: 159
Mike,
Hmmmm, that looks like some seriously COOL software. Unfortunately, the price tag and limited availability sorta puts it out of my league.... I don't think I have invested $600 for all of my acoustic measurement gear, including the laptop.
Maybe I can grab some spectrum screengrabs in REW and overlay the CEA2010 limits? I'll have to look into alternatives. Shipping them down to you for testing might get a little expensive, not to mention placing more of a burden on you (which is just uncool....). I would like to know how my designs measure up, and CEA2010 is as good a standard as any.
lilmike is offline
post #440 of 455 Old 08-21-2011, 12:38 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
Maybe John Mulcahy can add it to REW? He has added nearly everything else....REW is a powerhouse....
JSS
maxmercy is offline
post #441 of 455 Old 08-21-2011, 12:52 PM
lilmike's Avatar
Quoted: 61 Post(s)
Liked: 159
That would be awesome. I guess I could make that request. I have already generated some cosine-gated CEA test tones with GoldWave using the instructions from Linkwitz's site.
Working on tabulating the thresholds. I think I can actually do this with Excel and the SPL measurement tools I have already if I can get a FRD-style text dump of a spectrum measurement.
Edit - and--- it looks like I can from REW.
Will post results as soon as I get this sorted.
lilmike is offline
post #442 of 455 Old 08-21-2011, 01:37 PM
lilmike's Avatar
Quoted: 61 Post(s)
Liked: 159
JSS
Done.
We'll see if this goes anywhere.
lilmike is offline
post #443 of 455 Old 08-21-2011, 05:57 PM - Thread Starter
Ricci's Avatar
Quoted: 178 Post(s)
Liked: 461
Good luck Mike but I am not sure how close the results would be. There has been significant differences shown between even the "official" setup used by different parties. I tried to use ARTA and a peak hold setup to capture something similar previously and that was just not the same. Some of the results were quite close and others were way off between the 2 different ways. If you want to try I would suggest getting the signal correct first. Good luck!
Ricci is offline
post #444 of 455 Old 10-03-2011, 11:13 AM - Thread Starter
Ricci's Avatar
Quoted: 178 Post(s)
Liked: 461
Might as well throw this in here. This is the new format for CEA2010 results I will be using.
Attachment 224382
Attachment 224383
Ricci is offline
post #445 of 455 Old 12-13-2011, 06:01 AM
chrapladm's Avatar
Quoted: 788 Post(s)
Liked: 277
Ricci what kind of Hpas would be needed for this sub if used in a home with a Pi18?
I doubt anyone would ever need a Hpas in a home environment but I wanted to ask. I have been looking at maybe getting a pair of the Pi18's and building a monster like this would be a good way for me to finally be able to hear which I would like to have. (Pi18 sealed or TH)
And should I send you a PM for the plans when closer to a build?
chrapladm is online now
post #446 of 455 Old 12-13-2011, 08:12 AM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
Originally Posted by lilmike View Post
Done.
How will you track tonebursts with the spectrum function? Is there a peak hold that can be used as the tonebursts play?
For steadystate tones, this ROCKS.
All we need now is to be able to track distortion components in REW like HolmImpulse can....
JSS
maxmercy is offline
post #447 of 455 Old 12-13-2011, 09:40 AM - Thread Starter
Ricci's Avatar
Quoted: 178 Post(s)
Liked: 461
JSS
Agreed. I mentioned this to John long ago. If he can get harmonic distortion measurements during the sweeps implemented that would be huge for me. I use ARTA for that now. STEPS is great but way too brutal for high power. The other thing that I asked him about was beefing the generator up even further and allowing multiple sine wave output. Similar to NCH tone generator. Also the ability to do ascending or descending sweeps for measurements would be cool. REW has come a long, long way already.
Ricci is offline
post #448 of 455 Old 12-13-2011, 09:43 AM - Thread Starter
Ricci's Avatar
Quoted: 178 Post(s)
Liked: 461
Something near 14Hz and 18 or 24dB octave roll off would be recommended.
Sure.
Ricci is offline
post #449 of 455 Old 02-04-2015, 10:37 AM
Archaea's Avatar
Quoted: 2769 Post(s)
Liked: 2380
Here is the Akabak script...The max input on this thing should be about 130V short term without clanking the cone into the spider landing. I will be putting a steep 14 to 15hz hpf on it. Cone excursion hits clankity levels with 130v in at about 14.5hz and is close at the excursion maxima above the corner.
I actually ran out of sections on this.
|COMMENT:LMS5400 ULTRA 18hz 45x45x24 TH 020411 FINAL, no dead space, straight throat, with constriction, big mouth(LMS obstructs roughly 613cm2)
|REQUIRED AKABAK SETTINGS:
|File > Preferences > Physical system constants:
|Sound velocity c = 344m/s
|Medium density rho = 1.205kg/m3
|Sum > Acoustic power:
|Frequency range = 10Hz to 20kHz
|Points = 533
|Input voltage = 1.97V rms
|Integration = 2Pi-sr
|Integration steps = 1 degree ... 1 degree
|Integration method = Cross
Def_Const |Input Parameter Values
|Length, area and volume values converted to metres, square metres and cubic metres:
S1 = 82.90855e-4; |Horn segment 1 throat area (sq cm)
S2 = 308.14365e-4; |Horn segment 1 mouth area and horn segment 2 throat area (sq cm)
S3 = 453.98375e-4; |Horn segment 2 mouth area and horn segment 3 throat area (sq cm)
S4 = 226.85056e-4; |Horn segment 3 mouth area and horn segment 4 throat area (sq cm)/ brace area
S5 = 249.88796e-4; |Horn segment 4 mouth area and horn segment 5 throat area (sq cm)/ brace area
S6 = 513.6456e-4; |Horn segment 5 mouth area and horn segment 6 throat area (sq cm)
S7 = 729.21504e-4; |Horn segment 6 mouth area and horn segment 7 throat area (sq cm)
S8 = 517.6522e-4; |Horn segment 7 mouth area and horn segment 8 throat area (sq cm)
S9 = 254.60955e-4; |Horn segment 8 mouth area and horn segment 9 throat area (sq cm)/ brace area
S10 = 278.2318e-4; |Horn segment 9 mouth area and horn segment 10 throat area (sq cm)/ brace area
S11 = 570.7141e-4; |Horn segment 10 mouth area and horn segment 11 throat area (sq cm)
S12 = 846.68843e-4; |Horn segment 11 mouth area and horn segment 12 throat area (sq cm)
S13 = 579.57232e-4; |Horn segment 12 mouth area and horn segment 13 throat area (sq cm)
S14 = 795.34572e-4; |Horn segment 13 mouth area and horn segment 14 throat area (sq cm)
S15 = 587.76034e-4; |Horn segment 14 mouth area and horn segment 15 throat area (sq cm)
S16 = 628.4965e-4; |Horn segment 15 mouth area and horn segment 16 throat area (sq cm)
S17 = 894.92785e-4; |Horn segment 16 mouth area and horn segment 17 throat area (sq cm)
S18 = 637.70438e-4; |Horn segment 17 mouth area and horn segment 18 throat area (sq cm)
S19 = 908.89994e-4; |Horn segment 18 mouth area and horn segment 19 throat area (sq cm)
S20 = 647.05796e-4; |Horn segment 19 mouth area and horn segment 20 throat area (sq cm)
S21 = 684.16633e-4; |Horn segment 20 mouth area and horn segment 21 throat area (sq cm)
S22 = 1014.9946e-4; |Horn segment 21 mouth area and horn segment 22 throat area (sq cm)
S23 = 694.67089e-4; |Horn segment 22 mouth area and horn segment 23 throat area (sq cm)
S24 = 955.76983e-4; |Horn segment 23 mouth area and horn segment 24 throat area (sq cm)
S25 = 704.47613e-4; |Horn segment 24 mouth area and horn segment 25 throat area (sq cm)
S26 = 728.39915e-4; |Horn segment 25 mouth area and horn segment 26 throat area (sq cm)
S27 = 1037.1547e-4; |Horn segment 26 mouth area and horn segment 27 throat area (sq cm)
S28 = 739.10769e-4; |Horn segment 27 mouth area and horn segment 28 throat area (sq cm)
S29 = 1019.4091e-4; |Horn segment 28 mouth area and horn segment 29 throat area (sq cm)
S30 = 749.69967e-4; |Horn segment 29 mouth area and horn segment 30 throat area (sq cm)
S31 = 964.5552e-4; |Horn segment 30 mouth area and horn segment 31 throat area (sq cm)
S32 = 1367.7644e-4; |Horn segment 31 mouth area and horn segment 32 throat area (sq cm)
S33 = 989.80404e-4; |Horn segment 32 mouth area and horn segment 33 throat area (sq cm)
S34 = 1038.2765e-4; |Horn segment 33 mouth area and horn segment 34 throat area (sq cm)
S35 = 1428.0236e-4; |Horn segment 34 mouth area and horn segment 35 throat area (sq cm)
S36 = 1058.7029e-4; |Horn segment 35 mouth area and horn segment 36 throat area (sq cm)
S37 = 1060.4949e-4; |Horn segment 36 mouth area and horn segment 37 throat area (sq cm)
S38 = 1509.5979e-4; |Horn segment 37 mouth area and horn segment 38 throat area (sq cm)
S39 = 1075.8948e-4; |Horn segment 38 mouth area and horn segment 39 throat area (sq cm)
S40 = 532.2565e-4; |Horn segment 39 mouth area and horn segment 40 throat area (sq cm)/ brace area
S41 = 682.62005e-4; |Horn segment 40 mouth area and horn segment 41 throat area (sq cm)/ brace area
S42 = 1413.3813e-4; |Horn segment 41 mouth area and horn segment 42 throat area (sq cm)
S43 = 2501.1503e-4; |Horn segment 42 mouth area and horn segment 43 throat area (sq cm)
S44 = 2065.1744e-4; |Horn segment 43 mouth area and horn segment 44 throat area (sq cm)
S45 = 2067.7094e-4; |Horn segment 44 mouth area and horn segment 45 throat area (sq cm)
S46 = 1505.2217e-4; |Horn segment 45 mouth area and horn segment 46 throat area (sq cm)/ (1505.2217 with driver restriction, 2118.2217 without)
S47 = 2167.5538e-4; |Horn segment 46 mouth area and horn segment 47 throat area (sq cm)
S48 = 2237.6765e-4; |Horn segment 47 mouth area and horn segment 48 throat area (sq cm)
S49 = 2611.6741e-4; |Horn segment 48 mouth area (sq cm)
L12 = 23.64486e-2; |Horn segment 1 axial length (cm)
L23 = 54.00802e-2; |Horn segment 2 axial length (cm)
L34 = 8.93572e-2; |Horn segment 3 axial length (cm)brace area
L45 = 47.001684e-2; |Horn segment 4 axial length (cm)
L56 = 3.214878e-2; |Horn segment 5 axial length (cm)
L67 = 3.504946e-2; |Horn segment 6 axial length (cm)
L78 = 3.563112e-2; |Horn segment 7 axial length (cm)
L89 = 2.418334e-2; |Horn segment 8 axial length (cm)brace area
L910 = 48.208438e-2; |Horn segment 9 axial length (cm)
L1011 = 2.373376e-2; |Horn segment 10 axial length (cm)
L1112 = 4.11353e-2; |Horn segment 11 axial length (cm)
L1213 = 4.7655988e-2; |Horn segment 12 axial length (cm)
L1314 = 4.3843448e-2; |Horn segment 13 axial length (cm)
L1415 = 3.827526e-2; |Horn segment 14 axial length (cm)
L1516 = 40.694864e-2; |Horn segment 15 axial length (cm)
L1617 = 4.298442e-2; |Horn segment 16 axial length (cm)
L1718 = 4.9505108e-2; |Horn segment 17 axial length (cm)
L1819 = 4.9652428e-2; |Horn segment 18 axial length (cm)
L1920 = 4.418838e-2; |Horn segment 19 axial length (cm)
L2021 = 37.065458e-2; |Horn segment 20 axial length (cm)
L2122 = 4.912106e-2; |Horn segment 21 axial length (cm)
L2223 = 5.5748428e-2; |Horn segment 22 axial length (cm)
L2324 = 5.1532028e-2; |Horn segment 23 axial length (cm)
L2425 = 4.58724e-2; |Horn segment 24 axial length (cm)
L2526 = 35.401758e-2; |Horn segment 25 axial length (cm)
L2627 = 4.999228e-2; |Horn segment 26 axial length (cm)
L2728 = 5.6479948e-2; |Horn segment 27 axial length (cm)
L2829 = 5.4557168e-2; |Horn segment 28 axial length (cm)
L2930 = 5.119624e-2; |Horn segment 29 axial length (cm)
L3031 = 47.806102e-2; |Horn segment 30 axial length (cm)
L3132 = 6.366002e-2; |Horn segment 31 axial length (cm)
L3233 = 6.6675e-2; |Horn segment 32 axial length (cm)
L3334 = 32.559498e-2; |Horn segment 33 axial length (cm)
L3435 = 6.745478e-2; |Horn segment 34 axial length (cm)
L3536 = 6.860286e-2; |Horn segment 35 axial length (cm)
L3637 = 1.203452e-2; |Horn segment 36 axial length (cm)
L3738 = 7.239254e-2; |Horn segment 37 axial length (cm)
L3839 = 7.780782e-2; |Horn segment 38 axial length (cm)
L3940 = 1.651254e-2; |Horn segment 39 axial length (cm)brace area
L4041 = 51.303936e-2; |Horn segment 40 axial length (cm)
L4142 = 3.48996e-2; |Horn segment 41 axial length (cm)
L4243 = 12.146026e-2; |Horn segment 42 axial length (cm)
L4344 = 10.563352e-2; |Horn segment 43 axial length (cm)
L4445 = 1.200658e-2; |Horn segment 44 axial length (cm)
L4546 = 23.711916e-2; |Horn segment 45 axial length (cm)
L4647 = 23.490936e-2; |Horn segment 46 axial length (cm)
L4748 = 33.151826e-2; |Horn segment 47 axial length (cm)
L4849 = 6.847332e-2; |Horn segment 47 axial length (cm)
Vtc = 3500.00e-6; |Throat chamber volume (cc)
Atc = 1465.00e-4; |Throat chamber cross-sectional area (sq cm)
|Parameter Conversions:
Sd = 1194.60e-4; |Diaphragm area (sq cm)
Ltc = Vtc / Atc;
|Network node numbers for this tapped horn system:
| 0-Voltage-1
| -Chamber-5-Driver---
|8-Segment-9-Segment-10-Segment-11-Segment-12-Segment-13-Segment-14-Segment-15-Segment-16-Segment-17-Segment-18-Segment-19-Segment-20-Segment-21-Segment-22-Segment-23-Segment-24-Segment-25-Segment-26-Segment-27-Segment-28-Segment-29-Segment-30-Segment-31-Segment-32-Segment-33-Segment-34-Segment-35-Segment-36-Segment-37-Segment-38-Segment-39-Segment-40-Segment-41-Segment-42-Segment-43-Segment-44-Segment-45-Segment-46-Segment-47-Segment-48-Segment-49-Segment-50-Segment-51-Segment-52-Segment-53-Segment-54-Segment-55-Segment-56-Radiator
Def_Driver 'Driver'
Sd=1194.60cm2
Bl=26.93Tm
Cms=1.19E-04m/N
Rms=8.58Ns/m
fs=20.5001Hz |Mmd = 482.71g not recognised by AkAbak, fs calculated and used instead
Le=2.80mH
Re=3.78ohm
ExpoLe=1
System 'System'
Driver Def='Driver''Driver'
Node=1=0=5=53
Duct 'Throat chamber'
Node=5=9
SD={Atc}
Len={Ltc}
Visc=0
Waveguide 'Horn segment 1'
Node=8=9
STh={S1}
SMo={S2}
Len={L12}
Waveguide 'Horn segment 2'
Node=9=10
STh={S2}
SMo={S3}
Len={L23}
Waveguide 'Horn segment 3'
Node=11=10
STh={S4}
SMo={S3}
Len={L34}
Waveguide 'Horn segment 4'
Node=11=12
STh={S4}
SMo={S5}
Len={L45}
Waveguide 'Horn segment 4B'
Node=11=12
STh={S4}
SMo={S5}
Len={L45}
Waveguide 'Horn segment 5'
Node=12=13
STh={S5}
SMo={S6}
Len={L56}
Waveguide 'Horn segment 6'
Node=13=14
STh={S6}
SMo={S7}
Len={L67}
Waveguide 'Horn segment 7'
Node=15=14
STh={S8}
SMo={S7}
Len={L78}
Waveguide 'Horn segment 8'
Node=16=15
STh={S9}
SMo={S8}
Len={L89}
Waveguide 'Horn segment 9'
Node=16=17
STh={S9}
SMo={S10}
Len={L910}
Waveguide 'Horn segment 9B'
Node=16=17
STh={S9}
SMo={S10}
Len={L910}
Waveguide 'Horn segment 10'
Node=17=18
STh={S10}
SMo={S11}
Len={L1011}
Waveguide 'Horn segment 11'
Node=18=19
STh={S11}
SMo={S12}
Len={L1112}
Waveguide 'Horn segment 12'
Node=20=19
STh={S13}
SMo={S12}
Len={L1213}
Waveguide 'Horn segment 13'
Node=20=21
STh={S13}
SMo={S14}
Len={L1314}
Waveguide 'Horn segment 14'
Node=22=21
STh={S15}
SMo={S14}
Len={L1415}
Waveguide 'Horn segment 15'
Node=22=23
STh={S15}
SMo={S16}
Len={L1516}
Waveguide 'Horn segment 16'
Node=23=24
STh={S16}
SMo={S17}
Len={L1617}
Waveguide 'Horn segment 17'
Node=25=24
STh={S18}
SMo={S17}
Len={L1718}
Waveguide 'Horn segment 18'
Node=25=26
STh={S18}
SMo={S19}
Len={L1819}
Waveguide 'Horn segment 19'
Node=27=26
STh={S20}
SMo={S19}
Len={L1920}
Waveguide 'Horn segment 20'
Node=27=28
STh={S20}
SMo={S21}
Len={L2021}
Waveguide 'Horn segment 21'
Node=28=29
STh={S21}
SMo={S22}
Len={L2122}
Waveguide 'Horn segment 22'
Node=30=29
STh={S23}
SMo={S22}
Len={L2223}
Waveguide 'Horn segment 23'
Node=30=31
STh={S23}
SMo={S24}
Len={L2324}
Waveguide 'Horn segment 24'
Node=32=31
STh={S25}
SMo={S24}
Len={L2425}
Waveguide 'Horn segment 25'
Node=32=33
STh={S25}
SMo={S26}
Len={L2526}
Waveguide 'Horn segment 26'
Node=33=34
STh={S26}
SMo={S27}
Len={L2627}
Waveguide 'Horn segment 27'
Node=35=34
STh={S28}
SMo={S27}
Len={L2728}
Waveguide 'Horn segment 28'
Node=35=36
STh={S28}
SMo={S29}
Len={L2829}
Waveguide 'Horn segment 29'
Node=37=36
STh={S30}
SMo={S29}
Len={L2930}
Waveguide 'Horn segment 30'
Node=37=38
STh={S30}
SMo={S31}
Len={L3031}
Waveguide 'Horn segment 31'
Node=38=39
STh={S31}
SMo={S32}
Len={L3132}
Waveguide 'Horn segment 32'
Node=40=39
STh={S33}
SMo={S32}
Len={L3233}
Waveguide 'Horn segment 33'
Node=40=41
STh={S33}
SMo={S34}
Len={L3334}
Waveguide 'Horn segment 34'
Node=41=42
STh={S34}
SMo={S35}
Len={L3435}
Waveguide 'Horn segment 35'
Node=43=42
STh={S36}
SMo={S35}
Len={L3536}
Waveguide 'Horn segment 36'
Node=43=44
STh={S36}
SMo={S37}
Len={L3637}
Waveguide 'Horn segment 37'
Node=44=45
STh={S37}
SMo={S38}
Len={L3738}
Waveguide 'Horn segment 38'
Node=46=45
STh={S39}
SMo={S38}
Len={L3839}
Waveguide 'Horn segment 39'
Node=47=46
STh={S40}
SMo={S39}
Len={L3940}
Waveguide 'Horn segment 40'
Node=47=48
STh={S40}
SMo={S41}
Len={L4041}
Waveguide 'Horn segment 40B'
Node=47=48
STh={S40}
SMo={S41}
Len={L4041}
Waveguide 'Horn segment 41'
Node=48=49
STh={S41}
SMo={S42}
Len={L4142}
Waveguide 'Horn segment 42'
Node=49=50
STh={S42}
SMo={S43}
Len={L4243}
Waveguide 'Horn segment 43'
Node=51=50
STh={S44}
SMo={S43}
Len={L4344}
Waveguide 'Horn segment 44'
Node=51=52
STh={S44}
SMo={S45}
Len={L4445}
Waveguide 'Horn segment 45'
Node=53=52
STh={S46}
SMo={S45}
Len={L4546}
Waveguide 'Horn segment 46'
Node=53=54
STh={S46}
SMo={S47}
Len={L4647}
Waveguide 'Horn segment 47'
Node=54=55
STh={S47}
SMo={S48}
Len={L4748}
Waveguide 'Horn segment 48'
Node=55=56
STh={S48}
SMo={S49}
Len={L4849}
Radiator 'Horn mouth'
Node=56
SD={S49}
@Gorilla83 ,
Can you use this script in your CNC?
Archaea is online now
post #450 of 455 Old 02-04-2015, 11:29 AM
LTD02's Avatar
Liked: 2562
@Archaea
you probably know, but the gjallarhorn has a constant width, so all the internal panels are whatever width the cab is less the two side panels.
ricci posted the plan.
all that needs to be calculated are the panel lengths depending on which panels you want to but up against which panel at the panel intersections, though somebody who has built one may have the panel dimensions already on hand.
since it is a scale drawing, you could always 'front projector' it onto a piece of paper at 100% scale, trace it, and simply measure with an old fashioned yardstick. :-)
there is also a gjallarhorn v2 if you like a center located horn exit.
LTD02 is online now
