DIY bass horn build...Up next - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #181 of 455 Old 09-01-2010, 08:40 PM
soho54's Avatar
Bill, remember earlier in the thread where you talked about a TH having an advantage with large drivers...
soho54 is offline
post #182 of 455 Old 09-01-2010, 09:47 PM
MBentz's Avatar
Quoted: 25 Post(s)
Liked: 43
Hey Ricci,
I've been meaning to chime in sooner, but work has been way crazy hectic lately. I've actually been working on almost the exact same application for a few months now so I think it would be interesting to compare notes. I was actually targeting 20Hz to 150Hz, but scaling it down would be no problem.
However, what is driving the 380L requirement? And what are the SPL targets? The idea I've been working on is meant to be a modular/scalable approach, and the target transportation size should be smaller than 380L and weigh less than 100lbs. However, when unpacked, I think it's going to be larger. I'll have to crank the numbers later.
And then how many cabs were you going to build? I think you mentioned only one, but that wouldn't be very good for a FOH system....is this for your drum monitors on stage?
Btw, have you read Keele's paper on the comparisons between horns and vented cabs of the same volume?
http://www.xlrtechs.com/dbkeele.com/...%20vs%20DR.pdf
I'm not sure I agree with Keele's conclusions, but I thought I'd throw the article out there as a discussion point.
-Mike Bentz
~It's all about compromise~
MBentz is offline
post #183 of 455 Old 09-02-2010, 02:25 AM
LTD02's Avatar
Quoted: 2529 Post(s)
Liked: 2871
mbentz, thanks for posting that paper. fwiw, i agree more or less with their conclusions. it is humbling to see how right these guys were about the science of audio in the days when they were using typewriters and manually drawing characters and equations into their papers.
Listen. It's All Good.
LTD02 is online now
post #184 of 455 Old 09-02-2010, 04:25 AM
penngray's Avatar
Liked: 47
Mbentz, good paper...thanks! I have a 3 hour flight to enjoy it and read it 10 times before anything remotely sinks in.
penngray is offline
post #185 of 455 Old 09-02-2010, 06:18 AM
Bill Fitzmaurice's Avatar
Liked: 5684
Originally Posted by JapanDave View Post
You know what is a shame? That their is some great info posted by most people (vasyachkin excluded) and I have been following the thread since Ricci started it, but you have to sift through vasyachkin's constant ******** posts to get to it.
I have seen some real idiots on the net, but this guy takes the cake.
Use the 'ignore user' option. Life's too short to waste time wading through the chaff to find the grain.
It's a bit of a tossup as to whether it's an advantage per se. One trade-off of the tapped design is that they run with higher excursion. You get around that with a larger Vd. You can get that with larger/more/more expensive drivers; if it's one of the first two choices the lack of a rear chamber keeps the overall box size down.
Circa 1976, when amps started to break the 200w barrier and woofers the 2mm xmax barrier, Keele's conclusions made perfect sense. They still do to some extent. But you can only go so far using power and excursion to reach a desired output before said excursion gives unacceptable distortion. And there's still the matter of cost. Kilowatt amps today are common, but not free, and drivers capable of making use of those kilowatts don't come cheap.
Bill Fitzmaurice is offline
post #186 of 455 Old 09-02-2010, 06:27 AM - Thread Starter
Ricci's Avatar
Quoted: 246 Post(s)
Liked: 574
Originally Posted by Bill Fitzmaurice View Post
You won't, because the cab is too small. There is a limit to how low you can go with a horn cab of finite size, and you've gone past it. Hoffman always wins. From the size box you want to use I'd say a 40 Hz corner frequency is about as low as you want to try for using only one cab. With a 40 Hz Fc you want to use a driver with an Fs in the 35-45Hz range, which gives a lot lower Mms, and that allows a lot lower Qes and higher Bl from a smaller magnet, while the higher sensitivity allows less Vd for the same output. BTW, though I've never tried it myself to find out, standard design practice is to keep xmax at 15mm or so. More than that invites throat distortion, if not shredded cones. That potential is what limits the potential for 'brute force horns'.
We will see whether the cone can take it and the distortion will end up measured at 2m gp at various drive levels. Also remember that at the absolute maximum amount of power that I'd intend to use on a single cab the excursion would just reach 20mm in the pass band. Back the power off a little and factor in real content and not sine waves and it should be well less than that in use. This driver is as linear as is available well past 20mm.
The way that I've been thinking about this, the "brute force" approach is what will allow the upper range output to compete with other similar sized cabs while providing a corner about a half octave lower.
Ricci is offline
post #187 of 455 Old 09-02-2010, 06:54 AM - Thread Starter
Ricci's Avatar
Quoted: 246 Post(s)
Liked: 574
Originally Posted by MBentz View Post
Hey Ricci,
I was wondering where you've been at...
This cab here is for fun basically. It's a fact finding mission as I mentioned before. There are some concerns about the cone holding up at 3/1 compression, throat distortion getting out of control or other weird overload issues in the constricted area near the driver and I also wonder how the driver will behave thermally. Basically myth busting that long throw big woofers, with low efficiency like these don't work well in horns. If it happens to work out well, then a whole bunch of possibilities open up. Either way hopefully we can learn something. I'm almost done with the ported B&C cabs which cover the same range but are smaller at about 15cu ft external. Part of me wants to just do a TH with one of those drivers for an apples to apples, but we already know that the B&C will work well if done right. In the end I'll probably end up with 4 of some design or another for a foundation of a personal rig.
The reason for 380-400L is because I'm trying to come in at about 18cu ft external for the cab. Everything is based off of external cab size and what can be fit inside. 18cu ft is about the range of the average double 18" pro bin. I'm trying to make a horn that can outperform a good double 18 in the same cabinet size. It is not that easy at least according to the simulations. I can do perhaps a little better (efficiency/output 30-100hz), but I have not been able to beat the double vented cab that I would build with both having the same low corner. It wins slightly on efficiency, cone excursion and having twice the drivers would win on power handling and compression. . I can cram double 21sw152's or 21NLW9600's into a cab that is about 19cu ft external, with slightly undersized vents. It would not be easy but I have a rough cab design worked up.
Ricci is offline
post #188 of 455 Old 09-02-2010, 07:06 AM
Liked: 5684
Originally Posted by Ricci View Post
I'm trying to make a horn that can outperform a good double 18 in the same cabinet size. .
On that point Keele nailed it. From a given cabinet size the direct radiator will win. The trade off comes with the cost of the power and drivers. For a given power input and driver complement the horn will win; the trade off comes in the size of the cab. On a simplistic level if you've got plenty of money and minimal pack space use direct radiators; plenty of pack space and not much money, use horns.
post #189 of 455 Old 09-02-2010, 09:08 AM - Thread Starter
Ricci's Avatar
Quoted: 246 Post(s)
Liked: 574
And here I thought that Bill would disagree. You may not be able to outperform the same enclosure volume of vented direct radiators, but it looks like you can come close to the same performance in some cases with half the cost in drivers.
One thing that I have noted with the DTS-10's, the other Danley's that I've heard, the Klipschs's and the couple of occasions that I've heard Labsubs is that the sound is very clean at high output levels. It seems that they are freer from distortions or other unwanted noises compared to direct radiators driven to the same levels. Lots of people have reported this. I'd consider that a worthwhile advantage.
Ricci is offline
post #190 of 455 Old 09-02-2010, 09:31 AM
soho54's Avatar
If you just go with SPL the Keele paper is right. There will be a few exception, but there always are.
If you look beyond SPL, and at the actual signal reproduced at said SPL another issue comes up.
Then the question is what is causing said difference? How much is from the horns folds, or it's acoustic load on the driver? How much is just from the excursion reduction? Do the same methods used on a direct radiator to control distortions carry over into a horn? If so, to what degree?
soho54 is offline
post #191 of 455 Old 09-02-2010, 09:59 AM
Liked: 5684
Every speaker will be different in the exact details. But one can generalize that when the same SPL is achieved with less excursion distortion will be lowered. And the bends in a folded horn do act as low pass filters, so there will less above bandwidth harmonic output. That being the case the lowest possible distortion will be realized with a folded horn. A tapped horn will come in higher due to the longer excursion for equal SPL and the cone that's not hidden around the bend(s), with direct radiators having the highest.
post #192 of 455 Old 09-02-2010, 10:11 AM
soho54's Avatar
Those are all known data points, but they do not answer the questions posed. You also left out the last two, which are the key points.
soho54 is offline
post #193 of 455 Old 09-02-2010, 01:47 PM
michael hurd's Avatar
Quoted: 113 Post(s)
Liked: 107
Nice to see you still have the 1976 thinking, the TC LMS 5400 has a hellova lot less distortion + wider bandwidth in about the same package ( 7 cubic foot ) as the Klipsch Lascala.
To borrow a catch phrase from Oldsmobile: ' These aren't your father's transducers '
The LMS 5400 delivers in half space 1 meter 114 db with 60V at the terminals. You still can use a lot more power than that through it.
EVERY driver out there is so much more refined than the devices available even 20 years ago, that it's not even funny. Suspension linearity, motor linearity, inductance linearity.... heads and tails above what was the accepted 'norm' back then.
Spoon feeding with a 9 yd bucket.
michael hurd is offline
post #194 of 455 Old 09-02-2010, 02:36 PM
MBentz's Avatar
Quoted: 25 Post(s)
Liked: 43
Heck, the LMS digs an octave lower than the Jubilee with a cabinet half the size, and still has lower distortion and about the same max SPL. The only downside is you can't get up to 1kHz with the LMS.
That said, I would really love to see some distortion/spl comparisons between the Jubilee and the Acoustic Elegance drivers, which can operate on the same bandwidth (and arguably do a better job at it too...)
At the end of the day, I think it makes more sense to talk about audible performance metrics like maximum SPL, distortion, polars, etc... rather than focusing on inaudible metrics like power and efficiency. Heck, in the electronics world, the best sounding gear tends to be the least efficient...throwing extra bias current at a fidelity problem is always the easiest solution - definitely not the most elegant engineering solution, but it's just an example of how efficiency doesn't directly correlate to fidelity.
At the same time though, I still believe horns should always be better....but that comes from having extra control over the polars and usually lower distortion.
Btw, it's rather straightforward to predict the levels of harmonic distortion generated at the throat. I might also mention that I would be worried about extra air disturbances on some of the designs offered where the driver is firing sideways into a narrow slot...think of how DC air flow is gonna have to bend, and that bend is going to create turbulence...just something to think about.
-Mike Bentz
MBentz is offline
post #195 of 455 Old 09-02-2010, 03:44 PM
soho54's Avatar
Ricci,
I would hate to read through your PMs...
soho54 is offline
post #196 of 455 Old 09-02-2010, 05:08 PM
Liked: 5684
And what do you think will happen when a modern transducer is put into a folded horn?
post #197 of 455 Old 09-02-2010, 05:25 PM
Quoted: 113 Post(s)
Liked: 107
You still have smaller bandwidth from low pass filtering due to the folds in the horn, as well as the large ripples in FR.
Drivers have changed, yes. A modern driver in a horn could shift the bandwidth up or down in frequency and possibly change the maximum output some.
Unless you are building a straight bass horn, filtering due to folds is still going to be an issue.
Riddle me this: what happens when large bursts of low frequency energy is fed into a horn with a small throat / large compression ratio?
post #198 of 455 Old 09-02-2010, 08:40 PM
LTD02's Avatar
Liked: 2871
to ricci and all,
you guys are such unbelievable donkeys; i can't believe that you don't see things such as i do, as a master genius of all things. that paper is so stupid as it only considers efficiency of a system and not the limits of the system's performance. like all peer reviewed research it is just morons, reviewing morons about moronic research. anybody, and i mean anybody, who thinks that they know more than i do about audio is fooling themselves in the worst possible way.
as for that paper, who cares how efficient a system is at one watt if it only has one watt of power handling? only lemming peons from the 1970's would use drivers that have 2mm xmax. i'm superior to that. if you can't figure out why, you are stupid, ignorant, or delusional. choose two of three.
most folks around here ride the short bus, so it is no surprise that you are king of the special olympics ricci. can't speak for your followers, but the leader is typically more smarter than his followers. draw your own conclusions about them.
ricci, lol, you can't even figure out how to get a hair cut and you expect to lead the free audio world? as they would say in my homeland, нет. as they might say in your backarse language...not!
once the enclosure size is spec'd, then the driver actually matters. kind of like my panamera. excursion and power handling may not mean much to you idiots but in the world of auto racing it can...and it does. my porsche gt2rs packs 650 hp into a light weight motor, unlike your american fat hinies and its torque curve is as flat as salt lake. i was thinking about moving back to the soviet union, but...umm...err...[silence]
get with the program ricci and all you stupid americans. build a real sub with 50,000 tweeter units and when you do, don't even post it because it would be an insult to geniuses like me.
and if kyle is lurking, you don't know jack either. your subs are like crutches for men with broken legs and limp d_cks. i am the audio equivalent of viagra. i am the god of audio fertility. if you think otherwise, it is because you are delusional and confused.
some have called me YHVH, but you may call me vas.
hahahahhahahhhahhahahhahahahahahahaaaaa.....
LTD02 is online now
post #199 of 455 Old 09-03-2010, 05:14 AM
Liked: 5684
You still have smaller bandwidth from low pass filtering due to the folds in the horn... Unless you are building a straight bass horn, filtering due to folds is still going to be an issue.
One man's issue is another man's design goals. My goals when designing a sub is to limit bandwidth and filter above bandwidth output. Folded horns can do just that, so that's why I employ them.
OTOH if one desires a wide bandwidth folded horn for midbass/midrange use that also can be realized with the proper horn geometry.
post #200 of 455 Old 09-03-2010, 08:56 AM - Thread Starter
Ricci's Avatar
Quoted: 246 Post(s)
Liked: 574
Edit. Wow I'm dense sometimes. 3hrs sleep after a few too many!
Soho54,
Yeah my pm's...
Ricci is offline
post #201 of 455 Old 09-03-2010, 09:58 AM
soho54's Avatar
soho54 is offline
post #202 of 455 Old 09-03-2010, 09:59 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5972 Post(s)
Liked: 5029
Scott Simonian is offline
post #203 of 455 Old 09-03-2010, 10:35 AM
vasyachkin's Avatar
speaking of the salt flats here is a pic of me on the Bonneville raceway last week:
http://www.box.net/shared/static/hd3xhffmyj.jpg
and the aftermath of two runs where i hit my 155 mph limiter.
http://www.box.net/shared/static/lrxqo2khdl.jpg
yes LTD that's "burger king" sign reflecting in the windows. grilled chicken salad was the best i could do given the situation.
those salt flats are probably the only thing America is good for
vasyachkin is offline
post #204 of 455 Old 09-03-2010, 10:37 AM
Bass Enabler
Liked: 5029
Nice car! I love BMW's. I want an M3 and/or M5 like there was no tomorrow.
post #205 of 455 Old 09-03-2010, 10:53 AM
vasyachkin's Avatar
don't forget this baby:
http://www.bmwusa.com/Standard/Conte...HClfplbPlEXg==
but Panamera is still better ...
post #206 of 455 Old 09-03-2010, 10:58 AM
Bass Enabler
Liked: 5029
Oh, sure, can't forget the Alpina.
I'm sure there are "better" cars in one way or another. Though, for me, the BMW will always be 'The Ulitimate Driving Machine'.
post #207 of 455 Old 09-03-2010, 11:04 AM
LTD02's Avatar
Liked: 2871
vas, this is what ricci was talking about. you have a neat car, but why are you posting pics of your car in his horn loaded subwoofer build thread?
LTD02 is online now
post #208 of 455 Old 09-03-2010, 11:11 AM
vasyachkin's Avatar
because he called me obtuse now i am butchering his thread in retaliation
post #209 of 455 Old 09-03-2010, 11:17 AM - Thread Starter
Ricci's Avatar
Quoted: 246 Post(s)
Liked: 574
You are just mad because you hadn't had a chance to break that out on someone yet.
Ricci is offline
post #210 of 455 Old 09-03-2010, 02:29 PM
LTD02's Avatar
Liked: 2871
something that was missed in that paper is performance at the extremes. it more or less sets hoffman's iron law, but it remains silent on where a given design may give up the ghost (either in spl or distortion). two designs may be equally efficient, but the one with 2mm xmax is going to run out gas long before the one with 38mm xmax.
bfm keeps suggesting that distortion is related to excursion. is 10 mm excursion the same in an eminence driver as it is in an lms? i think not. i'm interested to see how this horn performs once the driver gets moving significantly. i've mentioned before that i think this thing is a linear spl monster in the making. many folks seem to be crapping all over ricci's design. i just don't understand why. 130db @ 30hz with neglible distortion.
LTD02 is online now
