Wolfhorn SDX Design Finished - Page 12 - AVS Forum | Home Theater Discussions And Reviews
post #331 of 361 Old 02-22-2013, 01:49 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
I am not so sane myself and am afraid of a possible back feed that would nuke your brain.eek.gif
I really should give it a try, but I lack so much of the other related knowledge that adds to the steep curve, not to mention lack of time to devote as well.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #332 of 361 Old 02-22-2013, 09:42 PM
NWCgrad's Avatar
Quoted: 1230 Post(s)
Liked: 1221
I am not sure any of us on this board are completely sane. smile.gif "Normal" people think a single 12" sub is overkill and 15" drivers in speakers a luditte failure to understand the bass/mid capabilities of modern 5" drivers that can be sourced from China for $3.
Note: I am not a clinical psychologist, psychiatrist, and did not stay in a Holiday Inn Express last night (no big western chain hotels exist in Cambodia, better come for a visit soon - a Hyatt will be openning soon to destroy the charm of lodging options in the developing world).
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is online now
post #333 of 361 Old 11-03-2013, 03:04 PM - Thread Starter
Oklahoma Wolf's Avatar
Quoted: 20 Post(s)
Minor update. I now have a Radio Shack SPL meter freshly Wallins modded. Here's a few sweeps of both my horns in room. The louder ones had stuff rattling in room - keep that in mind. Could use some EQ over and above the nothing I'm getting from the Reckhorn B-2, so I am going MiniDSP at last.
Most dips are no surprise to me. What is a surprise is the relatively decent extension to 130Hz or so, and the big peak at 15Hz (which by the way I love). I've still got these beasts crossed at 80Hz, so I'm leaving a lot on the table above that it seems.
Remember, only one horn is the SDX design - the other is the dual Tang Band, which still sounds too good to knock down and replace with another SDX unit. It would just be a waste of wood to kill it.
And with the B-2's measured response added:
All captures done with the Behringer UCA222.
Oklahoma Wolf is offline
post #334 of 361 Old 11-04-2013, 07:02 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Nice Wolf.
Let the tweaking begin!
Joe = LFE Addict
jpmst3 is offline
post #335 of 361 Old 12-02-2013, 12:58 PM - Thread Starter
Quoted: 20 Post(s)
Added the Sundown E-10 D2 to the list of driver alternates. As always, I have not verified its compatibility firsthand, so go with it at your own risk.
Models about as well as the TC Epic 10 does, assuming published specs are accurate. The driver really wants a smaller design, but should work well enough if the SDX10 isn't available at the time you're reading this.
post #336 of 361 Old 12-18-2013, 09:04 AM - Thread Starter
Quoted: 20 Post(s)
Thanks to the addition of a tool in Hornresp to simulate filtering, I am now recommending a 14Hz 48db/octave highpass for this design using a MiniDSP. Allows one to get the absolute most out of the horn without too much pesky distortion caused by operating too far below the corner. Should just about eliminate the chance of bottoming out the drivers, too.
post #337 of 361 Old 12-18-2013, 09:07 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Thanks for posting the update(s).
Joe = LFE Addict
jpmst3 is offline
post #338 of 361 Old 12-18-2013, 09:14 AM - Thread Starter
Quoted: 20 Post(s)
I was hoping to update with the results of getting the MiniDSP set up, but I don't even have it yet. Had too many financial setbacks this month. I'll be going with the balanced version due to the fact that I'm running a pro amp.
post #339 of 361 Old 06-29-2014, 10:09 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Did you ever get it ?
Mfusick is offline
post #340 of 361 Old 06-29-2014, 10:40 AM - Thread Starter
Quoted: 20 Post(s)
Nope - having too much trouble keeping my head above water this year. I landed a cheap one that wasn't working hoping I could fix it... I couldn't. Since then, it's been the last thing on my mind.
The Reckhorn is still doing pretty well - I reckon I'll be flogging it for some time to come yet. No, I'm not getting the most out of the horns but they're still trying to blow me off the couch when the need arises.
Watched "A Good Day to Die Hard" recently, super hot. Way hotter than usual, probably a good 7dB over reference on the LFE. Good gravy, was that ever fun. Surprised I still had a ceiling after that one.
post #341 of 361 Old 06-29-2014, 01:43 PM
modelaratrod's Avatar
Here's an update, I had to stop watching movies for a bit and finish the floors.
Name:	wolfhorn finished.jpg
modelaratrod is offline
post #342 of 361 Old 06-29-2014, 02:45 PM - Thread Starter
Quoted: 20 Post(s)
Cool - I was wondering how yours have been doing. Looks good!
post #343 of 361 Old 06-29-2014, 05:54 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Nice! What a perfect riser!
This bad boy would make a great wall too!
Joe = LFE Addict
jpmst3 is offline
post #344 of 361 Old 08-11-2014, 02:23 PM
FUN4ME's Avatar
Mr Wolf
I hope everything is going well.
I have a question about an amp(s) .
I see you modeled the wolfhorn sdx with 360watts is that as much power as you can safely power them with?
I bought 2 of the crown x1000 so that I could run each cabinet off of 1 amp bridged.
That would net me 2 X 600 @ 8 Ohms. I assume I will need a minidsp to high pass with.
This would net me a total of 1200watts between cabinets
That is option 1
Option 2 would be to return the crowns and buy an Inuke DSP 3000
With the 3000 I would run both cabinets together and get a 4 Ohm load at 880 watts.
and still have 1 channel left over for the center channel.
Option 3 would be to return the crowns and buy an Inuke DSP 6000.
With the 6000 I would run both cabinets together and get a 4 Ohm load at 3000 watts.
I can use the current limiters on the Inukes to protect the speakers.
I am $218 into the crowns and will need a dsp at about 100 so about 325 all in.
The Inuke 3000 DSP is 279.99 on AMAZON
The Inuke 6000 DSP is 399.99 on AMAZON
I know there are up sides to both what would you recommend?
Thanks Erich
FUN4ME is offline
post #345 of 361 Old 08-14-2014, 02:52 PM - Thread Starter
Quoted: 20 Post(s)
600W is the absolute limit the design will take with the highpass from post #336 in place... I wouldn't do a watt more than that. And you will absolutely need that highpass... it's what'll keep the drivers from clanking below the corner. My 360W suggestion was before Hornresp added that awesome simulation feature, and had to more or less guess based on the Reckhorn and diaphragm displacement graph.
As is, they will be very close to clanking above the corner as well if you give them that much power. Xmech is 28mm IIRC, and you will be close if you run them full out on 600W. You still need to stay around 360W if you want the drivers to stay within Xmax. That said, at 600W in quarter space at one meter, you're talking over 120dB each. Your house might give up before those drivers do
In other words, I would run the Crowns and add a MiniDSP balanced. You've got the amps, they're not crazy overpowered for the design, might as well use them
FWIW, the difference between 360W and 600W in SPL on this design is minimal. You gain perhaps 3dB... that's it.
post #346 of 361 Old 08-14-2014, 03:10 PM
Thanks Mr. Wolf.
Fun I've been running mine with the EP4000
RMS @ 1% THD (sine wave), bridged mode
8 ohms: 1750W
4 ohms: 2400W
It's turned all the way up to 2 maybe 2.5. LOL
post #347 of 361 Old 08-15-2014, 05:00 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Quick question for Mr. Wolf.
What were the final dimensions of this sub? As we discussed a while bank, I want to find a horn sub that I can use as a riser. I can't remember what we discussed, specifically in our PM's as I have deleted it.
My room is 14ft by 17ft by 8ft so I would prefer a horn sub that is capable of being used as a riser in a room of these dimensions. If I don't end up finding a suitable horn sub for this purpose, I may end up getting like 8 of the Infinity 1260w's and build them into a ported riser sub that is 14ft wide and 4ft deep by what ever hight I end up needing.
Martycool007 is offline
post #348 of 361 Old 08-15-2014, 12:49 PM - Thread Starter
Quoted: 20 Post(s)
78" x 43" x 13.25."
post #349 of 361 Old 08-16-2014, 04:39 AM
Quoted: 280 Post(s)
Liked: 176
78" x 43" x 13.25."
So that should work very well as a riser, assuming that I build two and arrange them do be 78" x 2 = 156" which comes out to 13ft which is almost the perfect size for my room as it is 14ft wide! I could add some additional bracing to better couple the subs to the walls which would prevent vibrating the walls to death, and cover the last 1ft gap between the two ends and the walls.
I vaguely remember reading in this thread something about some different drivers being compared for this horn, so in order to keep me from having to sift way back through the thread, can you tell me if the SDX-10 was the final and most optimal driver for these subs? Where can the SDX-10 be purchased?
post #350 of 361 Old 08-16-2014, 10:13 AM
FUN4ME's Avatar
FUN4ME is offline
post #351 of 361 Old 08-16-2014, 11:15 AM - Thread Starter
Quoted: 20 Post(s)
That info is in post #1 . The SDX10 is still the only driver I have ever tried with it, and the one it was primarily designed for. It is the only one I can confirm beyond any doubt that it works in this horn. It's still available here: http://www.creativesound.ca/details.php?model=SDX10
post #352 of 361 Old 04-26-2015, 07:17 PM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
Any new builds using this design, maybe using some different drivers
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is online now
post #353 of 361 Old 04-26-2015, 11:38 PM - Thread Starter
Quoted: 20 Post(s)
None that I'm aware of
post #354 of 361 Old 04-27-2015, 06:33 AM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
I was hoping someone would have use the Sundown's, they're pretty affordable for a pair on the Bay....Regardless, at about $340 a pair for the CSS's this design is pretty damn cool..
How do you load them into a corner ?
post #355 of 361 Old 04-27-2015, 12:46 PM - Thread Starter
Quoted: 20 Post(s)
I've got mine about a foot away from the corner along the back wall, firing straight at it, like so:
The SDX horn is the one on the bottom, and I'm still using the old Tang Band based horn on top.
I'm more confident in the accuracy of Sundown's specs than most... if I was trying one of the alternates, that's probably the one I'd try first. That said, Xmax is lower than the SDX drivers and I don't know offhand what Xmech is.
post #356 of 361 Old 04-27-2015, 06:38 PM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
Im not much of a gambling man, i would go with the CSS's 10", and be done with it. Now to find a house to put em in !
post #357 of 361 Old 05-01-2015, 05:53 AM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
78" x 43" x 13.25."
These are external dims, using 3/4" ply or MDF ???
post #358 of 361 Old 05-02-2015, 12:02 AM - Thread Starter
Quoted: 20 Post(s)
That would be 3/4" ply, three sheets per horn unless you add the bracing. All MDF will do is add weight.
post #359 of 361 Old 05-10-2015, 03:24 PM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
Any chance 1/2 ply could be used ? Howabout (4) driver single cabinet (dual horns sandwiched ), now i bet that would pack quite a punch..... For those who think 10's cant keep up.... $680 for drivers, not bad, and if 1/2" ply could be used, a little lighter, so to speak..
post #360 of 361 Old 05-10-2015, 10:40 PM - Thread Starter
Quoted: 20 Post(s)
1/2" ply would require re-folding and you wouldn't be able to get away with not bracing it. Four drivers would require starting completely from scratch.
