Wolfhorn SDX Design Finished - Page 9 - AVS Forum | Home Theater Discussions And Reviews
post #241 of 361 Old 12-01-2011, 11:37 PM
kryptonitewhite's Avatar
Originally Posted by Oklahoma Wolf View Post
Happy Halloween, everybody. I got my fun out of the way early, just so y'all could enjoy this with me.
The Haunting, DTS-ES. These are the DTS trailer, knocking, and room morph scenes. Average SPL for most of the hardcore bass scenes was about 118dB at listening position. Hit 122dB during the room morphing scene. SPL meter is set on 120dB.
About the camera.... I know, I know. It sucks and won't focus on the SPL meter. Did not too bad focusing on the projection screen though.
This was the first time I've run this movie since before the first TH went together. This movie needs both big picture and big sound to be any good, and it was an absolute blast this time around. Literally
Now, they need to hurry up and release this on Blu-Ray.
ridiculous!
kryptonitewhite is offline
post #242 of 361 Old 12-05-2011, 07:22 AM
modelaratrod's Avatar
Thanks again I'll order 4 of the SDX10's and start my build, what would you suggest for hi pass? I'll be xmax'n these with an ep4000.
modelaratrod is offline
post #243 of 361 Old 12-05-2011, 08:23 AM - Thread Starter
Oklahoma Wolf's Avatar
Quoted: 20 Post(s)
MiniDSP.
The iNuke NU3000DSP may be worth looking into if you don't have the EP4K yet... not too familiar with it. As long as it will do a 12Hz or so highpass at better than 24dB/octave it should do the job.
How big a space are you filling?
Oklahoma Wolf is offline
post #244 of 361 Old 12-05-2011, 08:37 AM
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 176
MiniDSP.
FYI, the last version of the iNuke software I played with stopped at 20 Hz.
lilmike is offline
post #245 of 361 Old 12-05-2011, 08:39 AM - Thread Starter
Quoted: 20 Post(s)
Doh! I think I'll take that suggestion off the table then. No point building this design if you're going to highpass that high.
post #246 of 361 Old 12-05-2011, 08:44 AM
The EP4000 is already on its way, the room is about 14 x 18 but one side has a 4 foot opening up to the next room so that's why I'm doing 2 of them in a riser like FUN4ME did.
post #247 of 361 Old 12-05-2011, 10:10 AM - Thread Starter
Quoted: 20 Post(s)
You're going to have so much fun with these
My room's open to the rest of the house, and I still can't run the two horns wide open. They break things when they get that loud.
post #248 of 361 Old 12-05-2011, 10:46 AM - Thread Starter
Quoted: 20 Post(s)
Folks, we have another driver alternate. The Fi X10 also works in this horn.
So, there are options now if the SDX10 goes away, or changes into something incompatible.
post #249 of 361 Old 12-05-2011, 11:02 AM
post #250 of 361 Old 12-05-2011, 11:38 AM
FUN4ME's Avatar
Nice I hope you do a build thread.
I am happy every time I listen to them.
FUN4ME is offline
post #251 of 361 Old 12-05-2011, 11:46 AM - Thread Starter
Quoted: 20 Post(s)
From Ficaraudio.com?
Yep. Take that with a grain of salt, though. I don't know if the specs are totally accurate, have no interest at this time in testing them out, and am not sure how they like the compression ratio.
I'd put the Seas driver ahead of it. And the SDX ahead of both.
Glad to hear it
post #252 of 361 Old 12-05-2011, 12:42 PM
SDX it will be then.
As for the horn itself plywood or High density fiberboard?
post #253 of 361 Old 12-05-2011, 01:12 PM - Thread Starter
Quoted: 20 Post(s)
I would do plywood.
post #254 of 361 Old 12-05-2011, 01:28 PM
I just finished reading the thread "Baltic Birch vs MDF vs engineered core".
Baltic Birch it is, as many ply's with no voids but how thick?
Just a side note I just ordered a mm tape measure instead of converting your plans. :-)
post #255 of 361 Old 12-05-2011, 01:30 PM - Thread Starter
Quoted: 20 Post(s)
You don't have to do BB - it's expensive, and the plans are designed around 4x8' sheets.
Any decent relatively void free 3/4" ply will do.
post #256 of 361 Old 12-16-2011, 10:35 AM
The EP4k showed up so my son and I hooked it up to his 2 12" Kickers in a sealed box to try it out and WOW this amp has some serious juice!
The 4 SDX's showed up yesterday so tonight we'll hit home depot and make some saw dust.
post #257 of 361 Old 12-16-2011, 10:46 AM - Thread Starter
Quoted: 20 Post(s)
Yep - make sure you go easy on the horns until you know what they can do. If your room is as challenging as mine is, 450W each may be enough to bottom the drivers if the highpass is incorrectly set. 450W above 15Hz won't get them into trouble though.
Looking forward to seeing how yours turn out. Any questions, just ask.
post #258 of 361 Old 12-22-2011, 06:20 PM
jimmy154's Avatar
Is there a way I can change the shape of the enclosure. I want to make it 19" deep, so that I can make the long dimension shorter. I'm not sure how easy this would be.
jimmy154 is offline
post #259 of 361 Old 12-22-2011, 08:54 PM - Thread Starter
Quoted: 20 Post(s)
Unfortunately, horns don't work like that... if you want to keep that 16Hz corner, it'll still need to be long enough to support it. You might be able to re-fold it so that it's shorter and taller, but that's about it. You have to get that 20+ feet of horn in there somehow. I just folded it this way because it was easiest.
Changing the depth would completely change the design. Not sure what the result would be - some increase is ok, but 19" is a long way from 13.5." Goes without saying it would take a lot more wood.
How much shorter do you need it? My Tang Band horn is a little shorter and wider. Still a 16Hz design though, so that only amounts to a few inches.
post #260 of 361 Old 12-23-2011, 10:15 AM
jimmy154's Avatar
I understand about the length. I was hoping maybe someone already or would do it for me, lol.
I want to use SDX10 drivers. Tang Bangs are not that sexy
The thing I don't understand about the application of these "horns" is that above 60 hertz the response is very ragged. What is done to solve this problem?
I was hoping to make an enclosure 19x30x48 inches roughly. Looks to be about 2.57 cu. ft. shy of what I need.
What I really like about these quarter wave resonators, that taper from small closed end to big open end is that they play loud down to 15 Hz. What I don't like is that, of course, this means there will be compression and I'm not sure how that affects sound quality. Also just like with transmission lines, since that is what these appear to be, there's a 1/4 wave delay between what you hear from the driver and the opening. Although it seems as though it might be less noticeable because the resonance is so much louder than the sound directly from the driver.
jimmy154 is offline
post #261 of 361 Old 12-23-2011, 01:27 PM
I just watched/ listened to a video of your horn on my horn! lmao!
One down, one to go....
Thanks again for all the info.
post #262 of 361 Old 12-23-2011, 05:19 PM - Thread Starter
Quoted: 20 Post(s)
The Tang Band drivers are actually more electrically optimal for tapped horn use. As a result, it sounds just a bit better in general than the SDX horn. Not that I notice it very often. The tradeoff there is that they require so much more space it's not worth building that horn. I learned from it and did a better one
Transmission lines and tapped horns do share that 1/4 wave resonator, but are not really the same beast. The SDX design is an undersized tapped horn... it doesn't have an ideal horn flare, and this does have some sonic drawbacks, but it is still a horn nonetheless. Had to compromise if I wanted it to fit in three sheets of plywood.
As far as the ragged response goes, Hornresp assumes perfect conditions. A lot of those peaks and dips aren't there in real life. If you take a look at my measurements elsewhere in this thread, you'll see how my pair do in room. The two of them are remarkably flat without EQ over three octaves or so.
I'd get more into horn theory, but it's been an insanely busy week and I can't think straight anymore. There are others who can probably explain it better than I can... I'm still getting my head around some of it.
Muahahaha! Soon, the earthquakes begin...
post #263 of 361 Old 02-24-2012, 03:16 PM - Thread Starter
Quoted: 20 Post(s)
Got bored, did another video. Well, actually six videos but I put them all together. Apologies for the terrible quality - I just don't have a good camera.
Just a demonstration of what happens in this house when I put sine waves through the horns below the corner frequency. Started at 12Hz, ended at 15Hz. Though not loud enough to register on the SPL meter due to the highpass, 12Hz was already loud enough at the fundamental to get ductwork rattling - not sure if you can hear that in the video due to the quality.
15Hz is pretty much high enough in frequency that I can't turn it up loud enough to find the limits of the two horns. As it is, it was pretty violent. The couch was visibly shaking, the screen was flapping, the door to my bedroom was rattling hard, the light fixture on the ceiling was moving up and down by more than half an inch... it was nuts. This is why that fixture no longer has a shade on it. This is why I have to change that light bulb frequently. I actually had to pop my ears after this one ended.
Final part of the clip is the first music demo of the horns I've recorded... they were set 8dB over reference for this. Used a recording of the world's largest pipe organ... this track has strong content down to 8Hz. Blew a woofer in the mains near the end (already replaced with a spare). 121dB at listening position from the horns. The camera couldn't handle the SPL on some of those peaks... you can sort of hear it distorting in places despite the sucktastic sound quality.
Probably the last video I'll be making of these. I can't let them get any louder in a place I'm only renting, but they will do it if I ask them to.
Now, to go design me some new mains. I shouldn't have asked them to try and keep up with the two monsters
post #264 of 361 Old 03-09-2012, 11:47 AM - Thread Starter
Quoted: 20 Post(s)
Since it looks like the SDX10 may be replaced by an updated model in the near or far future, and I am not exactly sure what the new guy will be like, I've found another driver alternate for this design: the Dayton TIT280C-4.
Standard disclaimer - I have not tried this driver, have not measured this driver, try it at your own risk. It's not as ideal for the design as the Seas L26ROY would be, but it's cheaper and still models quite well. Better than the SDX, in some ways.
Hornresp file attached.
For now, the SDX10 seems to still be around and will always be the driver this horn was meant for. I'll investigate the replacement when it's around to be investigated. But if you can't get the SDX, there are options.
Edit - Bob at CSS has told me the SDX is going nowhere. So, we're good for the foreseeable future.
titansdx.txt 0.423828125k . file
File Type: txt titansdx.txt (434 Bytes, 34 views)
post #265 of 361 Old 03-10-2012, 04:32 PM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 235
Just perused your thread again. I initially read it as it, bit by bit as it was posted. Interesting, certtainly,....those sure seem quite potent, and offer high value for the DIY'er.
Thanks for sharing
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #266 of 361 Old 03-10-2012, 05:46 PM
urapnes1's Avatar
Quoted: 44 Post(s)
Liked: 39
Very cool. I wonder how a pair of TB 740P's would be in a slimmed version of that horn.
urapnes1 is offline
post #267 of 361 Old 03-10-2012, 06:29 PM - Thread Starter
Quoted: 20 Post(s)
The W8-740P in pairs would be best kept to around 20Hz... they really don't have the displacement to pull off a 16Hz design that would end up being worth building.
The SDX10 was literally the smallest thing I could find that would do the job, though there are other 10's that will work in this design.
post #268 of 361 Old 04-25-2012, 12:11 AM
gordondean's Avatar
can we use a pair lab12 for driver with internal panel 320mm wide? or maybe only use one lab12 driver ?
thanks!
gordondean is offline
post #269 of 361 Old 04-25-2012, 06:46 AM - Thread Starter
Quoted: 20 Post(s)
Nope, sorry... the Lab12 is all wrong for this design.
post #270 of 361 Old 06-07-2012, 05:47 PM - Thread Starter
Quoted: 20 Post(s)
Bumping this thread again on account of the fact that I now have actual electrical impedance measurements for this beast. Did them with the help of lilmike's DIY impedance jig, REW, and my Behringer UCA222.
What have I learned? Well, for one thing, I learned I got way closer to the model on this build than I did my Tang Band horn.
Hornresp model:
Impedance measurement with phase:
