Pimp My LP THT - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 10-02-2010, 07:23 PM
chrapladm's Avatar
Quoted: 831 Post(s)
Liked: 289
Wow thanks for the detailed pics it helps me understand more about what I need to do.
chrapladm is online now
Old 10-02-2010, 08:00 PM
Tom Bley's Avatar
Quoted: 595 Post(s)
Liked: 529
Nice. Looking more like a finished product now. Good job!
Tom Bley is online now
Old 10-08-2010, 12:50 PM - Thread Starter
Brad Horstkotte's Avatar
Liked: 68
The monolith is done woot! Was a PITA getting it from the garage to the HT room, but fortunately my son's friend next door left his skateboard ramps in our backyard, so I used them as a ramp to ride the hand truck over.
To test for leaks, I moved it onto the riser (on top of a couple rolled up towels to keep it from getting too scraped up and dusty from all the drywall dust in the room), and ran some test tones from my iPhone through the receiver. Didn't detect any, so buttoned it up, and gave it a brief test with some music and movie scenes. So far so good.
Here's my disgusting temporary equipment wiring. Yeah, lovely.
Back onto the hand truck, moved it into the left front corner firing up into the ceiling - my final location will likely either be that, or laying down firing into the left or right wall.
I accidentally deleted the photo of the RS SPL meter, but it was reading 105 dB at this voltage. Haven't pushed it very hard yet.
I'll be auditioning it some more this afternoon, will have to try some of the well known bass workout HT scenes and see how it goes. Probably won't be doing any REW for a while, since the room is so far from complete (untreated is an understatement).
Brad Horstkotte is offline
Old 10-08-2010, 02:35 PM
LTD02's Avatar
Quoted: 2344 Post(s)
Liked: 2582
congratutions to you on the build and bfm on the form factor (and your son's friend for the skate board ramps).
you've got a nice big screen going in there.
i suppose that i will point out the obvious, if those are the "mains" that you are planning to use, they may be a little outgunned by the subwoofer and screen size.
Listen. It's All Good.
LTD02 is offline
Old 10-08-2010, 03:29 PM - Thread Starter
Liked: 68
Thanks LTD, yeah, the speakers (B&W bookshelves) are definitely next on the list. Planning on replacing them with (almost as small) PRO-10s.
Old 10-08-2010, 04:01 PM
LTD02's Avatar
Liked: 2582
i haven't done much research on the pro 10's. i don't see how the horn can hold directivity through the crossover region being so small. in my opinion, the horn should always be a little larger, at least no smaller, than the driver it is crossing to. sometimes it can work if you push the crossover frequency up higher. most folks tend to like as low of a cross (and that implies as large of a horn) as possible.
LTD02 is offline
Old 10-08-2010, 08:42 PM - Thread Starter
Liked: 68
No idea there LTD, that's territory I'm not competent to judge really - sort of another leap of faith I guess - like the THT was.
Old 11-04-2010, 12:22 PM
premiertrussman's Avatar
Quoted: 17 Post(s)
How you liking your THT so far? I've got the LP plans as well. Im building mine slightly smaller with a 12" driver I have on hand. Im anxious to get started.
_____________________________________
Shades of Grey Theater
Currently Playing: Overwatch/WoW - Legion
premiertrussman is offline
Old 11-15-2010, 04:54 PM - Thread Starter
Liked: 68
Oops, sorry I missed your post premier - I love it, works great. So tempted to build another though - not because I need another, just because I enjoyed building the first one! Plus the talk about evening out response across multiple seating positions. Besides, I still have a half a box of drywall screws left over, it would be a shame to waste them - just need to add a few sheets of plywood, a driver, PL tubes, primer, paint, ...
Hope to see your build thread reactivated soon.
Old 11-15-2010, 05:18 PM
Kanaris's Avatar
I am late to the party... What kind of THT is this and it's so tall... ?
BTW ,excellent build.
Kanaris is offline
Old 11-15-2010, 08:53 PM - Thread Starter
Liked: 68
Thanks Kanaris - its called a THT Low Profile - basically its designed to be thinner and longer than a standard THT - works nicely for behind screen walls, whereas a THT would be too deep unless you have a very deep false wall.
Old 11-15-2010, 09:45 PM
Kanaris's Avatar
Thanks! I know what you mean by deep false wall..click 'my setup' to see it.
Kanaris is offline
Old 11-15-2010, 10:00 PM - Thread Starter
Liked: 68
Haha, oh yeah, I do remember that one. Was it a closet before, I forget...
Old 11-15-2010, 10:11 PM
craigsub's Avatar
Brad - If you get the chance, please send me the plans for your sub. I like to irritate Rocky with stuff. I want to find out what his pro audio company needs to build something like this.
craigsub is offline
Old 11-15-2010, 10:18 PM - Thread Starter
Liked: 68
Would love to Craig, but they are copyrighted works of Bill Fitzmaurice.
http://billfitzmaurice.com/THT.html
Old 11-15-2010, 10:23 PM
craigsub's Avatar
Thanks for the link - I missed seeing the low profile one before. It looks pretty cool !
I Will have to call Bill.
craigsub is offline
Old 10-28-2011, 10:51 AM - Thread Starter
Liked: 68
Thread 347 days old??
What to do....
build another!
Old 10-28-2011, 11:31 AM
Kevin A's Avatar
What to do....
build another!
For the opposite corner?
Kevin A is offline
Old 10-28-2011, 12:24 PM - Thread Starter
Liked: 68
Yup, the first one is behind the screen firing into the left wall corner, this one will likely be firing into the other corner - unless I find that it works better laying the other direction, or firing up into the ceiling.
Old 10-29-2011, 12:43 PM
Audiophile34's Avatar
Awesome!
Glad you are getting a chance to make sawdust again!
Has anyone done a direct comparsion with a tht vs f20?
My first DIY project. A dual, dual opposed setup
www.avsforum.com/avs-vb/showthread.php?t=1345494
Audiophile34 is offline
Old 10-29-2011, 03:10 PM - Thread Starter
Liked: 68
If someone has, I haven't seen it. I would imagine they would be comparable, given a THT of similar dimensions (the plans allow one dimension to vary). I'd be interested in seeing that comparison too.
Old 10-29-2011, 03:29 PM
cheezit73's Avatar
Liked: 24
Awesome!
I am curious as well...I am planning on building one of these two as my first DIY and am trying to decide which one.
cheezit73 is offline
Old 06-17-2014, 11:26 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Did you ever take room measurements or measure the SPL ?
Mfusick is offline
Old 06-22-2014, 09:02 AM - Thread Starter
Liked: 68
Here was the last measurement I took in room, after EQ:
Mfusick likes this.
