Tuba 30" or twin SPUDs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 102 Old 09-18-2010, 11:00 AM - Thread Starter
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Hi all,
I am starting a carpentry class on Wednesday and have to pick a project. It's either a 30-inch tuba (with the option of a second smaller 20-inch Tuba to even out the response) or twin SPUDs to use as a second row riser. It may be that limited placement opportunities mean that one is better suited to my room. What do you think? Is one a better choice than the other in this room?
Room size is 20'8" at the front wall (bottom wall on this diagram), rear wall 18', room depth 18 to 19'.
The two 30-inch Tubas in the diagram are the two possible locations.
Disclaimer: Also posted on the Klipsch forum.
psgcdn is offline
post #2 of 102 Old 09-18-2010, 04:10 PM
shane2943's Avatar
By "Tuba" do you mean the THT (Tuba Home Theater)? Because if you mean the actual Tuba 30 (or T30) then that won't work well as it is a pro sound subwoofer, not a HT subwoofer.
Just trying to clarify.
Nice Sketchup Skills BTW.
shane2943 is offline
post #3 of 102 Old 09-18-2010, 04:34 PM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
there are lots of fun horn project possibilities.
small complex builds such as the anarchy horn build to large simple builds such as cowan's single fold horns.
go here:
http://www.avsforum.com/avs-vb/showthread.php?t=1104368
search on "horn". that will pull up a few ideas.
here are cowan's:
http://www.cowanaudio.com/
click on "tapped horns" in the left column.
Listen. It's All Good.
LTD02 is offline
post #4 of 102 Old 09-18-2010, 07:03 PM - Thread Starter
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Yeah, I meant the Tuba HT...
The 18 Hz Cowan looks too big my my basement!
psgcdn is offline
post #5 of 102 Old 09-19-2010, 08:24 PM - Thread Starter
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
I think I may go Tuba HT for now. I can always build SPUD risers later. It's not like they would cost a fortune to build.
psgcdn is offline
post #6 of 102 Old 09-19-2010, 10:26 PM
notnyt's Avatar
Quoted: 2790 Post(s)
Liked: 2572
i don't think you'll be building the spud after a tht. hope your s.o. is understanding =]
notnyt is offline
post #7 of 102 Old 09-20-2010, 05:49 AM
AndreasMergner's Avatar
Just a note that you'll want to place your THT 18" from the corner of the room. The THT is a great cab! You might want to just go with a 24" wide cab as it is more friendly with wood sizes (unless you are using Baltic Birch at 60x60"). It is easier to move around (doorways and corners) and still has plenty of output.
Current HT: HTPC-->Epson 5010 projector-->135" screen, BFM TLAHs x7 & THT
Build log: DIY rotary sub for contemporary HT in 100 year old house?
Andreas' Slow Rotary Sub build
AndreasMergner is offline
post #8 of 102 Old 09-20-2010, 10:49 AM - Thread Starter
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
I'll start with one and will build another if I have uneven bass issues. I like the frequency response of the 30-inch better and won't be moving it much. As for plywood, well if $50 of plywood is the difference then it's not so bad either.
But thanks!
psgcdn is offline
post #9 of 102 Old 09-20-2010, 11:22 AM
dykz34's Avatar
But thanks!
Make sure your path to the theater is through door openings that are WIDER than 30" then. I had to build my 36" wide one in the house.
dykz34 is offline
post #10 of 102 Old 09-20-2010, 12:09 PM - Thread Starter
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
And you can never move it out!
Access to the basement can be through a door at the bottom of an outside staircase. It's a 90-degree turn but a small second panel to the door makes it open to 44 inches. Then there's a straight run through a 32-inch door.
psgcdn is offline
post #11 of 102 Old 09-29-2010, 10:43 PM
LTD02's Avatar
Liked: 2888
"The 18 Hz Cowan looks too big [for] my basement!"
small footprint though... ;-)
LTD02 is offline
post #12 of 102 Old 09-29-2010, 10:45 PM
LTD02's Avatar
Liked: 2888
also there was another guy who built a vertical horn. i forget his site. he was a european who had some crazy nice looking horn mains...painted bright orange!
LTD02 is offline
post #13 of 102 Old 09-29-2010, 10:52 PM
radman12's Avatar
Liked: 27
volvotreter
radman12 is offline
post #14 of 102 Old 09-29-2010, 11:00 PM
LTD02's Avatar
Liked: 2888
"volvotreter"
that's the guy radman. nice pull!
http://www.volvotreter.de/th.htm
LTD02 is offline
post #15 of 102 Old 09-30-2010, 04:54 PM
radman12's Avatar
Liked: 27
i built two of his 38hz tapped horns, thats why i remembered, and i stared at his living room pictures for months
radman12 is offline
post #16 of 102 Old 11-16-2010, 12:42 PM
vschaos's Avatar
Quoted: 29 Post(s)
Very interested....looking at purchasing the plans(unless someone is willing to send them to me) so I can build two 30" tuba's for my room. Any more pictures guys?
vschaos is offline
post #17 of 102 Old 11-16-2010, 01:59 PM
Bill Fitzmaurice's Avatar
Liked: 5687
Publicly asking someone to commit a felony, not such a good idea.
Bill Fitzmaurice is offline
post #18 of 102 Old 11-16-2010, 02:04 PM
iconrl's Avatar
Quoted: 92 Post(s)
Liked: 64
I'm interested too. Don't the SPUDs dig a little deeper than the THTs, but have a little less output? I assume you get the thump in your chest with both, right?
Also, the Bill's plans aren't very expensive. Just buy them like everyone else.
Optoma HD37 on 138" DIY AT Screen
Infinity Beta 40s, Infinity Beta C250, Atlantic Technologies 224 SR
BIC H100 (DIY in the works)
Old Pioneer VSX-521
iconrl is offline
post #19 of 102 Old 11-16-2010, 02:18 PM
dwomd's Avatar
Not to stir things up too much, I am honestly asking because I don't know. (And, by the way, I respect your work and how you have made your designs available at low cost to people who want to do it themselves. In fact, I have thought about ordering and trying out some of your plans).
If person purchases copyrighted material (say a DVD or a book or plans to build a house) and another person asks for that purchased copy in an open forum and the original owner of the material is willing to give away, or even sell, their copy, is that a felony? It seems to me it would not be. If, on the other hand the person who possessed the copyrighted material posted an electronic facsimile of the copyrighted material and made it available to the masses for download without the permission of the author, either for free or for a fee, that would be illegal.
Are there any opinions from anyone who actually knows (I'll bet there are intellectual property attorneys who like to build their own speakers).
Wayne
dwomd is offline
post #20 of 102 Old 11-16-2010, 03:00 PM
Liked: 5687
This same warning that appears on DVDs applies to all protected material:
'The unauthorized reproduction or distribution of this copyrighted work is illegal. Criminal copyright infringement, including infringement without monetary gain, is investigated by the FBI and is punishable by up to five years in federal prison and a fine of $250,000.'
It's a slippery slope defining what you may legally do and what you may not. Better safe than sorry.
post #21 of 102 Old 11-16-2010, 03:28 PM
Brad Horstkotte's Avatar
Liked: 73
IMHO, even if you never build it, the $15 to Bill for the plans are a good investment just in terms of learning the mechanics of how a folded horn is constructed. And perfect for someone like me who has never built a folded horn, and needs step by step instructions (or at least made me more confident than if all I was going on was a picture/model).
The Low Profile version is also available, in case that form factor works better for you - it did for me (fits behind false wall nicely).
Brad Horstkotte is offline
post #22 of 102 Old 11-16-2010, 05:22 PM - Thread Starter
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
I guess I did abandon this thread. I have a minimal one on Bill's site:
http://billfitzmaurice.info/forum/vi...p?f=30&t=13008
and a longer one on the Klipsch forums:
http://forums.klipsch.com/forums/t/139522.aspx
I'm getting closer to the end...
psgcdn is offline
post #23 of 102 Old 11-16-2010, 05:24 PM - Thread Starter
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
psgcdn is offline
post #24 of 102 Old 11-17-2010, 05:38 AM
vschaos's Avatar
Quoted: 29 Post(s)
Sorry didnt mean anyone to commit a felony. I'll be purchasing the plans from your site either today sometime or tomorrow.
Is the Dayton RSS390HF-4 15" Reference HF Subwoofer 4 Ohm still the recommended driver for the standard THT? I also want to ask is it allowed to post pictures as I put the boxes together(I plan on building two)?
vschaos is offline
post #25 of 102 Old 11-17-2010, 06:09 AM
Liked: 5687
It's a recommended driver because it has the right specs at the right price. You can use any driver with appropriate specs that will fit into the box.
Ever been to my forum? Highly recommended.
http://billfitzmaurice.info/forum/vi...224db5083c15fa
post #26 of 102 Old 11-17-2010, 06:17 AM
vschaos's Avatar
Quoted: 29 Post(s)
It's a recommended driver because it has the right specs at the right price. You can use any driver with appropriate specs that will fit into the box.Ever been to my forum? Highly recommended.
thanks just sent the money....question is though should I have purchase the panel jigs? I think I should have since it was only $1.95, but wasnt aware if I needed those.
vschaos is offline
post #27 of 102 Old 11-17-2010, 06:39 AM
t6902wf's Avatar
I have to comment on the intellectual property conversation.
Not to anyone specific just a general rant.
Bill's product is his plans. His time and effort to develop a viable product. Create a web site, get known. I'll bet he has been pursuing this for years.
It is a shame what things are coming to.
If I hired you for your industry contacts and got that information and fired you in three months would that be fair? I paid you for your intellectual property.
T6
Clearwave 4TSE and 4CC build thread
http://www.avsforum.com/avs-vb/showt...1#post19489740
t6902wf is offline
post #28 of 102 Old 11-17-2010, 06:48 AM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 169
Bill,
You may want to include the dayton reference hf 12" driver to the recommended driver list. It models VERY well in a slim 15"-16" wide box. Not so well in other widths.
Caveat: I have not built one yet.
JSS
maxmercy is offline
post #29 of 102 Old 11-17-2010, 08:06 AM
vschaos's Avatar
Quoted: 29 Post(s)
I see on parts-express they have this woofer...
Dayton RSS390HO-4 15" Reference HO Subwoofer 4 Ohm
It is the same price as the recommended. What is the difference if anything between the "HF" and the "HO"?
vschaos is offline
post #30 of 102 Old 11-17-2010, 10:58 PM
michael hurd's Avatar
Quoted: 142 Post(s)
Liked: 126
VSCHAOS.... ever cook anything>? If a recipie calls for garlic salt and you instead used celery salt, would the results be the same?
The HF and HO have different parameters, and are suited for different tasks. Google "Thiele/Small" parameters and this might help you understand a bit more.
95% Synthetic bass since Y2K.
michael hurd is offline
