MiniDSP - Page 100 - AVS | Home Theater Discussions And Reviews
 60Likes
post #2971 of 2977 Unread Today, 12:03 PM
3ll3d00d's Avatar
Quoted: 562 Post(s)
Liked: 152
Originally Posted by Stereodude View Post
I'm suggesting they make an in between product that's well suited for subwoofer usage that isn't $500.
I don't disagree with the importance of knowing the limits of your system but I'm curious as to why you don't just turn the trims down? are you getting too much noise if you do or can't turn it down far enough? or something else maybe?
3ll3d00d is online now
post #2972 of 2977 Unread Today, 12:25 PM
Stereodude's Avatar
Quoted: 1096 Post(s)
Liked: 807
With my Pioneer Elite SC05 I could just barely get the output voltage below the clipping point of the balanced 2x4 by turning the sub trim down to -10dB (lowest it would go) to support 0dB / "reference" level playback of worst case 5.1 content. However, any EQ boost in the miniDSP would result in clipping the output of the miniDSP. That can be mitigated by turning down the input level in the miniDSP GUI. Then I had to turn up the gain on my amps all the way so the 75dB test tone was the right volume. So, yes, I was able to make it work, but the user has to be very cognizant of exactly what needs to be done and it's not something a n00b is going to stumble into. In it's current incarnation it's certainly not a plug & play / can't mess it up subwoofer EQ.
Stereodude is online now
post #2973 of 2977 Unread Today, 12:29 PM
DS-21's Avatar
Quoted: 462 Post(s)
Liked: 300
Why thank you. Yes, I am trying to be cheap about it. I'm suggesting they make an in between product that's well suited for subwoofer usage that isn't $500.
First, the subwoofers only clip in case of a not-gonna-happen scenario you imagined and/or completely inept system setup.
What you fail to understand is, to get the upper bass really right in a small room one actually needs the 8x8/10x10 (“8x8” for the rest of this post) unit’s capabilities anyway. (Or the 2x8/4x10 with an upstream A/D converter.) This has nothing to do with picayune complaints that a very inexpensive box can’t handle massive and not-seen-in-a-competently-set-up-system input levels. Rather, it’s the matrix routing feature that’s key.
Bass management is always handled ineptly by AVRs and prepros, and the errors are readily unmasked in competently set-up multisub installations, because the overall response is much smoother. Also, common setups put a “crossover” right in the middle of the modal region (i.e. ca 80Hz) which is just a stupid thing to do.
The way around the stupidity of onboard bass management is defeat it entirely for the mains and feed the LCR+LFE preouts to the 8x8. (One can also, of course, add the side surrounds to that, depending on how many subs one is running.) Sum all the bass from the front three channels and the LFE for the subwoofers. Apply highpass filters to your mains if you must, i.e. if they’re compromised designs (fairly small, vented, etc.), but otherwise let them run fullrange. Optimize according to your priorities (seat-seat consistency, listening position FR, whatever) using measurements.
As the 2x4 doesn’t have 4 inputs (for LCR+LFE) or enough outputs for LCR + multisubs, it’s suboptimal for serious subwoofer setups to begin with. It’s great for multiway mains, though. And would be better if they fixed its only real flaw (the turn on/off thump).
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #2974 of 2977 Unread Today, 12:30 PM
The Truth Hz
beastaudio's Avatar
Quoted: 1456 Post(s)
Liked: 1224
Few units rarely are. You can argue something like the old ED eq.2 is foolproof, but just about any robust EQ setup can be botched. I know Bosso was speaking of several occassions where he saw folks using the bassis units with upwards of 18dB shelving and frying drivers, amps, and everything left and right, having no clue why it was happening. EQ is a fickle beast, you gotta definitely be "Cognizant" to say the least...
(European models do not accept banana plugs.)
"If you done it, it ain't bragging." ~ Walt Whitman
AE TD12x SEOS12 Build
Beast's DIY Master Measurement Thread
DIY Emminence Coaxial Surround Thread
beastaudio is offline
post #2975 of 2977 Unread Today, 12:49 PM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 218
Just as a matter of curiosity, how high are you able to set the LPFs of the subs before you notice localization? Are they 4th-order LPFs?
andyc56 is offline
post #2976 of 2977 Unread Today, 03:16 PM
coolrda's Avatar
Quoted: 77 Post(s)
Liked: 78
Never paid any attention to this very much. But after reading Bosso's post on another forum concerning Interstellar's soundtrack, I checked my inputs. I'm using the UnBal 2x4 with whatever the jumper comes set at factory. At -10 to -8db the input clips with the 2:18min content. I haven't metered the voltage out of the preamp yet except with a -20db@50hz tone which hit 0.9v at a MV of +3db. I can't remember if Audyssey was on or off. My current amps are rated for full power@1.0v. I assume moving the jumper being moved to the 2.0v tap would give me additional headroom on the preamp side?
coolrda is online now
post #2977 of 2977 Unread Today, 04:11 PM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 218
From the updated manual PDF file, page 37:
Note that the input sensitivity jumper setting does not affect the maximum output signal – it is always 0.9 V RMS. Therefore, when the jumper is in the 2.0 V position, the miniDSP (without any other processing enabled) has an approximately 7 dB insertion loss. If higher output signal levels are required, then the miniDSP Balanced 2x4 or the 4x10 Hd can be used.
andyc56 is offline
