MiniDSP - Page 101 - AVS | Home Theater Discussions And Reviews
 60Likes
post #3001 of 3019 Old 04-20-2015, 05:38 AM
Stereodude's Avatar
Quoted: 1137 Post(s)
Liked: 813
Originally Posted by GizzeGutten View Post
Even the 2nd and 4th order HPF overshoots using the 96kHz plugin.
I agree, it's not a good solution for the 96kHz unit(s).
I've done more research and @notnyt which is a user on these forums has raised the instability with PEQ filters in the lower frequencies using 4x10HD and 96kHz with miniDSP before. I noticed I got more bass when I used the filter, measured and these were my results.
According to that thread miniDSP doesn't want to solve it because they have more pressing issues (and it has now been several years). Also, their patch for the PEQ filters seems to be the Sub_EQ filter option:
My favorite thing from that thread is when the miniDSP folks said the unit couldn't pass 2Hz. It was impossible! Have they measured their own hardware?
Stereodude is online now
post #3002 of 3019 Old 04-20-2015, 04:49 PM
asarose247's Avatar
Quoted: 194 Post(s)
Liked: 97
technical for a guy out of the loop, to be polite
would the minidsp be able to
handle lpf and HPF for the rotary sub discussed in this section
I suspect wrt my minimal comprehension that that might be a mini 2 x 4,
that way I could still work in the 2 Lhorns and MAX, total 4 subs
pure speculation/planning for the road ahead . .
thanks and please, KISS
DIY FAN Denon X5200 , Emotiva UPA7, for 7.3.4 ATMOS/DSSHARP 80" U
FL/FR: DIYSG Fusion 15's , Center: DIYSG "88 Special" , SL/SR: RC3II , SRL/SRR: F-3Towers, TF & TR: SLX
2 30" BF THTLP'S , SUBMAXIMUS, 2 x Inuke6000DSP & 2 driverless LHORN cabs
http://www.avsforum.com/forum/401-di...rs-subwoofers/
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
asarose247 is online now
post #3003 of 3019 Old 04-20-2015, 04:58 PM
Pain Infliction's Avatar
Quoted: 635 Post(s)
Liked: 314
When it comes to rotary subs, I am by no means an expert, but would a HPF even be necessary?
Applying a LPF is definitely something the minidsp can handle. HPF too at 10hz roughly. Rotary subs play down to 1hz so I am not sure what can be done about this.
Pain Infliction is online now
post #3004 of 3019 Old 04-20-2015, 05:18 PM
asarose247's Avatar
Quoted: 194 Post(s)
Liked: 97
yes, its obvious I wasn't thinking , HPF indeed
now wrt getting a signal for the rotary subbut i'll go back to that thread
however
i'm thinking bass synthesizer for those 3-5 to 15-18 hz tones specifically for the rotary
sounds like a visit to sweetwater is at hand . .
thanks
post #3005 of 3019 Old Yesterday, 10:32 AM
Quoted: 24 Post(s)
Liked: 2
I am a complete noob and was going to buy a 2Vrms unbalanced MiniDSP 2x4 (I really don't want to deal with Phoenix connectors) to go between my Denon 4520CI and a samson sx3200 that will power 2 custom subs. Is that the right product for me? I need a HPF @ 10, so other easier plug-and-play options don't seem viable. Any and all guidance is welcome.
John
jwebtx is online now
post #3006 of 3019 Old Yesterday, 10:57 AM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 219
The Samson sx3200 has an input sensitivity of 1.24 Volts RMS. This means it takes 1.24 Volts RMS at its input to drive the output to full power. But the unbalanced miniDSP 2x4 only puts out 0.9 Volts RMS maximum, regardless of whether its input sensitivity jumper is set to 2.0 Volts RMS or 0.9 Volts RMS. So the miniDSP 2x4 unbalanced is incompatible with the Samson.
andyc56 is offline
post #3007 of 3019 Old Yesterday, 11:05 AM
Quoted: 24 Post(s)
Liked: 2
Wow, I am glad I asked. I guess the balanced is still an option? How difficult is the wiring job? I was really hoping to avoid it and can't imagine why they use them over more common plugs.
post #3008 of 3019 Old Yesterday, 11:10 AM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 219
I have heard it's not difficult at all, but haven't tried it. I was thinking of buying one a while back and did a bunch of research on them, but ended up not buying one.
andyc56 is offline
post #3009 of 3019 Old Yesterday, 11:43 AM
Quoted: 24 Post(s)
Liked: 2
Another product you would recommend over the balanced 2x4 that can HPF @ 10?
post #3010 of 3019 Old Yesterday, 11:58 AM
The Truth Hz
beastaudio's Avatar
Quoted: 1468 Post(s)
Liked: 1233
The open DRC-AN uses XLR inputs and outputs. If you only need 2x2 I/O, then it should work just fine for you
(European models do not accept banana plugs.)
"If you done it, it ain't bragging." ~ Walt Whitman
AE TD12x SEOS12 Build
Beast's DIY Master Measurement Thread
DIY Emminence Coaxial Surround Thread
beastaudio is online now
post #3011 of 3019 Old Yesterday, 12:36 PM
Quoted: 24 Post(s)
Liked: 2
Thank you. $220 more, but I think that is the route i'm going to take.
post #3012 of 3019 Old Yesterday, 04:27 PM
Quoted: 635 Post(s)
Liked: 314
Wiring is easy or you can buy pheonix to xlr cables pre made if you want. B&H Photo sells them and I am sure other places do too.
Correct. It's easy enough.
Or you can go this way. I like this option too, and if you don't mind spending the extra money, go for it. You can set higher delays than the balanced version and it can handle more input voltage as well.
post #3013 of 3019 Old Yesterday, 08:17 PM
DS-21's Avatar
Quoted: 473 Post(s)
Liked: 303
http://seriousaudioblog.blogspot.com...s-for-2x4.html
They use them because they're smaller. (I like them better, actually, because you can use them with bare wire cut to size instead of needing to add a connector.)
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #3014 of 3019 Old Yesterday, 09:21 PM
AustinJerry's Avatar
Quoted: 2383 Post(s)
Liked: 1216
That link doesn't seem to work.
As for the difficulty of the wiring, I recently connected the DDRC-88A and a balanced 2x4 using the Phoenix connectors. I purchased XLR cables, cut them in half, and learned how to use heat shrink. It really isn't that hard. I recommend the bare wire approach rather than the XLR-to-Phoenix converters because with the converters you end up with a bundle of bulky and heavy XLR connectors on the back of your equipment. The bare wires are nice and clean.
AustinJerry is online now
post #3015 of 3019 Old Yesterday, 09:28 PM
DS-21's Avatar
Quoted: 473 Post(s)
Liked: 303
Worked for me both on my Mac and my iPhone.
Does it work for you set up like this?
Serious Audio Blog
DS-21 is offline
post #3016 of 3019 Old Yesterday, 09:33 PM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 219
Working fine here, as did the link from the original post.
andyc56 is offline
post #3017 of 3019 Old Yesterday, 09:34 PM
Liked: 1216
After trying it again, the first link worked. Interesting read. I am lucky because my pre-pro, power amp and subs all have balanced connections. All I needed to do was develop my Phoenix connector skills, which turned out to be kind of fun.
post #3018 of 3019 Old Today, 07:10 AM
DS-21's Avatar
Quoted: 473 Post(s)
Liked: 303
Definitely basic stuff for someone who's played with Phoenix connectors already, but I wrote that (wow, almost three years ago now; need to update it with better pics) because there was a lot of confusion about something that's really not an issue for anyone who can handle a screwdriver without drawing blood (at least 75% of the time)!
Serious Audio Blog
DS-21 is offline
post #3019 of 3019 Unread Today, 08:20 AM
Quoted: 24 Post(s)
Liked: 2
After further consideration, I think a balanced 2x4 with pre-made B&H cables might be best for me (and cheapest too). I'll digest the link some more before deciding, but I really love the ease of plug-and-play. I know i'm going to need significant time to actually learn how to use REW and the miniDSP.
