MiniDSP - Page 107 - AVS Forum | Home Theater Discussions And Reviews
Old 07-14-2015, 05:49 PM
audioguy's Avatar
Quoted: 950 Post(s)
Liked: 618
Originally Posted by AustinJerry View Post
What about measuring output voltages with a DMM?
DMM = ?
And where would I measure them? 7702 or miniDSP or both?
Our Theater
FS: PurePower 1050 Regenerator/Conditioner - Price Reduced
Obsessed is just a word the ill-informed use to describe the dedicated
audioguy is online now
Old 07-14-2015, 06:21 PM
AustinJerry's Avatar
Quoted: 2962 Post(s)
Liked: 1601
Originally Posted by audioguy View Post
DMM = ?
Digital Multi Meter. How to do it is in the 2x4 write-up linked in my sig. You would measure the 7702 output under load, and then the MiniDSP output to your power amps or subs. Check to see if readings exceed the rated input of the MiniDSP or the amps.
If you are inclined to try this, a DMM is relatively inexpensive at Home Depot or Lowes.
AustinJerry is online now
Old 07-15-2015, 08:26 PM
audioguy's Avatar
Quoted: 950 Post(s)
Liked: 618
[Another] Input and Output Sensitivity Question
I have an Open DRC-AN. The input sensitivity can be either 2V or 8V. The max output is 2V. Theoretical question: If I change the input sensitivity to 8V, do zero processing in the miniDSP, what happens to the 8V when it shows up at the output channel that only outputs 2V. Is the 8V input scaled so that at the full 8V it will drive the 2 volt output, at 4V input it would drive 1 volt output, etc?
Our Theater
Old 07-15-2015, 08:30 PM
Stereodude's Avatar
Quoted: 1732 Post(s)
Liked: 1118
It's going to cut the voltage to 25% of the original voltage (ie: divide by 4).
Stereodude is online now
Old 07-15-2015, 08:33 PM
audioguy's Avatar
Quoted: 950 Post(s)
Liked: 618
Not sure I understand. Will the 8V input get 2V output?
Our Theater
Old 07-15-2015, 08:43 PM
Stereodude's Avatar
Liked: 1118
Yes.
Old 07-15-2015, 08:55 PM
audioguy's Avatar
Quoted: 950 Post(s)
Liked: 618
So will 1/2 of the input (4V) generate 1/2 of the output (1V)?
Our Theater
Old 07-16-2015, 04:49 AM
Stereodude's Avatar
Liked: 1118
Yes, that's what I meant when I said you would get 25% of the input voltage on the output.
Old 07-16-2015, 01:10 PM
audioguy's Avatar
Quoted: 950 Post(s)
Liked: 618
All is well. Raised the sub amps gain to maximum; removed the jumpers to allow an 8V input on the miniDSP; adjusted the 7702 trims and viola - it worked.
I can now reach Reference + 5 with the multiple shelf filters engaged and the sub about 5db hot!! (I can't ever recall but one time I played the system at that volume with real material.) After that, the response curve gets a bit weird.
Thanks for all of the recommendations. Love AVS!!!
Our Theater
Old 07-26-2015, 03:26 PM
Gaugster's Avatar
Quoted: 53 Post(s)
Liked: 41
Did my first dive into subwoofer room correction and nothing but good things to report. The setup guides for 2x4 provided by this site and MiniDSP.com along with REW have made a great improvement in my listening room.
I have a question about time alignment of the subs. I have old Definitive Technology BP2002's in front each with a powered 12. I have a third subwoofer that can be read more about here.
Transmission Line Isobaric Subwoofer for home.
I seem to notice that when I performed the time alignment step by measuring and adding an offset more and deeper nulls occurred in the REW sweeps.
What does this mean? Or rather how should I interpret this change? I rely on a setup disc with "pops" or "clicks" that helps to fine tune timing delays of surround channels vs fronts & centers. Is there a test tone or method to listen and tune low frequency delays? I have a disc from Sheffield labs that does 100Hz bursts but would like to here from the folks here about audible test methods that are used with consistent good results. I am going to drop a post over on HT Shack in the REW forum too I think.
Here some more details about the setup as it stands.
1 - I measure SPL at 6 postions along the main seating area. Lots of data from which to generate biquads so any huge nulls or peaks will be averaged out significantly (IMO).
2 - As the front Left/Right BP2002's have internal cross overs I have left MiniDSP settings as pass through.
3 - The BP2002's are physically closer to MLP so the sub output is delayed by 1.3ms. Also wondering is delaying these subs is okay as they are build in to the main L/R mid & high frequency drivers. I.e. MTM in bipolar setup.
4 - The third sub is a 30Hz transmission line. MiniDSP is used to invert the phase and filter. HPF 20Hz 48dB/oct BW & LPF 85Hz 48dB/oct BW
5 - The averaged results matched the REW predicted curve very well.
6 - No room treatments whatsoever.
Here is a capture is an in process comparison. All three subs active. GREEN is with no timing delay at all. RED has 1.3ms delay for BP2002's based on physical distance delta. I am wondering about the nulls at 60Hz, 70Hz and 85Hz. I did ABA testing so I don't believe it is measurement error. All distance measurements taken from center of sub woofer (side firing and down firing.) I had also thought about taking my measured and adding delay based on the distance to each subs port instead of speaker. But not time yet to fiddle.
PS - Thanks to several contribution members to the setup guides etc.... for MiniDSP and sub integration. My hats off to YOU!!!!
Gaugster
Gaugster is offline
Old 07-26-2015, 05:08 PM
Stereodude's Avatar
Liked: 1118
Do REW sweeps at different ms settings. Even try delaying the other sub. Pick the delay value that gives you the flattest response.
Old 07-26-2015, 06:07 PM
Gaugster's Avatar
Quoted: 53 Post(s)
Liked: 41
Ha! I was afraid someone would suggest as much. Lots of sweeps ahead. Would 0.5ms increments be alright? I guess I could try 1ms and 0.5ms using one microphone position too get a feel for the process.
Gaugster is offline
Old 07-27-2015, 04:50 AM
Stereodude's Avatar
Liked: 1118
Put the mic at your MLP and try 1ms increments. You should find a few good candidate values. Once you've identified them check .5ms more or less and see if they're better or worse. Then, use the best values you found to check the other mic positions (seats).
Old 07-27-2015, 06:16 PM
Gaugster's Avatar
Quoted: 53 Post(s)
Liked: 41
Good point. Making the LF decent across the seat positions is kind of a secondary goal vs the MLP.
Gaugster
Gaugster is offline
Old Today, 12:29 PM
nwf477's Avatar
Quoted: 151 Post(s)
Liked: 64
Need a little Help
I have taken the plunge and decided to upgrade to HST18D1's a Crest 7.5amp a MBM with a Dayton 465 powered by a nu3000DSP. My AVR has 2 LFE jacks according to the images on how to make the cables for the Balanced MiniDSP I will use current RCA to Speakon cut the Speakon off wire one to Input 1 the second to Input 2. Coming out of the DSP ( my confusion starts ) I will be running the Crest at 2 ohms per channel do I need RCA to XLR for each channel EXample output 1 and output 2 ( cutting the RCA off of each one ) then have another one for the NU3000DSP. I understand the basics but that is it, according to Nick at Stereo Integrity he said I should cross the HST's at 80hz and run the MBM from 80 to 150 or so and let the rest of the system play from there up. This makes sense but how do I do that on the DSP? I have not gotten the DSP yet I ordered it Saturday and even if I get it this week it might take a little longer to get both subs. Hopefully I am not coming out of left field and this makes some sense so if someone can please advise.
Equipment: Panasonic 42" LCD TV, Panasonic DMP-BD65 BluRay, HP Compaq 6000 Micro Tower - for movies and music, Yamaha RX-A2010, getting ready to redo.
nwf477 is online now
