MiniDSP - Page 127 - AVS Forum | Home Theater Discussions And Reviews
 210Likes
post #3781 of 3932 Old 08-14-2016, 11:17 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7571 Post(s)
Liked: 4230
Originally Posted by Tstan7777 View Post
Will this power supply work for a minidsp 2x4? It powers it up, but I want to make sure before leaving it powered.
Don't see why not. The MiniDSP product page calls for a 12V PSU, and that's what you are showing.
AustinJerry is online now
post #3782 of 3932 Old 08-14-2016, 12:45 PM
Gorilla Killa's Avatar
Quoted: 676 Post(s)
Liked: 778
For anyone else viewing, I was told by miniDSP that its not recommended to exceed 2000ma or 2 amps with the minidsp. 1 amp is what they recommend
Gorilla Killa is offline
post #3783 of 3932 Old 08-14-2016, 12:55 PM
Tstan7777's Avatar
Quoted: 93 Post(s)
Liked: 29
Sweet, thanks guys. I wish mini sold a proper power supply, it's pretty confusing trying to find one because there are multiple parameters and multiple connectors available. That's one I had around from my old audio interface. I guess it's not called diy for nothing!
Tstan7777 is offline
post #3784 of 3932 Old 08-14-2016, 01:07 PM
Quoted: 676 Post(s)
Liked: 778
They do, its an extra 10$ at checkout. If you want to just buy the PSU, you have to email them and then they'll send a paypal invoice. Somewhat clunky , but thats the miniDSP way
post #3785 of 3932 Old 08-14-2016, 01:14 PM
Liked: 4230
I just checked the MiniDSP web site, and both the unbalanced and balanced 2x4's now have an option to add a PSU. Note that the unbalanced 2x4 PSU is listed as a 5V unit, and the balanced 2x4 PSU is listed as a 12V unit. I don't believe your original post specified which 2x4 you have, so be aware of the difference.
post #3786 of 3932 Old 08-14-2016, 01:59 PM
Tstan7777's Avatar
Quoted: 93 Post(s)
Liked: 29
Ahh, let's role that back then. Because I have the unbalanced which says 5v. I kept seeing posts on using a 12v which is why I asked. I thought you had to match the volts on the unit to the supply but many were saying use 12v. So having the unbalanced 5v I need a 5v power supply right? Not sure whst happens if they're not matched. If so, I'll email mini and try that route so I get the right one.
post #3787 of 3932 Old 08-14-2016, 04:29 PM
Tstan7777's Avatar
Quoted: 93 Post(s)
Liked: 29
According to mini, the unbalanced can use 5v-24v power supply because it's internally regulated. The balanced version uses 12v only according to the interweb.
AustinJerry likes this.
post #3788 of 3932 Old 08-14-2016, 04:34 PM
Liked: 4230
Thanks for obtaining that clarification.
post #3789 of 3932 Old 08-14-2016, 08:03 PM
dashpuppy's Avatar
Quoted: 408 Post(s)
Liked: 241
you want to try that again ? ( because that doesn't make sense at all )
dashpuppy is online now
post #3790 of 3932 Old 08-14-2016, 08:46 PM
zeus33's Avatar
Quoted: 1549 Post(s)
Liked: 1393
It's crystal clear. What part don't you understand? They recommend not exceeding a 2 amp power supply, so you can use up to a 2 amp, but not anything higher. However, a 1 amp is the recommended amperage.
zeus33 is offline
post #3791 of 3932 Old 08-14-2016, 08:54 PM
dashpuppy's Avatar
Quoted: 408 Post(s)
Liked: 241
You realize that a 3 6 10 30 or 100 amp psu at 12v isn't going to make a difference at all right ?
post #3792 of 3932 Old 08-14-2016, 09:12 PM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 391
In a competent design that isn't a fire hazard, overcurrent on the power supply is handled by fuses within the device itself, that is, fuses on the power supply lines of the circuit board of the miniDSP itself. If such fuses aren't present, this is design incompetence and an unsafe situation with regard to a fire hazard when connected to a supply capable of too high a current. If they do have the appropriate fuses on the miniDSP power supply lines, they are admitting incompetence on the support side by not understanding that their power supply fuses will protect against an overcurrent condition.
dashpuppy likes this.
andyc56 is offline
post #3793 of 3932 Old 08-14-2016, 09:31 PM
zeus33's Avatar
Liked: 1393
I don't know their design, but why take a chance of blowing fuses? If they recommend a lower amperage power supply, just use it. Besides, a 1 amp is a pretty common one anyways. I make a habit of listening to a manufacturers recommendations when it comes to products that they designed. Don't you?
zeus33 is offline
post #3794 of 3932 Old 08-14-2016, 09:38 PM
dashpuppy's Avatar
Quoted: 408 Post(s)
Liked: 241
The statement that don't use anything over 2amps doesn't make sense at all.
When you put it into a car you can't limit the current going to it. So saying a 2 amp or higher psu will damage it is kinda miss leading.
It will only draw what it needs and nothing more.
Bassment likes this.
post #3795 of 3932 Old 08-15-2016, 02:42 AM
Quoted: 676 Post(s)
Liked: 778
For anyone else viewing, I was told by miniDSP that its not needed to exceed 2000ma or 2 amps with the minidsp2x4. 1 amp is what they recommend
Sorry for the ****e storm, this is how my post should have read
andyc56 and dashpuppy like this.
post #3796 of 3932 Old 08-15-2016, 10:21 AM
dashpuppy's Avatar
Quoted: 408 Post(s)
Liked: 241
It's all good just trying to clear things up is all
andyc56 likes this.
post #3797 of 3932 Old 08-15-2016, 11:32 AM
Wireless member
pepar's Avatar
Quoted: 1059 Post(s)
Liked: 548
I am about to give this a try - use a 2x4 to integrate my dual subs into my system. In looking at how to do this, and mentioned specifically (though optionally) in Jerry's guide, I see that there is software that can be used to optimize each individual sub. Sensing another rabbit hole within the 2x4 rabbit hole ... and with Jerry's "optional" comments in mind, is it consensus that there could only be minimal benefit with individual sub EQ before Dirac room correction?
Could I use the MSO software to assist in placing my two subs? Or does REW do that much? Additional context there is that my subs are each collocated pairs with limited possible lateral movement in front (behind a false wall/screenwall) and in the rear near my rack.
I suppose I should ask this generically so as to not run afoul of the OTP. Is ANYBODY using the miniDSP 2x4 to EQ the individual subs before applying room correction?
Jeff
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is online now
post #3798 of 3932 Old 08-15-2016, 12:21 PM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 391
To prevent going off-topic in this thread, I've responded in the MSO thread.
andyc56 is offline
post #3799 of 3932 Old 09-14-2016, 12:29 AM
kingpin111's Avatar
Quoted: 290 Post(s)
Liked: 283
2 part question.
Does the minidsp have to always be connected to my computer or once all the info and settings are done can I remove all the wires?
If the power goes off when the minidsp is "not" connected to my computer does it lose the settings or does it store information?
kingpin111 is offline
post #3800 of 3932 Old 09-14-2016, 01:49 AM
Quoted: 676 Post(s)
Liked: 778
Originally Posted by kingpin111 View Post
2 part question.
Save the configuration in your pc. I always load that configuration back to the minidsp to be sure, im OC about it. It saves it on the mini so no worries about unplugging and plugging back in.
kingpin111 likes this.
post #3801 of 3932 Old 09-14-2016, 05:32 AM
kingpin111's Avatar
Quoted: 290 Post(s)
Liked: 283
I'm moving my main computer from the basement where the minidsp is to upstairs. It's why I was worried.
post #3802 of 3932 Old 09-14-2016, 05:34 AM
Liked: 4230
2 part question.
To actually answer the questions you asked, yes, once you have completed the configuration, the computer is no longer needed. You can unplug it an disconnect the USB cable.
And no, nothing is lost if you lose power to the unit. All configuration is stored in non-volatile flash memory.
post #3803 of 3932 Old 09-14-2016, 05:59 AM
EndersShadow's Avatar
Quoted: 612 Post(s)
Liked: 929
How are folks powering these? I'm reacquiring one I sold to a friend, who is now selling it back to me.
I'd "prefer" to use the 5v DC plug instead but dont know if there is a preferred adapter for these or not.
My Setup | FS: Nothing right now
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #3804 of 3932 Old 09-14-2016, 11:12 AM
Quoted: 676 Post(s)
Liked: 778
This is what im using for the balanced version, been working fine since beginning of June. If you have the unbalanced the usb phone chargers is what I used for 2 years with that version.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
post #3805 of 3932 Old 09-14-2016, 01:37 PM
Quoted: 612 Post(s)
Liked: 929
I have the unbalanced version and I was also using a phone charger to USB, but then the cable was super short (I'm OCD about cable management) unless I was trying to program it, then the cable was too short....
I'd prefer to be able to jack in and out as I please while its always on 24/7
post #3806 of 3932 Old 09-14-2016, 02:15 PM
Quoted: 676 Post(s)
Liked: 778
I think they did the phoenix connectors so car audio guys could use as well. I know many have cut a cord or you can get a 20ft usb to micro.
I always found the plugging and unplugging to the mini annoying like you, so much so I quit mucking with my system...until I got the balanced v
post #3807 of 3932 Old 02-13-2017, 04:15 PM
MBrown2020's Avatar
Quoted: 71 Post(s)
I just purchased the minDSP 2x4 unbalanced. I plan on using it with 2 SVS PB-2000's & 1 PC-2000 (Same amp & drivers). The subs input sensitivity is 350mV. Is the .9V output on the miniDSP for each of the four outputs or combined (.9V divided by 4). I will be using this with a Marantz AV8802a.
I just did the voltage gain test using a Fluke 114 True RMS voltmeter. I had audyssey enabled by mistake when doing measurements, does it really matter? With MV=0 (reference) SW trim was as follows:
-5.0 = .998V
-5.5 = .940V
-6.0 = .890V
So if I set trims for combined subs (75dB) at -6.0 I should be good?
MBrown2020 is online now
post #3808 of 3932 Old 02-17-2017, 03:28 PM
MBrown2020's Avatar
Quoted: 71 Post(s)
Can you leave the unbalanced miniDSP plugged into the computer with the USB all the time and not have any problems? Do I need the AC adapter if I leave it in computer and it powers itself from USB port 5V?
post #3809 of 3932 Old 02-17-2017, 04:13 PM
Liked: 4230
I don't think the USB connection is providing power to the unit. These days, many of us have a spare USB power adapter lying around. I have used one of the little white iPhone charging cubes and it works just fine.
post #3810 of 3932 Old 02-17-2017, 04:22 PM
MBrown2020's Avatar
Quoted: 71 Post(s)
According to website:
USB self powered device and wide range of DC power options (4.5 to 24VDC)
So, I still need to power it with AC adaptor? I did order it with the miniDSP that arrives Saturday. Do you leave it plugged in at all times? Does the automatic sub turn off still work?
