MiniDSP - Page 128 - AVS Forum | Home Theater Discussions And Reviews
 190Likes
post #3811 of 3814 Old 02-17-2017, 05:35 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6623 Post(s)
Liked: 3654
Originally Posted by MBrown2020 View Post
According to website:
USB self powered device and wide range of DC power options (4.5 to 24VDC)
So, I still need to power it with AC adaptor? I did order it with the miniDSP that arrives Saturday. Do you leave it plugged in at all times? Does the automatic sub turn off still work?
Mine is powered all the time, and yes, my subs do turn off.
AustinJerry is online now
post #3812 of 3814 Old 02-17-2017, 05:38 PM
MBrown2020's Avatar
Quoted: 30 Post(s)
Jerry,
Could you have a look at post #3807 and see if I'm on the right track? Thanks again for all you help!
MBrown2020 is offline
post #3813 of 3814 Old 02-17-2017, 06:06 PM
Liked: 3654
I just purchased the minDSP 2x4 unbalanced. I plan on using it with 2 SVS PB-2000's & 1 PC-2000 (Same amp & drivers). The subs input sensitivity is 350mV. Is the .9V output on the miniDSP for each of the four outputs or combined (.9V divided by 4). I will be using this with a Marantz AV8802a.
I just did the voltage gain test using a Fluke 114 True RMS voltmeter. I had audyssey enabled by mistake when doing measurements, does it really matter? With MV=0 (reference) SW trim was as follows:
-5.0 = .998V
-5.5 = .940V
-6.0 = .890V
So if I set trims for combined subs (75dB) at -6.0 I should be good?
Each sub gets .9v. You should be just fine.
post #3814 of 3814 Old Today, 07:54 PM
Steve Hanna's Avatar
Quoted: 59 Post(s)
Liked: 33
I was.looking at the 2x4 HD as an active XO and DSP. Is there a LF cutoff and is it adjustable?
Steve Hanna is online now
