MiniDSP - Page 130 - AVS Forum | Home Theater Discussions And Reviews
 205Likes
post #3871 of 3876 Old Today, 07:53 AM
Cichlid109's Avatar
Quoted: 114 Post(s)
Liked: 58
Which Plug-in??
This maybe kind of a dumb question but I cannot find the answer so hopefully someone here can help please?? I have the miniDSP balanced and when I got I also got the 2-Way advanced plug in. The mini is being used strictly for my subs and the 2 way does a good job but now since my system is going to change somewhat I need a plug-in the will allow 1 input for 4 outputs I will not be using either the LP or HP filters just the PEQ. I am aware the 2X4 Advanced has more features but it only has 5 PEQ filters vs the 4-Way which has 6 ( I would prefer using 6 better tuning plus I can just transfer the same filters over ). My biggest concern with the 4-way are the LP and the HP if they can be bypassed then that solves the problem. I know they are only 10. each but I only need one and I just want to get it right instead of spending 20.
Yamaha RX-A2010 LCR BIC DV84's w/ 2 SX2400 amps, Volt6 front height w/nu3000, Volt6 surround w/ EPX2800, Polk Audio Rt-35 pwred by AVR,
Infinity 1262's 2 pair w/ nu6000,SI DS4's in 2 sealed Marty Cube w/ IT 8000, 2 SI HST18's in Dual Opposed w/ A14K
Cichlid109 is offline
post #3872 of 3876 Old Today, 10:07 AM
duc135's Avatar
Quoted: 156 Post(s)
Liked: 225
The 4-Way Advanced will do exactly what you're asking. 1 input to 4 outputs and all filters can be bypassed.
duc135 is offline
post #3873 of 3876 Old Today, 10:10 AM
Cichlid109's Avatar
Quoted: 114 Post(s)
Liked: 58
Thank you very much!!
post #3874 of 3876 Old Today, 10:14 AM
Gorilla Killa's Avatar
Quoted: 545 Post(s)
Liked: 592
I have found a annoyance with these. I have 2 separate mini's and when changing back and forth it recognizes its a different unit during synch but it still shows the previous units curve and runs it. I was having major issues and didnt figure it out after a day of tweaking. I sent an email so maybe they will address it. Just a heads up if youre running multiples.
Gorilla Killa is online now
post #3875 of 3876 Old Today, 12:47 PM
duc135's Avatar
Quoted: 156 Post(s)
Liked: 225
I don't seem to have that issue. Are you switching back and forth with the plugin still running? I close out of the plugin before switching connections to my various units. I have two units running the 4-Way for subs and one unit running the 2-Way for my mains. Try closing out of the plugin and relaunching it between switching connection over to the other unit.
duc135 is offline
post #3876 of 3876 Old Today, 02:49 PM
Quoted: 545 Post(s)
Liked: 592
Ive been unplugging each unit and plugging the other back in and re-synch. I just assumed since im re_syching and it recognizes its a different unit, it should load the config with that unit, not the previous used.
