MiniDSP - Page 132 - AVS Forum | Home Theater Discussions And Reviews
 212Likes
post #3931 of 3935 Old 07-28-2017, 12:53 PM
Gorilla Killa's Avatar
Quoted: 684 Post(s)
Liked: 791
I would eq all the subs not just the uxls. Y to the buttkicker and mini, miniDSP out to uxl and 15
Gorilla Killa is offline
post #3932 of 3935 Old 07-31-2017, 11:09 AM
OJ Bartley's Avatar
Quoted: 284 Post(s)
Liked: 357
Thanks Gorilla. That... is a great solution. I have the processing power, so I might as well put a little EQ on the Tempest too! I'm just waiting on my Monoprice cables to arrive so I can chop them up.
OJ Bartley is online now
post #3933 of 3935 Old 09-29-2017, 11:33 AM
OJ Bartley's Avatar
Quoted: 284 Post(s)
Liked: 357
Alright, cables made, REW filters created, and MiniDSP up and running. I had one little issue during hookup, which I didn't have an explanation for until I did a quick update on my sub thread today. Initially I wired the MiniDSP with the input side using the +, - and the jumper from - to shield. I wired the output side using +. -, and shield to the XLR cable connected to the iNuke. But I wasn't geting any signal, just an occasional pop when the MiniDSP cycled something.
Eventually I removed one end of the jumper, and everything seems to work fine, even though I couldn't figure out what had gone wrong. Upon examining this image in passing today, I see that I was only supposed to connect the + and - of the output, and not the shield.
If my way works, is it OK to keep it this way, or should I change it to match the setup above? This way seems to work well with a strong, clean signal, and it got rid of the hum I had been getting with the direct AVR to iNuke setup.
post #3934 of 3935 Old 09-29-2017, 02:34 PM
dtsdig's Avatar
Quoted: 911 Post(s)
Liked: 1035
So, to clarify, are you just using the "S" and the "+" on the output side like the bottom right diagram shows?
dtsdig is offline
post #3935 of 3935 Old 09-29-2017, 04:59 PM
OJ Bartley's Avatar
Quoted: 284 Post(s)
Liked: 357
No, on the output side I'm using "S", "+", and "-". All to an XLR cable end.
Edit: here's a pic (I hope - mobile posting)
Sent from my SM-A520W using Tapatalk
