MiniDSP - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 203Likes
Old 03-27-2011, 05:19 PM - Thread Starter
penngray's Avatar
Liked: 43
Originally Posted by mastermaybe View Post
Geeze, as someone pretty much depending upon this device for my sub "project" from what I gathered above I'm pretty disheartened.
I thought the spec sheet said it puts out 2 volts which would be fine, but if it's less than half of that figure we have a problem, Houston.
Penn: you seem to have a different experience with it? Hoping so!
James
Right now the minidsp is only used with main speakers. The balance version will be used with the pro amps.
I will have measurE but I was pretty sure I was getting more then 50Watts out of the Berhinger A-500.
penngray is offline
Old 03-27-2011, 05:23 PM
nwboater's Avatar
I'm also just getting into this low output voltage issue. Have been planning to use the Class D amps by HiFiMeDIY as very discussed on the DIY Audio Forum. They require 1.5 (unbalanced) volts for full output. From an old thread there it appears that a couple of resistors can be changedon the amps inputs to allow a lower voltage. I just posted a request for verification at that thread.
Looks like this .9 volt max output on the unbalanced version is a problem, or at least a potential problem for many of us. I'm going to make a post on the MiniDSP Forum "Suggestions" section asking that they have a way to increase their output. Might be helpful if others did the same.
Cheers,
Rod
nwboater is offline
Old 03-27-2011, 06:31 PM
augerpro's Avatar
Quoted: 101 Post(s)
Liked: 61
augerpro, those comments do not make sense at all from what I have seen out of the MiniDSP
Did John K. post on the MiniDSP forum on DIYaudio? Im looking for the post/discussion and I can not find it.
btw, Welcome back..I hope all is good!
Discussion at the PE forum. John used the unbalanced model that is why the output voltage is lower, this is a known spec difference and not really a big deal if you know about it ahead of time. If you have a high enough gain amp, or you don't run enough power for it to matter there can be benefits to the lower voltage because it allows the DSP upstream to run at a higher level, which has an impact on resolution in the digital domain. Still it can a problem for some, it would be nice to have some sort of gain (like 0.6-2.0v) adjustment to cover everyone's needs.
Really the apparently non-standard definition of Q at higher frequencies is probably the only real issue, and then only for those of us who measure the speaker, then model the EQ/XO in some software, and want to use those values directly in the miniDSP.
augerpro is offline
Old 03-27-2011, 07:24 PM
mastermaybe's Avatar
Quoted: 380 Post(s)
Liked: 317
Originally Posted by weeman View Post
The balanced version has 2v output. The unbalanced is limited to 0.9v output.
Good qualification...I'm in clear then I guess.
If that's the case it would seem to me everyone would be better served getting the balanced version then and simply running an RCA to XLR adapter, no?
James
My Parlor and Theatre: "Jimbo's Dugout" : http://www.avsforum.com/forum/15-gen...re-parlor.html
Actual phone call (see pic to left):
 Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
Old 03-27-2011, 10:43 PM
augerpro's Avatar
Quoted: 101 Post(s)
Liked: 61
James
This from John: "By the way, how do you get 2 V RMS out of the balanced unit when wiring it for single ended opt? The negative side of the output is shunted to ground which should result in 1 V RMS (max) between the positive side and ground at the input of the power amp."
I don't really anything about XLR, so I have no idea if this how they work or not.
augerpro is offline
Old 03-28-2011, 03:07 AM
A9X-308's Avatar
Quoted: 1421 Post(s)
Liked: 1062
On the standard single ended O/P board, the reason the output is limited to 0.9Vrms is because that is what the ADC/DSP/DAC chip used puts out for 0dBFS and they add nothing after it. Adding gain via say another opamp is getting difficult because it runs on a single +5V rail and most decent opamps won't give a lot of swing run this way. There are some that I might use for subs, but not full range, so a (say) +/-12V supply would be needed for that. That would mean a new board in all probability and not in their 75x75mm format.
For the balanced O/P version, I'm guessing they've just added an inverting opamp to supply the -ve out.
As for the suggestion of just changing the NFB resistors in an existing poweramp to get more gain, I would check with the designer/manufacturer first.
“If you want to be funny these days, tell the truth.” Bill Leak, 2016
Vale Bill. Sadly, the master has gone.
A9X-308 is offline
Old 03-28-2011, 04:44 AM
Quoted: 930 Post(s)
Liked: 493
Might the fix for the miniDSP's level issue be as simple as a car-audio line driver (such as an AudioControl Matrix for a multichannel system) on a 12V wall wart?
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
Old 03-28-2011, 05:43 AM
louisdamani's Avatar
Would the Behringer MX882 be the best of a good option for multiple outputs.
louisdamani is offline
Old 03-28-2011, 05:51 AM
Quoted: 380 Post(s)
Liked: 317
The last thing I want to do is spend $150+ and wait "x" amount of time for a device that won't allow me to realize 100% use of the amp I also spent $500 on.
So am I now understanding that starting with an RCA at the sub pre-out and going to XLR - minidsp - XLR - amplifier will still result in a voltage shortage at the amp and thus, decreased output?
Wow. If this is the case (low voltage ~1V) with either unit (balanced vs unbalanced), how on earth is ANYONE seeing anywhere near their max output potential while using these?
James
Old 03-28-2011, 06:16 AM
nwboater's Avatar
I made a post in the Suggestions section of the MiniDSP forum. Here's the companies response (hope it's okay with AVS to quote it here):
Rod,
Indeed the miniDSP un-balanced outputs 0.9Vrms max. That's based on the fact that it's using a 5V USB supply and supposed to be part of a consumer audio chain of devices. Adding output opamps + modifying the power supply section would mean added cost. Maybe future products based on 12V supply...
If you need higher output capability, using the miniDSP Balanced would be the way to go (2Vrms max). Simply run the input as a Pseudo Balanced/forward referencing which is actually very good at removing the common mode noise inherent to unbalanced connection. Then connect the output as shown on the user manual. The miniDSP could even turns itself into a preamp doubling your gain!
DevTeam
I don't understand what they mean by "run the input as a Pseudo Balanced/forward referencing", nor have I had a chance yet to look at the manual for the output connections. But it does seem as another poster here said that using 1/2 of a balanced 2 volt signal will result in a 1 volt signal. What am I misunderstanding? Think I'll go look at their manual now - but did want to get their response here right away.
Rod
nwboater is offline
Old 03-28-2011, 07:46 AM - Thread Starter
penngray's Avatar
Liked: 43
Has John contacted MiniDSP or post all this info on their forum(s)? I will check the PE forum and suggest that if he has not.
I knew about the unbalanced usage with subwoofers/pro amps already, we have discussed this in the thread also. The 50W @ 8 ohms is true too, just doing some simple calcs and the fact that Im at 4 ohms tells me Im around 100Watts. The balanced version is still delayed but I have to check USPS today.
One more reason, Why I love high sensitivity designs. No need to worry about more then 50Watts
penngray is offline
Old 03-28-2011, 07:52 AM - Thread Starter
penngray's Avatar
Liked: 43
James
James slow down.
MiniDSP NEVER considered usage in the subwoofer world until us DIYers started saying this would be a great device because of its < 10Hz EQing abilities.
They also live in a world where 100Watts is a lot of power so the voltage question was never raised when the product was first released.
MiniDSP is listening and will definitely work on something. Of course that does not help many today that have monster power requirements but we have to realize where the product life cycle sits at this time.
penngray is offline
Old 03-28-2011, 09:02 AM
Quoted: 380 Post(s)
Liked: 317
I do not necessarily disagree with you at all, Penn- perhaps except slightly in the DYI point, as I read on their site in multiple areas how they are specifcally attempting to cater to the DYI'er...perhaps just not specifically to this scenario (powering passive subs).
I'm really just saying that this may not be "best" for my particular application and therefore it wouldn't make a lot of sense for me to spend a decent sum of money on it, nor time, if indeed a better option exisits.
That said though, I haven't heard of too many more standalone devices (nevermind external amplifiers) that will give me the only thing I'm really looking for: sub 10hz filtering.
Suggestions?
James
Old 03-28-2011, 10:42 AM - Thread Starter
penngray's Avatar
Liked: 43
Its definitely a recent new topic for them to deal with. Im hoping the address the issue because I see this as a bread & butter device for subwoofers. I can even see manufacturers adding the device into their designs. Its still a feature rich product.
I think the balanced MiniDSP is at the post office, so I have to pick it and test it soon.
penngray is offline
Old 03-28-2011, 10:50 AM
nwboater's Avatar
Hi Penn,
If you are talking about the voltage issue, did you see my post above where they responded to my post on their forum?
Rod
nwboater is offline
Old 03-28-2011, 10:52 AM - Thread Starter
penngray's Avatar
Liked: 43
Yes, I did and there definitely confusion. JohnK posted that he does not even know how it can give 2V.
penngray is offline
Old 03-28-2011, 10:53 AM
noah katz's Avatar
Quoted: 888 Post(s)
Liked: 305
Not all pro amps have low input sensitivity.
The Peavery ipr's are .775V, for example.
Noah
noah katz is offline
Old 03-28-2011, 11:03 AM
Quoted: 380 Post(s)
Liked: 317
^ Yep, I'm looking at a QSC rmX 1850 now and that's 1.16- closer than a few at 1.4 I was considering.
As relatively unlearned in this arena I just want to ensure I'm doing everything as "most correct" as possible.
I'd imagine a line driver would still be doable between the minidsp and amplifier if absolutely necessary?
And out of curiosity, can you simply look at an amplifiers min sensitivity required and what you have and come up with an estimate as to your maximum power?
For example: If the balanced version can ouput 1.00 volt and the QSC sensitivity is 1.16 volts sens, can you divide the output by the input (1/1.16), come up with 86% and then look at its max output in bridged 4 ohm load format (2400 watts) and then calculate: 2400 X .86 to arrive at a maximum of 2,064 watts?
I realize published specs are not 100% accurate and that's prolly an 8 ohm sens rating, just wondering if the that's above board in theory.
If it is by chance, I'm sure I'll be fine as it would appear even 1 volt out of the dsp would drive this QSC fine.
Just curious too, I suppose.
thanks,
James
Old 03-28-2011, 11:13 AM
nwboater's Avatar
This is a post on my thread at MiniDSP from the DevTeam:
@ John,
Increased output gain of 2Vrms is indeed available on the miniDSP balanced version as mentioned by Theresa. These are meant to run off of a 12V Power supply and therefore can easily derive the split rail supply required for the op amps.
Hoping this clarifies,
DevTeam
The John they are adressing is John.Reekie - I don't think he's the John posting here.
Penn when you get your balanced MiniDSP can you test it's output voltage with a single ended output connection? Would be most informative for many of us here. I also am curious how they can get 1 volt single ended from a 2 volt balanced.
Rod
nwboater is offline
Old 03-28-2011, 11:20 AM
Quoted: 380 Post(s)
Liked: 317
^ Wait a second...won't must of us be going from an RCA (single) to an XLR to the minidsp to XLR to an amplifier?
So you mean going from a single ended RCA to a balanced output, correct?
Although it's not truly balanced, also correct?
Perhaps I'm lost again though.
James
Old 03-28-2011, 11:57 AM
A9X-308's Avatar
Liked: 1062
^^^ Easily, The 'balanced' signal is likely the outputs of a pair of opamps, one + polarity, one - polarity of 1V each. The 2V O/P is the difference between them (1-(-1))=2. So if you short one side to ground you only have 1V.
Edit: my ride turned up as I was typing this this morning, but form one polarity to either + or - will also only give 1V if using it this way.
A9X-308 is offline
Old 03-28-2011, 12:23 PM - Thread Starter
penngray's Avatar
Liked: 43
@ John,
DevTeam
I wish there was a nice low cost product out there that could easily measure voltage out of RCA and XLR connections. I have used TrueRTA for some tests but I think there was sound card issues,etc.
Rod
Okay, I have the balanced MiniDSP.
I have always had a hard time measuring voltages...so what do I wire and what do I use to get the voltage? Do I just wire up my Multimeter to the output connections or is there more to this?
I also need to buy a 12V power supply and some phoenix to XLR cables. I think I can rip some of my XLR cables apart to make up a cable.
penngray is offline
Old 03-28-2011, 12:32 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
hey folks, would i need one of these for two sealed 15" subs?
smokarz is offline
Old 03-28-2011, 04:16 PM
nwboater's Avatar
Penn,
This may take a little while to get ready for measurements. Here's how I would go about it (others may have some better ways) and keep in mind a lot of these steps you need to do anyway to use it:
1. Get your instruction manual out.
2. Wire up your 12 volt supply.
3. Hook up the USB to your computer.
4. Install the software plugin you are going to use on the computer and get a little familar with it especially how to set input and output levels.
5. I assume you are going to connect the input to a single ended source (RCA).
6. Get a cable together with RCA on one end for the source and bare wires on the other end. Connect the bare end to the input terminal strip per the instruction manual - Unbalanced connection.
7. For now we wont wire the output to anything. I just hope that the output voltage wont be higher than normal with no load. If someone thinks it might be then we should go ahead and connect it to your amp.
8. I believe you are running balanced to your amp. If so when you do hook it up you will want a cable with an XLR on one end for your amp input and bare on the other end to connect to the Output terminal strip per instruction manual - balanced connection.
9. We will need a steady sine wave signal on the output of your source (Preamp?). Something around one Khz would be good.
10. You will need a meter that will read true RMS. Do you have one? Or a scope?
11. You also need to know what input sensitivity on the MiniDSP you are set for. Is it .9v or 2 volt?
12. I believe their software has an input level display. If so we want this to go to 100% as you turn up the signal on your preamp.
13. Assuming you do have single ended input from your source connect your meter across signal and ground on the input terminal strip. The meter should read either .9 or 2.0 volts depending on the MiniDSP's sensitivity setting.
14. We now know that we have 100% input to the MiniDSP.
15. On the MiniDSP software set the output for 100%.
16. Read the voltage on the output terminals, I believe from + to - since it's a balanced signal. (Someone please correct me if I'm wrong on this.) It should read 2 volts RMS if the factory is giving us the straight scoop.
17. It would be helpful for those of us planning to use single ended in and out if you would read the output voltage with the output connected per the instruction manual for unbalanced output. That is connect a jumper on the output terminal block from S to -. Now read the voltage across + and -. It should still be 2 volts if what the factory is saying is correct. This is the reading some of us are questioning.
Whew - sorry that got so long Penn. Hope it didn't scare you away. As I said before most of the steps you are going to need to do anyway to use it. Basically what we are doing here is to put a 100 % input signal to the DSP, confirming with a voltmeter that it is in fact 100%. We are then adjusting the mini DSP software to give 100% output, and finally reading the output voltage on a meter or scope.
If anyone finds errors or omissions in these instructions, or a simpler way to do some of it, please comment.
Good luck.
Rode
nwboater is offline
Old 03-28-2011, 05:35 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Just wanted to say that I downloaded the two-way advanced plugin last night and it took no more than 20 minutes to manually adjust 5 biquad filters to smooth out my sub response within REW, import that into the plugin, add a high-pass filter as a crossover and upload it all to teh miniDSP. Easy as pie!
I couldn't, however, figure out how to get REW to design the (six) filters automatically. How is that done?
psgcdn is offline
Old 03-28-2011, 10:49 PM
A9X-308's Avatar
Liked: 1062
Better yet would be a test DVD/BR with test tones at 0dBFS into the AVR digitally, so you can also measure what levels the AVR puts out at what VC settings too. Anyway, start low and work your way up in level, and remember you will need to give it full scale on the input to get max output.
Correct. Doing this with no load will be fine.
It will be interesting to hear what numbers come out.
A9X-308 is offline
Old 03-29-2011, 05:33 AM
nwboater's Avatar
A9X-308 - Good idea on the test tone DVD/BR.
MiniDSP has just posted an FAQ on the I/O voltage levels. It's here:
http://www.minidsp.com/support/faqs/...nidsp-balanced
I've gotta believe that what they are posting is true, so this is good news for those of us needing higher than .9 volt outputs in a totally single ended system. It's just a shame that we have to buy the more expensive balanced kit when we only need single ended.
Penn, unless you just want to do the exercise for learning and to confirm exactly what your system levels are doing (good to know) I'm satisfied with what the factory just put out in the chart. I'm now ready to order 2 balanced kits.
Cheers,
Rod
nwboater is offline
Old 03-29-2011, 06:26 AM - Thread Starter
penngray's Avatar
Liked: 43
I only have a cheap digital multi-meter at this time. Maybe I should find an Oscilloscope on ebay.
Also, I sent an email to MiniDSP about John K's post on PE. Here is the response...
1) Sensitivity: It seems like there is a misunderstanding somewhere on
how a balanced kit would behave when using an unbalanced signal...
Looking at the wide range of applications of miniDSP balanced/unbalanced
(some users using this kit as a line driver almost), a short summary
table is in order.
I've just edited a FAQ summarizing all this information into tables and
with some explanations. I think that it will do some good. The same
information will be included in the miniDSP balanced user manual:
Note that if I recall you have a miniDSP 2x4 balanced (configured by
default on 2Vrms) so remember to open the box to turn it to 0.9Vrms to
get it to work as shown in the table at the bottom of the FAQ.
2) Q calculations: For this one, there is also a simple answer (just
need to ask.. :-) We're using RBJ's EQ calculations (/Robert/
Bristow-Johnson) who is using a different calculation on how to
calculate the Q. Here is a very good paper from him btw
(http://www.google.ca/url?sa=t&source...K2r35w&cad=rja)
Q calculations are notorious to be different and a Rane app note does a
very good work at showing that even in the major player (talking of
rane, bss, biamp) who are all major DSP box player, there seems to be
some miscalculations. This being said, we perfectly understand that
having the ability to copy and paste settings from say a DCX to a
miniDSP would make sense. We just need to include a translator or maybe
simply a radio button box to select which Q setting flavor you'd like to
work with... We've never been asked for that feature, but it makes
sense... I'll look into including it to the next revision.
Anyway, hoping this information helps, feel free to contact me if you
have any questions.
Best Regards
Tony Rouget
Co-Founder miniDSP
penngray is offline
Old 03-29-2011, 06:41 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
Sooo what's the typical voltage output on an Avr preout?
how much voltage is normally required to drive a pro amp?
NicksHitachi is offline
Old 03-29-2011, 06:42 AM
Quoted: 380 Post(s)
Liked: 317
Ok, not to consistently be the turd in the punchbowl here, but from what I'm reading off the chart, the 2V balanced output from an unbalanced input is derived from a 4VRMS signal with the jumper in the 2.0 position.
So is there still a problem with an AVR or PREPRO that's delivering 1.5/1.7 to the dsp...won't that fairly dramatically reduce the output voltage of the minidsp (assuming of course that the ouput voltage of the minidsp is directly correlated to the level of input voltage)...by at least HALF, seeing it takes 4V's to reach 2V's of output?
The obvious answer seems to be to place the jumper in the .9V postion but then are we at risk of overdriving the minidsp, as I've read the pre-outs of modern AVR's can easily exceed the .9 position's max input of 2.0V's (although above the grid it states the actual max of the .9 mode as 1.8 V's???)?
Someone just tell me to shut up if I'm needlessly complicating this. I'm basically asking if the jumper in either the .9 or 2.0 position would lead many AVRs to under or over-drive the minidsp.
Whenever I think I know more than I do, everyone suffers.
James
