MiniDSP - Page 97 - AVS | Home Theater Discussions And Reviews
 56Likes
post #2881 of 2892 Old 02-27-2015, 03:19 PM
Quoted: 46 Post(s)
Liked: 2
Originally Posted by AustinJerry View Post
Exactly. Somewhere between the XLR end and the RCA end, the cable undergoes a transition, going from the two-wire + ground to whatever is required on the RCA end. I am not sure why the OP was using the XLR-to-RCA cable to begin with.
I said 2 times already (post 2860 and post 2875) on this page alone that I had a unbalanced minidsp 2x4 before i got the balanced version because it wasnt enough output for my FB14K. Their manual says for unbalanced connection to jump the negative and shield.
Edit: i will cut up one to see if your right about the transition. Think the cable is 3ft long? If not ill just order some new cables. Best place for xlr to xlr male ends? Seems sweetwater doesnt have both ends as male on their site. Closet to me for shipping why i like that site.
MagnumMafia05 is online now
post #2882 of 2892 Old 02-27-2015, 03:52 PM
AustinJerry's Avatar
Quoted: 2008 Post(s)
Liked: 1123
I normally buy from Monoprice. Good cables at a reasonable price. Strange that both ends would be male. My pre-pro uses male, but my XPA-7 uses female.
AustinJerry is online now
post #2883 of 2892 Old 02-27-2015, 04:10 PM
Quoted: 46 Post(s)
Liked: 2
I thought maybe there would be cables with 2 male ends.. so i just needed 1 cable and cut it in half but if thats not the case ill order 2 cables.. i took the xlr apart. Pin 1 is jumped and solders to pin 3.
Edit. Here the manual
post #2884 of 2892 Old 02-27-2015, 04:41 PM
Liked: 1123
That is not a standard balanced cable. Clearly it was meant for a balanced to single-ended conversion. Since you can't get any output to your subs, I recommend you purchase conventional balanced cables, which I am reasonably confident will get you up and running.
post #2885 of 2892 Old 02-27-2015, 04:48 PM
Quoted: 46 Post(s)
Liked: 2
I have said its a unbalanced cable before. I even should you how minidsp shows how to wire that cable.
Anyways.. my dmm hooked up to the mini, i get 2.9 on DCV continously even if i move the output level on the mini around and even of i click mute if i have the positive in the + and negative in the - with the jumper from - to shield. Otherwise if the jumper isnt in, i get no reading.
Even if i soldered a new wire from pin 1 and took the jumper off from pin 1 and pin 3, it be the same thing with the jumper on the dsp like they even show on the manual.
post #2886 of 2892 Old 02-27-2015, 05:01 PM
Liked: 1123
I understand all that, and don't have an explanation why it isn't working. Are you saying you are not willing to get standard balanced cables to resolve your issue, or am I misunderstanding you?
post #2887 of 2892 Old 02-27-2015, 05:11 PM
Quoted: 46 Post(s)
Liked: 2
Lol no im willing to order the cables. I just dont see why it isnt working with this cable. Like is this a faulty dsp?
Here is my dmm on with a 40hz test tone
Here i have the channel muted. I tried to get everything in the picture. Same voltage.
Now i broke the jumper on the xlr from pin 1 and 3 and soldered a brand new wire pin 1. No its wired like a balanced cable. Im going to hook this up and see if it works. If not then i think i have a bad minidsp and i got it last week but finally got the power souce few days ago and now im here.
post #2888 of 2892 Old 02-27-2015, 05:25 PM
Quoted: 46 Post(s)
Liked: 2
Well i hooked it up.
And end result.. nothing.. again.
post #2889 of 2892 Old 02-27-2015, 09:04 PM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 217
Your multimeter is in DC mode. It needs to be in AC mode to measure an AC signal.
andyc56 is offline
post #2890 of 2892 Old 02-27-2015, 09:10 PM
Quoted: 46 Post(s)
Liked: 2
I'll retest it in the morning. I did both settings. If i recall both were the same. Thanks for the input I'll post up what i find. Hoping is just the cables.
post #2891 of 2892 Old 03-04-2015, 03:04 PM
Quoted: 46 Post(s)
Liked: 2
Well they are sending me a new internal module. Minidsp was quick about replying back with amazing customer service! Not that i didn't expect anything less. Now still waiting on my balanced cords that were suppose to be here today... just left (today) where fedex picked them up on Monday to be shipped to me.
Update: got my xlr balance cables today. Wired them up. Still no sound. So wasnt the cables
post #2892 of 2892 Unread Today, 09:31 AM
Quoted: 46 Post(s)
Liked: 2
Got my new module today and everything works. Figured i had to send the old one back but doesn't seem i do. Back in action!!
