Newb here - Help with a project - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-13-2010, 01:39 AM - Thread Starter
zephyrnug's Avatar
Hi all.
So I'm pretty new to speaker building and everything it entails. I've been reading up on it, trying to figure some stuff out, but need some help.
So I basically want to create let's say a box that two 7" woofers, two tweeters and a crossover units that will mainly act as a speaker system with a headphone jack to plug into iPods, etc. Now I've found some projects on instructables for speakers that are built to plug into receivers, but I don't want to do that. So can I convert the speaker wires into the headphone jack?
So I'm wondering what kind of power source I can use so I can have full power of the speakers while plugged into a source through a headphone jack, and how I would go about doing that.
Any help would be awesome. And I haven't decided on the parts I'm gonna get yet, so I might need help on that later too, making sure the woofers, tweeters, and crossover will work together. I want to create a semi-high-quality system with good components.
Thanks!!!
zephyrnug is offline
post #2 of 6 Old 10-13-2010, 09:05 AM
Mrkazador's Avatar
Quoted: 258 Post(s)
Liked: 384
Have a look here for completed builds
http://www.htguide.com/forum/forumdisplay.php4?f=39
http://techtalk.parts-express.com/sh...d.php?t=215536
Look for an efficient speaker build(econowave?) and incorporate a t-amp or build your own amplifier from 41hz.com.
Here is a simple dock
http://www.flickr.com/photos/simplesimon/sets/1747665/
Mrkazador is offline
post #3 of 6 Old 10-13-2010, 03:02 PM - Thread Starter
zephyrnug's Avatar
So it sounds like an amp is what I'm looking for. I may actually buy a set of Dayton 6.5" 2-way bookshelf speakers and pull em apart and put t-amp between them. The speakers say they handle 40 watts and 8 ohms. Would a Sonic Impact 5066 15-Watt amp work? It says it's compatible with any standard 8 ohm or 4 ohm shelf speakers up to 20 watts. Thanks for the help
post #4 of 6 Old 10-13-2010, 03:10 PM
LTD02's Avatar
Quoted: 2350 Post(s)
Liked: 2587
here you go:
http://www.chasehometheater.com/inde...id=53&TreeId=1
Listen. It's All Good.
LTD02 is offline
post #5 of 6 Old 10-13-2010, 03:25 PM - Thread Starter
zephyrnug's Avatar
Do you know if that has a 3.5mm mini-jack input?
post #6 of 6 Old 10-14-2010, 05:40 AM
jntart's Avatar
Check out the Podzuma build in the DIY projects section on Partsexpress.com.
It appears to be just what you are looking for.
jntart is offline
